| NorthantsPete |
 NorthantsPete Two Stroke Sniffer
| doggone |
 doggone World Chat Champion
| Bhud |
 Bhud World Chat Champion
 Posted: 18:27 - 13 Jul 2021 Post subject: |
It's an easy task but as mentioned above, there are safety considerations when removing and reinstalling (or replacing) a tube.
You need to be careful the tube isn't pinched anywhere, and that you don't puncture the tube, that it isn't chafing against something rough, and that the valve is lined up perpendicularly.
If you look at my thread here in the workshop, I had a bit of trouble with a tube. To be on the safe side, if you're getting a new tube get a branded one from a reputable source. One trick to stop the tube pinching when putting it in is to inflate it to 5 to 10 PSI. You should be able to press the second bead of a tubed tyre in with just your fingers, and it helps if you do in the summer, and spray the rim and sides of the tyre with soapy water. Try to avoid using a lever or you could damage the inner tube.
Another thing: your tyre really has to be seated properly on the rim. This means, use lots of soapy water. It may also mean you have to overinflate. If it doesn't make a popping sound as it seats, look at the moulding mark around the tyre and make sure it's visibly equidistant from the edge of the wheel, when the tyre is inflated. You may have to deflate and do this a few times. I won't recommend overinflating to crazy high pressure to seat the bead because it could blow up, but I've done this in the past (while wearing a helmet). |
| jaffa90 |
 jaffa90 World Chat Champion
| martin734 |
 martin734 Spanner Monkey
| MCN |
 MCN Super Spammer
| davebike |
 davebike World Chat Champion
 Posted: 09:03 - 14 Jul 2021 Post subject: |
I expect you find if you take it to a fitter you will get a new tube
Pro were banned by our insures from poaching tubes back in the 1970's !
Tune is under £10 a patch takes ages at £60 per hour !
Me as I done thousands I just fit a new tube but be sure You have found the cause!
No tyre tools take the wheel to a fitter
DIY get two tubes ! you may/will kill one ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| Islander |
 Islander World Chat Champion
| NorthantsPete |
| blurredman |
 Posted: 12:04 - 15 Jul 2021 Post subject: |
| NorthantsPete wrote: | 9the current oen was patched about 3 times probably why!)
Why not?  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
The last post was made 4 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
