Power banks
ThunderGuts
PostPosted: 07:34 - 21 Jun 2021    Post subject: Power banks Reply with quote
Want to get a power bank to charge 'phone etc. when camping. There seems to be two categories; "mainstream" branded items costing £££ and never-heard-of-them brands on Amazon for circa £20-30. For the relatively infrequent use, I'm tempted by the latter, but are these likely to blow up / catch fire etc. etc.? Conscious they're a fairly sizeable lithium polymer battery potentially mixed with cheapo wiring and charging mechanisms? Or are they not a problem?
TG.
LustyLew
PostPosted: 08:03 - 21 Jun 2021    Post subject: Reply with quote
I've got a few Anker power banks. Seem pretty sturdy and no sign of them going bang.
UncleFester
PostPosted: 08:22 - 21 Jun 2021    Post subject: Reply with quote
Same and zero problems with them. Got two for trips to the USA and did the job perfectly when out and about away from power.
2017 Z1000SX
colink98
PostPosted: 08:26 - 21 Jun 2021    Post subject: Reply with quote
recently purchased 2 of these
https://www.amazon.co.uk/gp/product/B00XVTJKCQ/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
they seem to be well made and no getting hot or the like.
take a decent time to charge up and last for ages.
Ride it like you stole it.
doggone
PostPosted: 09:18 - 21 Jun 2021    Post subject: Reply with quote
The output amps do vary some earlier ones aren't really suitable for charging or running more demanding things.
Unless you really only want to boost your phone size up a bit and two or more outlets is good too.
I got this one last year you can charge a phone or camera without dropping one indicator light.
https://www.amazon.co.uk/gp/product/B07SB554G8
It is rather brick like in weight, towards the upper end of what you'd want in a pocket mind.
I have a much smaller one would do a weekend for phone and maybe one camera charge.
The bigger ones can take many hours to charge fully
Freddyfruitba...
PostPosted: 10:13 - 21 Jun 2021    Post subject: Reply with quote
I've definitely had problems with these things in the past, as iPhones in particular seem to be pretty fussy about what they will permit to charge them (I assume they allow only a narrow tolerance on the voltage?) I've had several which refused to perform, whereas at the same time being fine charging other kit.
PostPosted: 11:32 - 21 Jun 2021    Post subject: Reply with quote
I've got one that works OK but has a weird sort of problem. If it doesn't sense enough load it turns itself off. It's fine for charging phones and the like but if I plug in a strip of led's it's fine for 30 seconds then shuts down. I don't know if that's just mine or a general problem.
It's a cheap £25 Chinese piece of crap off Amazon that's OK for what it is but bulky.
Wifie has a proper Samsung one that's tiny and does 2 phone charges but that might not be enough for certain things and was rather more money than my cheapy.
ThunderGuts
This would be for charging my iPhone as well as the camping light etc.. so useful info. Did you have success with any particular one in the end?
TG.
NJD
PostPosted: 12:25 - 21 Jun 2021    Post subject: Reply with quote
Take a look at eBay auctions. People tend to sell two or three together, and end up going for not very much. Far cheaper than buying from Argos, which is the cheapest brand new option I found.
How much power the banks have will vary, of course, so make sure they meet your minimum power needs (the heated seat I used to use requiring a 5000 mAh power bank minimum, for example).
Freddyfruitba...
PostPosted: 13:47 - 21 Jun 2021    Post subject: Reply with quote
For what it's worth: https://iponcomp.com/shop/product/trust-19858-power-bank-4400-blue/1413073 - was only a cheapo one from Tesco or somewhere but it's worked well for about 7 years now; on its second iPhone. Cost never seemed to be a predictor of iPhone compatibility AFAICS!
steve the grease
PostPosted: 17:54 - 21 Jun 2021    Post subject: Reply with quote
I got one of these from Lidl's .
Power bank = Yes.
And it does start the Iseki tractor , when the battery is mostly flat.
Very handy I would say:
https://www.ebay.co.uk/p/28036014227
Islander
PostPosted: 18:37 - 21 Jun 2021    Post subject: Reply with quote
I have a Lidl power bank - just a power bank. I've had it for at least 5 years and it's very reliable and from memory, cheap. Thumbs Up
MCN
PostPosted: 20:02 - 21 Jun 2021    Post subject: Reply with quote
Solar powered? For long term camping where there is no power available then solar work. Power Monkey or something.
There are shitty ones available but although they provide the same power as others the battery and solar panels are not as refined or reliable.
A 12v-5v dropper connected to the bike can be used to power a phone/torch/power bank when moving (to save draining the bike battery when parked)
Ebay. I have two fitted to my bikes. Problem free for several years.
ThunderGuts
PostPosted: 06:50 - 22 Jun 2021    Post subject: Reply with quote
Karma was supposed to be helpful, not funny. Doh.
TG.
arry
PostPosted: 07:57 - 22 Jun 2021    Post subject: Reply with quote
I've got an Anker power bank that I've had for a good 6-7 years now. It's been faultless; it charges everything I've ever attached to it and holds charge very well even when left for weeks. Think I paid about 22 quid for it, way back then.
PostPosted: 08:02 - 22 Jun 2021    Post subject: Reply with quote
I've got a Varta one which has been fantastic, although now it won't quite get to full charge, I have had it for 7 odd years.
I've also got a suaoki jump starter which works as a power bank, and that is great although it's not quite man enough to jump my Beemer with it's 3 litre straight six. It will jump the bikes just fine though.
Diggs
PostPosted: 09:10 - 22 Jun 2021    Post subject: Reply with quote
We have loads of these in the house, and so far none of them has stopped working.
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
MCN
PostPosted: 18:57 - 22 Jun 2021    Post subject: Reply with quote
They mostly use lithium battery packs. Sort of off the shelf sealed envelopes sized appropriate to the case dimensions but the cheap shite cheats on that front mostly and only fits the cheapest cell. Small.
The smaller ones have less capacity.
And often the cells construction is lacking.
The Mrs and I have been using this beastie since Mar 2019
https://www.ebay.co.uk/itm/Qi-Wireless-Power-Bank-900000mAh-USB-Backup-Battery-Charger-For-Mobile-Phone-/124690666806?_trksid=p2349624.m46890.l49286
Cheaper now than then.
It still fully charges my 9s. Even when powered on and connected to 4g and stuff.
Wireless charges stuff too. My lectrik toothbrush picks up the induction loop too. Cool
I have used it fairly regularly too speshaly for travel.
Tdibs
PostPosted: 02:14 - 23 Jun 2021    Post subject: Reply with quote
Yep had a anker one for years, survived a few drops and still going.
The other one I have has jump leads adapter, just in case the bike needs a jump.
Courier265
PostPosted: 15:03 - 17 Jul 2021    Post subject: Reply with quote
I am using various power banks by some well unknown makes and they are quite good, never had an issue with any of them.
However for people who are a little worried, Anker is the Brand to aim for. Energizer and Duracell would be worth looking into but the price of them are a little high which might put people off.
Yes I'm still breathing and double jabbed.
I have a DBpower power back which can start a CBF500.
CBF500 - 2 x Inazuma 250
iooi
PostPosted: 18:58 - 19 Jul 2021    Post subject: Reply with quote
As this has just popped up again.
Just dug a old one out of the draw, that has not been used for a long time. Guessing must be at least 2 years, maybe longer.
Bought in 2017 (£37.00) RAVPower 26800mAh Power Bank Portable Charger. Left in drawer fully charged. Just plugged camera in, still got 75% power showing Charging like a good un..
The last post was made 5 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 112.72 Kb
