Chain Lube - BCF choice?
Shaft
PostPosted: 21:34 - 13 Aug 2021    Post subject: Chain Lube - BCF choice? Reply with quote
Righto, having ventured back to the dark side and bought a chain drive bike that I'm using a lot, what's the current best choice for something I can squirt out of a can?
Please don't suggest used engine oil or boiling up tins of grease on the cooker, this is the 21st century and I'm looking for something as low effort as possible, as befits somebody who finds chains so objectionable, I even called myself Shaft!
Oh, as close to zero fling as possible too, I hate having the back end of my bike covered in crap.
So, fire away, what can I go and buy that will satisfactorily do the job?
Kawasaki Jimbo
PostPosted: 21:54 - 13 Aug 2021    Post subject: Reply with quote
In true BCF Workshop style (oh, wait) I’m going to give you the answer you don’t want. Chain lube from a can, be it oil or wax, is filthy, expensive shit. Get a bottle of 90w gear oil and a 3/4” paint brush. Paint it onto the chain, then hold a rag over the lower rung and turn the back wheel by hand to wipe off the excess. It will still fling a bit but it’ll come off wheel rims easily with WD40 if it bothers you, yet you don’t need to re-apply all that often with an O-ring chain. It’s a satisfying 3-minute job. If that’s all too much, get a car.
Long-term users of aerosol chain wax should uncover the front sprocket and see the sticky ball of stones which the chain runs around. Grinding paste.
arry
PostPosted: 21:56 - 13 Aug 2021    Post subject: Reply with quote
As above. A small layer of gear lube applied with a small paint brush and wiped over with a rag.
Yeah, sure, spraying tins of stuff is a bit easier - but not by much, and by the time you deal with the clear up you're probably not gaining much.
JustinW
PostPosted: 22:21 - 13 Aug 2021    Post subject: Reply with quote
Gear oil for me. Cheap as chips and does the job.
xX-Alex-Xx
PostPosted: 22:23 - 13 Aug 2021    Post subject: Reply with quote
Kerosene and new engine oil mixed 4:1. Cleans the chain and leaves the oil behind. Been using it for years.
DILLIGAF
Fizzer Thou
PostPosted: 22:46 - 13 Aug 2021    Post subject: Reply with quote
Mark gave me a can of Wurth Dry Chain lube for Xmas and I have used it a few times if I have forgotten to lube up after a rideout.
But for foreign and general UK use I use this stuff from Halfreuds,although it is cheaper if bought from other places
https://muc-off.com/products/all-weather-chain-lube-motorcycle
Always have a 'Plan B'
wr6133
PostPosted: 22:47 - 13 Aug 2021    Post subject: Reply with quote
I use wynns clear lube. Fling isn't too bad and cleans off easily.
Easy-X
PostPosted: 22:57 - 13 Aug 2021    Post subject: Reply with quote
Granville Spray Grease & Chain Lube. It's pretty sticky stuff - certainly hard to wash off your hands - fling's not too bad. I stick a bit of scrap cardboard behind the chain while spraying, wouldn't want this stuff going anywhere near the rear tyre or brake!
JackButler
PostPosted: 04:06 - 14 Aug 2021    Post subject: Reply with quote
Chainsaw oil (think about it !)
Usually painted on & excess wiped off but the regular runners have Scottoilers filled with it.
I clean my guns with the tears of the snivelling, left wing scum.
PostPosted: 09:39 - 14 Aug 2021    Post subject: Reply with quote
I use a Kawasaki branded 6t9 chain lube. It's good. It smells nice, it doesn't fling but it does penetrate the chain well.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Nobby the Bastard
Harley Gaydar
PostPosted: 10:03 - 14 Aug 2021    Post subject: Reply with quote
As much as I don't want to agree with back scutler ...
Chainsaw oil, scotoiler, no fucks given about flingoff, stops the bike rusting.
Triumph Sprint ST 1050
Easy-X
PostPosted: 10:25 - 14 Aug 2021    Post subject: Reply with quote
Yeah, I think it boils down to three camps: dab on old motor oil by hand, spray on overpriced <insert brand here> or Scotoiler + chainsaw oil.
Nobby the Bastard
Harley Gaydar
PostPosted: 10:28 - 14 Aug 2021    Post subject: Reply with quote
I bought a galleon of chainsaw oil about 5 years ago for 15 quid. I reckon about half a litre is left.
ThatDippyTwat
PostPosted: 11:46 - 14 Aug 2021    Post subject: Reply with quote
This. Emphasis is mine.
Simon13245
PostPosted: 12:33 - 14 Aug 2021    Post subject: Reply with quote
I used Ipone spray lube, but I regret not using simple 90w oil. I did in fact remove the excess lube with a cloth, but it seems it wasn't enough. I had lube all over the rear rim, some in the rear indicators as well, and also the front sprocket cover was covered in black grindy grease.
I bought this lube with a cleaner as a bundle just before I got the motorcycle. Next time I will be definitely using 90w gear oil.
Honda NSR 125R (1999)
Nobby the Bastard
Harley Gaydar
PostPosted: 12:44 - 14 Aug 2021    Post subject: Reply with quote
Judging by the cleanlines of your rear wheel and how dickered in oil your chain is, yours is a garage queen.
Some of us use our bikes up to 10k miles a year (pre COVID) and put longevity and ease before how pretty it looks.
Simon13245
PostPosted: 13:33 - 14 Aug 2021    Post subject: Reply with quote
Of course it's clean and well lubed (on the pic), because it was the day it was cleaned and lubed Smile
Also, does "longevity and ease" have to collide with "how pretty it looks"? Just clean it from time to time.
You can use your bike however you want, I'm not judging your practices Thumbs Up
UncleFester
PostPosted: 13:47 - 14 Aug 2021    Post subject: Reply with quote
Scotoiler. Just set it so it doesn't over lube. Sure there's a bit of fling but it's zero maintenance other than a wash from time to time.
2017 Z1000SX
PostPosted: 10:48 - 15 Aug 2021    Post subject: Reply with quote
Gear oil is best. Fortnine put that one to bed.
Muck-off all weather chain spray lube is however convenient and smells like sweeties.
Ayrton
PostPosted: 17:15 - 15 Aug 2021    Post subject: Reply with quote
90w gear oil applied with a toothbrush is about as low effort as you can get. I just use paraffin with a toothbrush and rag to clean the chain first.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:34 - 15 Aug 2021    Post subject: Reply with quote
Still much more hassle than putting oil in a container every 300 miles.
ThatDippyTwat
PostPosted: 17:43 - 15 Aug 2021    Post subject: Reply with quote
Thy're great until they let go and dump it all over your rear tyre. That's why I ripped it out and binned it. I'd rather spend a minute or so once a week. Can also check the split link while I'm doing it.
Also - White wheels, and Scottoilers don't mix.
Islander
PostPosted: 18:07 - 15 Aug 2021    Post subject: Reply with quote
That^^
All of that - including the need for regular removal of the grinding paste under the front sprocket cover.
If you don't like the smell of the gear oil, you can do the same thing (at a higher cost) with Scott Oil.
Or you could fit a Scott oiler or a PDOiler, set the drip rate and forget it (apart from topping the reservoir up periodically).
I'd recommend the oiler.
xX-Alex-Xx
PostPosted: 18:39 - 15 Aug 2021    Post subject: Reply with quote
My 929 came with a Scottoiler already installed. Really good bit of kit. I installed a new chain/sprocket after I bought the bike, and put something like 20k on that bike. The chain was still pretty much in brand new condition when I sold it on - literally zero pull-away rearward from the back sprocket.
DILLIGAF
Nobby the Bastard
Harley Gaydar
PostPosted: 18:47 - 15 Aug 2021    Post subject: Reply with quote
The design of a scotoiler makes dumping it on the wheel almost impossible. Even if the valve stuck open, it's still gravity fed and with the bike on it's side stand after 3 hours you would have a puddle next to your back wheel and not on it.
The last post was made 4 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 126.23 Kb
