| Hexpert |
 Hexpert L Plate Warrior
 Posted: 09:51 - 13 Jun 2021 Post subject: Kawasaki Er-5 2002 won't start |
Hello guys. First of all, sorry for my English(it's not my native language), secondly I'm beginner in these things, so my part knowledge is also quite broken.
I bought Kawasaki ER-5 just recently and it had and accident, all right side of motorcycle are damage (with main speedometer). I have a lot work to do, but main problem is that before taking off all parts I want to start engine. Just once to see how it works. But I can't do that. What I did:
*Checked battery (it is fine, starter works good)
*cleaned carburetor(was cleaned already)
*checked if ignition candle gives ignition(took out and touched with rim, spark was good)
*choke slide is open
*key lock is okay(pushed it "ON")
*all other safety vires are disconnected(but i guess if there is a spark, then there is no problem with vires, yes?)
*fuel tap is on PRI
What else should I do? I guessed that there is fuel fault, but I'm so new at this that I don't know what else should I do.
https://youtu.be/OvZR9-vODPA this is video of sound |
 Posted: 10:18 - 13 Jun 2021 Post subject: |
I'm pretty sure they need the rev counter to be connected to run properly, but you say you do have a spark...
It could be flooded. Try turning it over with the fuel and choke off and the throttle open. Maybe even worth trying some starter spray.
For what it's worth, it sounds ok. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 jeffyjeff World Chat Champion
| Hexpert |
 Posted: 15:44 - 13 Jun 2021 Post subject: |
You are absolutely certain it has a spark? Because as i said, I thought the rev counter needed to be connected for the IC igniter to function properly.
You say you've bypassed the safety interlocks but they are pretty complex on an ER5... Bridging the clutch switch so it appears like the clutch is pulled in all the time is the best bet in that respect. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 4 years, 303 days ago. Instead of replying here, would creating a new thread be more useful? |
