| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
| stinkwheel |
 Posted: 22:43 - 26 Jul 2021 Post subject: |
Got one on my VFR replacing the exact same pump as you have. I've fitted the 40171 pump which is working just fine.
Should be a comparative piece of piss to replace on the CBR because it's not so tight in the area round the pump. You'll need to work out what fittings you need because the facet pumps go in one side, out the other where the Honda one goes in and out on the same side.
Remember the threads on the pump itself are oddball American NPT threads, it's probably easiest to order the fittings at the same time as the pump. Or at a minimum an NPT to BSPT adapter so you can use readily available UK fittings.
The lady at fuelpumpsonline.co.uk was very pleasant and helpful on the phone when they missed a part from my order.
EDIT: Even got rid of a slight response lag when you crack the throttle in the midrange the bike has always had which I was putting down to the transition across a step on the needle profile. It wasn't, it was a glitch in fuel supply picking up. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| yen_powell |
 yen_powell World Chat Champion
| Nobby the Bastard |
| Fisty |
 Fisty Super Spammer
| Hong Kong Phooey |
The last post was made 4 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
