Changing ignition battel on alarmed bike?
TheGazWaz
PostPosted: 13:07 - 11 Aug 2021    Post subject: Changing ignition battel on alarmed bike? Reply with quote
Hi all,
The ignition barrel on my ZX9R is fekd and getting worse. Sometimes I spend 3 to 4 minutes trying to get the key to turn so I thought it’s about time I sort it out before I end up stranded.
I’ve tried the Pencil carbon trick and sprayed plusgas down the barrel but it ain’t touching it.
I’ve bought a new ignition barrel and I’ve no problem about fitting it mechanically. The question I have is about whether my alarm system will allow be to just unplug the old barrel and plug the new one in.
My alarm system is a Datatool EVO 433. Currently it auto arms after 30 seconds of the ignition begin switched off so the bike won’t start and cannot be moved without the alarm going off so I suspect it is wired to the ignition somewhere.
I’ve done a barrel change on my GSXR K3 but that wasn’t alarmed so it was straight forward.
Has anyone else had this situation before?
Cheers all and much appreciated.
Went like this.. 43 years old(2013) decided to do CBT to get a 125 for new job. Bought 2011 YBR, loved it for three months then hated it because it was too god damn slow. Did DAS 4 months later then bought RF600 Loved it, sold it bought Bandit 1200(K3). EFFIN lOVED IT. Wanted something a bit more sporty so got Triumph Sprint ST 955i (53). Not sporty enough so now on my GSXR 1000 K3 and absolutely love it. 1 year down the line, nearly died way too many times on this bike. Sold it. Had a 6 month break. Missed biking so now, Aug 2019 have a 1999 ZX9r. What a beauty she is too.
Islander
PostPosted: 13:46 - 11 Aug 2021    Post subject: Reply with quote
Crack on - you'll be fine. Datatool alarms use their own fobs which are separate from the keyed system. Thumbs Up
TheGazWaz
PostPosted: 14:43 - 11 Aug 2021    Post subject: Reply with quote
Smashing thank you.
Kawasaki Jimbo
PostPosted: 17:44 - 11 Aug 2021    Post subject: Reply with quote
Since you’ve already got the new barrel you can leave the old one in-situ for a moment, unplug it, plug the new one in and try it.
I think you have to drill the security bolts which hold the old barrel in, don’t you?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:51 - 11 Aug 2021    Post subject: Reply with quote
Yes, will have to.
TBH security bolts are a PITA only for the owners of bikes. theives don't bother undoing them to steal bikes, they just jemmy the ignition if the steering lock is on, causing even more damage to the bike.
This is why I never use the steering lock and when I have to replace an ignition I just use a normal pair of M6(?) bolts of a suitable length.
Triumph Sprint ST 1050
TheGazWaz
PostPosted: 12:55 - 13 Aug 2021    Post subject: Reply with quote
Oh crp yeh. I've had a look with my inspection mirror and there is nothing to get hold of. I believe they are torqued to snap off at the factory. I get it but ffs...
Good idea about plugging the new one in situ first to make sure it does everything it should. I'll do that.
I plan on taking the top tree off to do the job. I've had it off before when I did my head bearings. Not a bad job tbh. I'm a bit nervous about drilling the old bolts out though as they go into aluminium and I can imagine the threads getting feked up pretty easy.
What this space.
Gaz
Nobby the Bastard
Harley Gaydar
PostPosted: 13:10 - 13 Aug 2021    Post subject: Reply with quote
You only need to take the heads off. Then the ignition will slide off and you can undo the remaining threaded bits with your fingers.
Angle grinder will do. You'll be throwing away the ignition anyway.
TheGazWaz
PostPosted: 17:09 - 13 Aug 2021    Post subject: Reply with quote
Your soooo right Nobby thank you. I've got a dremle with plenty of cutting wheels so I'll give that ago before I get the big boy out.
I really didn't think of doing it that way. So long as I plug the new one in to check it works fine first I don't need to worry about damaging the old one.
Nice one cheers
The last post was made 4 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 57.68 Kb
