Looks like my reserve is clogged... cleaning agents vs manua
SirFallalot
PostPosted: 17:24 - 17 Jul 2021    Post subject: Looks like my reserve is clogged... cleaning agents vs manua Reply with quote
As I wait for me mum to bring me a fresh can of fuel and what other bikes go by, I'm thinking if I really need to disassemble the petcock or running something through a premium tankful will sort the problem?
Hadn't considered testing reserve before I actually needed it, so now I'm stuck on the A27. Only had the zx9r for a couple weeks and I figure the po didn't go on long rides or let it run dry.
Lexmoto Valiant 125; 94 CB400; 96 CB750F2; 81 CB750 (restoring, lol not gonna happen); 2001 ZX9R(It's about to go :c); 2012 R1200R; 2015 R1200RS
wr6133
PostPosted: 17:52 - 17 Jul 2021    Post subject: Reply with quote
Clean it properly, even if you find something to "clean" it where is all that shit going to end up......
Zen Dog
PostPosted: 17:59 - 17 Jul 2021    Post subject: Reply with quote
I doubt running a tankful of fuel through is going to do anything. You've been running fuel through the whole time you've been riding it. And if you mean running the tankful through with it on reserve, if it's clogged with crap, do you really want to run all crap that through your engine?
20 year old bikes need love. Clean it out if you think it's blocked.
Current - '94 VFR750FR (Dead), '00 VFR800FI, '10 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
Easy-X
PostPosted: 20:48 - 17 Jul 2021    Post subject: Reply with quote
Pull off fuel line, empty fuel into a safe container, remove petcock* and clean... what's to think about?
*And make futile attempt at catching the remaining fuel.
steve the grease
PostPosted: 21:48 - 17 Jul 2021    Post subject: Reply with quote
I remember with a smile watching the boss at work try and drain a full tank of petrol from a big lawnmower into a tea cup as he unscrewed the tap to unblock the filter that was clogged up with grass and other shite.
I did point out to him that the teacup might not be quite big enough for the job, but was told to shut up as 'I didn't know what I was taliking about'.
Imagine the glee of the assembled workforce as the 2 gallon tank pissed out all over the wooden Parkies hut and the Boss screaming and shouting.
Mower did run better after we cleaned the filter though.
All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of.....
Robby
Dirty Old Man
PostPosted: 11:55 - 18 Jul 2021    Post subject: Reply with quote
If the reserve channel in the fuel tap is blocked, it is more likely to be blocked with a sludgy mixture of water and rust. Premium fuel won't do a thing.
Take it off and blow it through gently with an air line in the outlet and the tap set to RES. If it's a vaccum tap you may need to put a line on the vacuum port and suck on that to open it up.
Good time to drain the tank anyway. If the reserve is clogged, you probably have half a pint of rusty water in the bottom of the tank.
No further dismantling or cleaning should be necessary, and you're more likely to break something if you try. You don't need to remove every last molecule of water or dirt.
The last post was made 4 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 47.87 Kb
