CM125C Starting problem
Beeza-Geeza
PostPosted: 18:44 - 13 Jun 2021    Post subject: CM125C Starting problem Reply with quote
Purchased a non runner CM125C over a year ago
Would just about start on full choke and full throttle
Fully stripped down once in lockdown, engine completely taken apart and put back together with new bearings, piston/rings, gaskets, seal etc
Both bores were in very good condition so did not need a rebore
Finally after stripping, welding, painting and polishing, it is back together again
Still will only start on full choke and throttle!!
Timing marks adhered to during rebuild, tappets adjusted correctly, new twin coil, leads and plugs fitted
Purchased a generic 125cc carburettor which is a clone of the fitted Keihin one and that also needs full choke and throttle.
Question
If the CDI or pickup were at fault do they just fail or can they be intermittent?
Spent more than I will ever recoup but it has been fun during lockdown, be nice to actually get it working
Any advise would be appreciated
Regards
Ade from Nottingham
Nobby the Bastard
Harley Gaydar
PostPosted: 18:58 - 13 Jun 2021    Post subject: Reply with quote
No. They either work or fail completely.
ignition coils can be fine when cold but fail when hot but they get hot because much higher voltage.
Triumph Sprint ST 1050
Beeza-Geeza
PostPosted: 19:45 - 13 Jun 2021    Post subject: Reply with quote
Also, it is not in the book what spark plug cap to use 1, 5 or 10K
using a 5K at present with a CR7HS medium heat plug
Nobby the Bastard
Harley Gaydar
PostPosted: 19:56 - 13 Jun 2021    Post subject: Reply with quote
https://www.wemoto.com/bikes/honda/cm_125_cp/93/picture/spark_plug_ngk
PostPosted: 20:47 - 13 Jun 2021    Post subject: Reply with quote
Is it getting enough petrol through the tap?
Do you have the airbox and filter and exhaust on?
Easy-X
PostPosted: 00:31 - 14 Jun 2021    Post subject: Reply with quote
Replaced carb, what jetting did you go with? What the new carb came with or the factory spec?
Beeza-Geeza
PostPosted: 08:36 - 14 Jun 2021    Post subject: Reply with quote
Petrol is via a funnel directly into the carb
Exhaust is on
Airbox is in but not connected (it takes hours to get the rubber connecting tube into position)
Beeza-Geeza
PostPosted: 08:43 - 14 Jun 2021    Post subject: Reply with quote
Replacement carb is with the standard jets, good shout (but still acts the same way as the correctly jetted Keihin)
But worth a shot re-jetting the new carb in case there is a problem with the original one
The original one however does not look like the one in the Haynes manual, does not have the pull choke, but not sure if all CM125c did
Ade
Beeza-Geeza
PostPosted: 08:45 - 14 Jun 2021    Post subject: Reply with quote
It the proper spec of the cap I'm having difficulty finding out (1,5or10k)
Ade
jeffyjeff
PostPosted: 09:06 - 14 Jun 2021    Post subject: Reply with quote
It does start with full choke and full throttle (oxymoron there!), suggesting a fuel system issue. Still, I would verify ignition timing is right and that spark advance is not way out of whack. The different spark plug cap resistance values are for radio noise suppression.
PostPosted: 10:01 - 14 Jun 2021    Post subject: Reply with quote
Many bikes wont run properly without the airbox in place.
Easy-X
PostPosted: 10:04 - 14 Jun 2021    Post subject: Reply with quote
How's the compression?
PostPosted: 10:11 - 14 Jun 2021    Post subject: Reply with quote
You've been painting... Do you have a good earth connections? Paint doesn';t conduct very well. So between the frame and engine, coils and frame and the battery frame earths. You often need to scrape some of your nice paint off behind the relevant fittings. I often fit an earth strap between the engine and the frame.
GettinBetter
PostPosted: 12:00 - 14 Jun 2021    Post subject: Reply with quote
This ^^
It's easy to do and costs nothing.....but tells a lot.
Also;
Turned over with no plug lead attached, half throttle, no choke.... soaking wet plug or barely wet?
When it DOES start is it responsive to the throttle and stays going but only at high revs, or runs for a while then dies or...something else?
Robby
Dirty Old Man
PostPosted: 12:39 - 14 Jun 2021    Post subject: Reply with quote
You've had the whole thing apart, so there is a big list of things to consider. You also haven't told us how it runs when it starts - is it full throttle just to tick over, or will only run at high revs and no hope at low revs?
There are a lot of things in the rebuild that would make me ask questions, like why both fitting new pistons? New rings I can understand, but why replace the Honda originals for what I assume are pattern replacements. Did you measure the old and new piston rings to be sure they needed replacing, and the new ones are any better?
There is also no mention of cleaning up and lapping in the valves, which is a standard part of a top end refresh.
That, combined with my naturally pessimistic attitude, makes me wonder if you committed the ultimate sin of the top end rebuild, and didn't get all of the gasket surfaces spotlessly clean.
Check compression, check valve timing.
Beeza-Geeza
PostPosted: 19:43 - 14 Jun 2021    Post subject: Reply with quote
A few updates
Bore was good, pistons replaced because I damaged them, bar underneath them to remove the clutch put dents in the bottom (I know, should have used a wider plates)
Compression - I do not have anything to compare the results to but LHS 8 bar 116psi RHS 7.5 bar 109psi so a little different
Valves removed and were lapped in, medium then fine
Earthing - Battery to crankcase to frame with paint removed
It's got a lever choke and will start on full throttle on full choke, can get it to about half throttle but erratic then dies, not a beat with no choke
BUT, have found that the existing carb it came with which did look as old as the bike itself is not a Keihin, googling HL IC T W shows it is actually a Fujian Hualong Carburetor (never heard of it) and jetting is Main 90, Pilot 35 not the listed 98/38 (so probably never ever worked on this bike) "it was working, honest guv"
Replacement carb was listed for a CM125C 1982 (mine is a 1983) so wrongly assume it would have been jetted for the bike it was listed for, jets on that were main 90 and pilot unknown (can't find a thing on it)
So
Ordered the correct jets, not sure if 90 to 98 & 35 to 38 would cause sure a drastic failure but I'll soon find out
Thank you for all your comments and help
Ade
bypass2
PostPosted: 21:30 - 14 Jun 2021    Post subject: Reply with quote
with it being the wrong carb might not be allowing the right amount of petrol whats needed try adjusting the float heights to allow more petrol. what about the battery power is it good
Beeza-Geeza
PostPosted: 22:42 - 14 Jun 2021    Post subject: Reply with quote
Battery is new
New jets should be here by the weekend, see what happens
Not sure about compression now, other bike forums seem to think anything near 100psi is to low, shame the manual doesn't give any readings, might try tightening head down a bit harder.
Regards
Ade
PostPosted: 22:45 - 14 Jun 2021    Post subject: Reply with quote
Please don't. You tighten the head down to the correct tension, in the correct tightening order, to the specified torque readings.
I sincerely hope this is what you did when you fitted it?
GettinBetter
PostPosted: 09:08 - 15 Jun 2021    Post subject: Reply with quote
Beeza-Geeza wrote:
...Compression - I do not have anything to compare the results to but LHS 8 bar 116psi RHS 7.5 bar 109psi so a little different...
That compression is IMO too low, somethings wrong (I would expect something in the region of 150'ish min). Either you haven't checked your lapping results, it's still getting past the rings, or the head gasket isn't sealing.
EDIT: .. or your valve clearances are too tight and the valves are NOT closing properly.
Robby
Dirty Old Man
PostPosted: 09:14 - 15 Jun 2021    Post subject: Reply with quote
Whether or not the compression readings and carb settings are bang on, they are in the right general area so it should work just fine.
I'm assuming engine timing is right to get the compression tester to give a reasonable figure. Any chance the valve clearances are wide open, so the valves are barely opening?
Beeza-Geeza
PostPosted: 18:50 - 15 Jun 2021    Post subject: Reply with quote
Well, I would not have believed it if I had been told it and not done it!!
New jets arrived today
Got back from work, swapped the 90 main for the 98, the 35 pilot for the 38
Tried on full choke and throttle, nothing, even worse than before
Tried with no choke and slight throttle as she bust into life
quick turn down on the tick-over screw and she's ticking away nicely
Would not have thought such a little change in jets would have such a massive affect
Still bits to go back on and then for a road test (after a MOT of course)
Cheers for all your help
Ade
Nobby the Bastard
Harley Gaydar
PostPosted: 20:10 - 15 Jun 2021    Post subject: Reply with quote
That's a huge change in jetting.....
GettinBetter
PostPosted: 20:28 - 15 Jun 2021    Post subject: Reply with quote
Beeza-Geeza wrote:
...and she's ticking away nicely....
Brilliant, good effort.
That compression is defo low (online values show as ~138), but it should improve as the rings bed in.
Perhaps you'll be good enough to post results of your testing/fine tuning?
The last post was made 4 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 123.7 Kb
