Turning engine over - starter motor only
droog
PostPosted: 15:31 - 05 Aug 2021    Post subject: Turning engine over - starter motor only Reply with quote
Hi guys, I hope everyone is doing ok.
My CBR600 F4i (fuel injected model) has been sitting for well over a year and I would like to turn the engine over for a few cycles using the starter motor (only) to give the camshafts a coating of oil before I start the bike up for real.
I just need to check that my technical preparations are correct beforehand:
1: Fuel pump (located underneath fuel tank) wiring disconnected so fuel pump will not
prime and feed the fuel injection system (so I'm not spraying neat fuel into the
cylinders).
2. Spark plugs and coil packs disconnected and removed so I don't damage coils/electrical
system, plus no compression so easier for the engine to turn over.
3. Throttle held open when applying starter motor.
Is there anything I got wrong or missed out? Thanks. Very Happy
droog
PostPosted: 15:32 - 05 Aug 2021    Post subject: Reply with quote
Or maybe I should just take off the valve cover and give the cams a squirt with an oil can to give them a decent coating of oil and start the bike normally?
PostPosted: 17:37 - 05 Aug 2021    Post subject: Reply with quote
Overthinking. Shorting across the terminal posts of the starter solenoid with the ignition off will turn the engine over without any chance of it starting.
blurredman
PostPosted: 18:19 - 05 Aug 2021    Post subject: Reply with quote
Do FI bikes not have killswitches? Genuine question- never had one.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:28 - 05 Aug 2021    Post subject: Reply with quote
They do, but mine turns off everything on my nbike the same as the ignition does. I thought that it was normal.
Triumph Sprint ST 1050
droog
PostPosted: 20:06 - 05 Aug 2021    Post subject: Reply with quote
I'm sure you are a 100% right - but I'm convinced if I take that route I'll make a mistake and blow the electrics Embarassed
Bike is already stipped down so removing the coil packs and plugs, and unplugging the fuel pump won't take long - then I'll turn it on the starter (throttle open) a few times to get some oil over the cams.
Cheers Very Happy
droog
PostPosted: 20:10 - 05 Aug 2021    Post subject: Reply with quote
Yeah, as stated by Nobby they have kill switches - starter motor won't turn with the kill switcch on.
PostPosted: 00:06 - 06 Aug 2021    Post subject: Reply with quote
Cheers Very Happy
Nothing to blow. It's unfused and the cables are the width of your finger.
droog
PostPosted: 07:46 - 06 Aug 2021    Post subject: Reply with quote
Thanks Stinkwheel - I'll take another look at doing it that way. Very Happy
Robby
Dirty Old Man
PostPosted: 10:43 - 06 Aug 2021    Post subject: Reply with quote
Or you could just start it. Nothing will get damaged. The trouble only creeps in when metal is hot, spinning fast, and running without oil.
PostPosted: 10:54 - 06 Aug 2021    Post subject: Reply with quote
Absolutely. As long as you have decent oil in it , it will be fine and that's if it starts straight off. The chances are it will go a couple of revolutions before it fires so doing what you want anyway.
Press and play Thumbs Up
Triumph Trophy Launch Edition
droog
PostPosted: 11:02 - 06 Aug 2021    Post subject: Reply with quote
Yeah, thanks Robby, Polarear. I'm probably being a little paranoid. I'll see how things go.
WD Forte
PostPosted: 14:14 - 06 Aug 2021    Post subject: Reply with quote
As said, just whip the plugs out and short the solenoid terminal with a screwdriver blade a few times to get the oil circulated.
Nothing will assplode.
I use a spare car battery and jump leads for similar purposes but the principle is the same.
On a rebuilt or long laid up motor, I usually spin it up until the oil light goes out a few times before firing up in anger then when it does start
dont rev the tits off it until it's started to warm up
bikers smell of wee
droog
PostPosted: 17:36 - 06 Aug 2021    Post subject: Reply with quote
Cheers WD Forte, excellent advice Very Happy
Shaft
PostPosted: 22:08 - 06 Aug 2021    Post subject: Reply with quote
You need to watch a few resurrection vids on YooToob
https://www.youtube.com/watch?v=fhpA1uT8W28&t=9s isn't a bad place to start.
tl;dr Fires up car after 26 years in a field, throws some tyres on it and drives it 600 miles home.
After a life of running on modern oil, you might do some damage to your bike if it started instantly and you revved it straight to the limiter and held it there for half an hour...............
............but probably not.
droog
PostPosted: 11:24 - 07 Aug 2021    Post subject: Reply with quote
Ha! Thanks Shaft! yeah, that video defiinetly adds some perspective on how robust engines actually are.
I love these ressurection videos, watching some guy using his skill and know-how bringing back a 'long dead' machine to life is really satisfying.
It's great to see old, forgotten bikes, cars and trucks getting rescued like this. Very Happy
The last post was made 4 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 91.72 Kb
