| A100man |
 A100man World Chat Champion
 Posted: 09:57 - 05 Jul 2021 Post subject: Battery fail or something else.. |
Last Sunday (not yesterday) I took the FZ 750 out for a quick jaunt. Picked up form storage started fine. traveled for petrol (3 miles) started again fine after, rode to my mates house 30 miles all good (switch light on to dip as others seems to have). Chatted for 1.5 hours went to start the bike - zippo fuel pump ticked but not enough juice to turn the motor even a little
Initially thought I'd left the light on but I don't think its possible with key removed.
Jumped it to get going rode home fine. Tried again when home after another 30 miles (light off this time) still zippo. Jump started again and measured the charge volts - 13.9..
Hmm Took battery off and into work for a regulated charge using a PSU. Seemed to take the right amount of current - back on bike zippo again.
On the face of it battery seems fuked, but how come it happened so quick? With ignition on current draw is about 2.5 A which seems a lot but I guess could be just what the coils draw?
No problem with buying another batt but curious to know why it failed
and if there an issue cure it first('twas Yuasa Lead acid topped up between lines so not run dry) ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
| Polo |
 Polo World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
| A100man |
 Posted: 12:11 - 05 Jul 2021 Post subject: |
| WD Forte wrote: | Try charging it while ensuring its getting at least 13.5v
(chargers can fail y'know)
and leave it over night to settle indoors circa 20C
Read the standing voltage next day
Healthy batteries tend to show around 12.7V
12.4V ailing, 12V bad
It could also be a sulphated, broken or distorted plate inside which can give a voltage that looks ok but have no real discharge power when put to work, ie starting. |
Hi WD - yes did exactly that charged at current limited 1.5 A at 15V then after leaving overnight measured what I thought was a healthy 12.8. It seemed to be taking charge and delivering a lot of Hydrogen in the process so I was confident when I connected it yesterday it would turn over the engine. Perhaps I should also check starter motor for dirty contacts/brushes? ____________________ Now: A100, GT250A, XJ598, FZ750
| A100man |
 Posted: 12:16 - 05 Jul 2021 Post subject: |
| Polo wrote: | Yeah I believe batteries like regular charging cycles. Had the same issue with my dad's car that he drove a couple of times a year. Get a voltmeter across the battery and if you have around 14v going in at a few thousand revs, time for a new battery. |
Yes t was the way it would start one minute then not the next which has got me looking at other options the battery. ____________________ Now: A100, GT250A, XJ598, FZ750
| steve the grease |
 steve the grease Crazy Courier
| doggone |
 doggone World Chat Champion
| Robby |
 Robby Dirty Old Man
| MCN |
 MCN Super Spammer
 Posted: 17:36 - 05 Jul 2021 Post subject: Re: Battery fail or something else.. |
| A100man wrote: | Last Sunday (not yesterday) I took the FZ 750 out for a quick jaunt. Picked up form storage started fine. traveled for petrol (3 miles) started again fine after, rode to my mates house 30 miles all good (switch light on to dip as others seems to have). Chatted for 1.5 hours went to start the bike - zippo fuel pump ticked but not enough juice to turn the motor even a little
and if there an issue cure it first('twas Yuasa Lead acid topped up between lines so not run dry) |
Open Cell voltage doesn't tell much about the real state of the battery. Its a test.
The sure-fire only proper test is to use a high rate discharge tester.
They more of less short out the battery (simulating full load conditions such as when starting an engine) and show how much voltage it can maintain under that load.
The more modern posherer ones either provide a print out of stuff or have a panel that shows test results.
Don't listen to Any other cnut telling you about batteries they are simple things Really.
Made complicated by Edjits. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| GettinBetter |
 GettinBetter Crazy Courier
| Islander |
 Islander World Chat Champion
 Posted: 20:46 - 05 Jul 2021 Post subject: |
Batteries can and do fail that way. Measuring the off load voltage will show fairly normal readings but as soon as it's on load it'll drop drastically. It's caused by one or more cells failing high resistance. I had one on the GSF1200 a couple of years ago. I started it to warm it up, switched it off because I needed the key to get under the seat. The next press of the starter, nothing at all. Dead battery.
It's worth checking the charging output of course - just in case there's an underlying problem.  |
| A100man |
 Posted: 10:38 - 26 Jul 2021 Post subject: |
| Islander wrote: | Batteries can and do fail that way. Measuring the off load voltage will show fairly normal readings but as soon as it's on load it'll drop drastically. It's caused by one or more cells failing high resistance. I had one on the GSF1200 a couple of years ago. I started it to warm it up, switched it off because I needed the key to get under the seat. The next press of the starter, nothing at all. Dead battery.
UPDATE:-
Since not desperately urgent I gave battery one last good charge and then monitored voltage drop during attempted start as suggested => 6V
New battery from Tayna deleivered next day => Vroom!
I am now more educated than two weeks ago. Thanks all. ____________________ Now: A100, GT250A, XJ598, FZ750
The last post was made 4 years, 224 days ago. Instead of replying here, would creating a new thread be more useful? |
