| hornet_guy |
 hornet_guy Two Stroke Sniffer
 Posted: 21:59 - 07 Jul 2021 Post subject: Bikes with 'divided' tanks. Tips? |
There are many bikes out there like my Honda CB600 whose tank is sort of divided in 2 sides due to the chasis running along the middle.
https://a.allegroimg.com/s512/116bb2/f7de38654f84bb683ff7a5e8a4ef/Zbiornik-paliwa-bak-Honda-CB-600-Hornet-PC36-03-06
It is well known that on these bikes one can't usually make use of the full tank capacity because fuel that is in the opposite side to the tap can't reach it.
Today, I was forced to stop on the side of the road with just 155 km (96 mi) on the clock (on reserve) to tilt the bike to the tap side and continue as normal.
How do you cope with this? Did you have bad experiences? Any tips to live with this?
Cheers |
| stinkwheel |
 Posted: 22:33 - 07 Jul 2021 Post subject: |
Usually by knowing how many miles you can do before running out of fuel and refilling before then.
However, you were either spanking the tatties off it or something is wrong. A CB600 hornet has a 16 litre tank, you should be getting around 150 miles out of that.
If you emptied it in 96 miles, that's 26mpg. That's 250LC territory.
Was it emptying to uncover the outlet, or was there a fair bit of fuel slopping about in the tank still? The "tunnel" on jap bike tanks is usually nearly totally flat at the back of the tank meaning fuel evenly distributes to both sides. Old Brit bikes had a tap on both sides of the tank (the bit stuck on one side was the "reserve", you ran on one tap then turned the other on when it started stuttering).
I wonder if you are having a fuel pump malfunction so it's emptying by gravity to float bowl level then conking out? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hornet_guy |
| F18 |
 F18 Renault 5 Driver
| hornet_guy |
| Pete. |
 Pete. Super Spammer
 Posted: 23:24 - 07 Jul 2021 Post subject: |
That 'lean it over to get a couple more miles' can be a life saver if you lose track of your range/forget to zero the trip and manage to run out. My bike has a balance pipe so if it runs low and starts to stumble you better make for the hard shoulder sharpish because you know it's gonna die in a matter of seconds. ____________________ a.k.a 'Geri'
| MCN |
 MCN Super Spammer
| hornet_guy |
| hornet_guy |
| stinkwheel |
The last post was made 5 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
