How easy is it to learn how to operate a motorcycle clutch?
JohanTheAndro...
PostPosted: 12:36 - 16 Aug 2021    Post subject: How easy is it to learn how to operate a motorcycle clutch? Reply with quote
I'm going for my first-ever motorcycle lesson next month, and I'm a little nervous about learning how to properly use the clutch.
Even though I know how to drive a manual transmission car, I've never ridden a motorcycle before, much less used a motorcycle-style clutch.
How long does it usually take to learn how to shift and use the clutch? Is it easier/harder than using one in a car?
arry
PostPosted: 12:52 - 16 Aug 2021    Post subject: Reply with quote
Depends on whether you're..... umm..... challenged in the mental department.
It's no different in terms of difficulty, just different in terms of application. Clearly, you are going to have to do a bit of learning on the muscle memory but once the controls of the bike become second nature, you'll find it easy. How long that takes - who knows; you're the only defining factor.
PostPosted: 12:58 - 16 Aug 2021    Post subject: Reply with quote
Much easier but it'll take a while to get the muscle memory.
The main difference is most motorcycles have a wet, multi plate clutch where cars have a single, dry plate clutch.
The upshot is that you can slip a motorcycle clutch a lot in a way that would damage/wear out a car one. So when you're riding slowly, you don't need to let it all the way out, you can hold it on the bite point and let that pull you along, controlling the speed with the rear brake. This can take a bit of getting used to.
They also have a sequential gearbox so there's a lot less to think about in that regard.
They'll take care of this in the lessons. The usual exercise is repeatedly getting the bike moving forwards then stopping again using the rear brake until you've got the hang of it. Then doing slow manouvers round cones etc. It's all a balance betweenn clutch, throttle and brake.
JohanTheAndro...
PostPosted: 13:17 - 16 Aug 2021    Post subject: Reply with quote
Laughing Well, in that case, I think you'll be happy to hear that I'm certainly not "challenged in the mental department."
Evil Hans
PostPosted: 13:58 - 16 Aug 2021    Post subject: Reply with quote
It was a long time ago now, but it took me about 10 minutes. You'll be fine.
RhynoCZ
PostPosted: 14:57 - 16 Aug 2021    Post subject: Reply with quote
It all depends on what you want to achieve. I could operate the cluch of a Jawa 21 (50cc, two stroke, 3 speed gearbox) right away. Taking off on big bikes is an intimidation game at first for all the beginers though. You have to understand what the clutch bite point is and how to controll it and the best way how to get it right is to practice.
Different bikes also have different aproach, just like cars, but the goal is always the same, find the clutch bite point ane controll it accordingly. Once you get going, shifting gears is easier than you'd think.
Prawny
PostPosted: 15:44 - 16 Aug 2021    Post subject: Reply with quote
I was in the same situation as you when I did my CBT, it blew me away at how easy it was. Absolutely no bother at all.
I did my CBT and then didn’t ride another manual bike for 2 years, did my DAS in the last month my CBT was valid and jumped straight back onto a manual bike with zero issues.
You’ll be fine.
Yamaha Vity 125 (gone) Kawasaki ER6N(dead) 2022 Royal Enfield Meteor 350 (nicked) 2003 DL1000 V Strom
Nobby the Bastard
Harley Gaydar
PostPosted: 15:49 - 16 Aug 2021    Post subject: Reply with quote
You're more likely to spend more time trying to get used to the back brake than the clutch.
My experiences of first riding bikes were that pulling away and changing gear was fine with the clutch but every time I tried to stop i forgot that my left hand was a clutch and so reverted to pedal bike thinking and treated them both as brakes.
Easy-X
PostPosted: 16:31 - 16 Aug 2021    Post subject: Reply with quote
Ignoring old British bikes for a moment I think it helps that the same side of the brain is handling the gears. Left hand/foot > left foot/hand. This obviously doesn't apply to grubby foreigners that drive on the wrong side of the road... might be why Americans like auto-boxes due to the mental confusion Laughing
PostPosted: 16:48 - 16 Aug 2021    Post subject: Reply with quote
What most people forget is that to slow down, the first thing you do is close the throttle. It's easy on a car because you have to take your foot off the throttle to push the brake. You can brake and pull the clutch on a motorcycle with the throttle still open which invariably leads you you stopping and redlining the engine at the same time until you get used to it.
Norts1531
PostPosted: 18:25 - 21 Sep 2021    Post subject: Reply with quote
If you can already drive a car then you already know what the concept of using a clutch is. Remember, you fingers are used for fine motor skills whereas your feet are not. If you can work a clutch with your foot, you'll have no problems when using your fingers.
Is it beer 'o clock yet?
Kawasaki Jimbo
PostPosted: 19:35 - 21 Sep 2021    Post subject: Reply with quote
It’s very hard. We’re all geniuses.
Keithy
PostPosted: 20:31 - 21 Sep 2021    Post subject: Reply with quote
This lot ^^^ might be smart, I really struggled.
30+ years of ‘car brain’ and I could not get used to the revs required or the lack of torque. Very much used to gently letting out the clutch with close to no additional gas. That stalls a bike every time. Hated the 2k of revs required of a tiddly 125 and it felt really alien.
You will, of course, get used to it. Thumbs Up
BRUN
PostPosted: 12:11 - 22 Sep 2021    Post subject: Reply with quote
you will be fine, I did my CBT at 38 years old having never been on a bike before in my life, before I did it I thought it would be the gears would be the thing I couldnt do, and even the start of the CBT I didnt really enjoy, but once out on the road it just all comes together and I could then understand why people have bikes
blurredman
PostPosted: 12:46 - 22 Sep 2021    Post subject: Reply with quote
I did my cbt on an auto 125cc on purpose,
Then bought a CG125 and learnt to ride with the clutch on my own, and in my own time. It did help that I already knew how to drive a manual car, anyway. I barely needed to bother going to the car park I was destined for to practice, because by the time I got there- I knew it.
A100man
PostPosted: 13:30 - 22 Sep 2021    Post subject: Reply with quote
.really hard.
Some members have had to buy scooters because of it Laughing
Nobby the Bastard
Harley Gaydar
PostPosted: 16:34 - 22 Sep 2021    Post subject: Reply with quote
I found it much harder to learn how to drive a clitoris but i persevered and eventually she sorted herself out.
PostPosted: 19:10 - 22 Sep 2021    Post subject: Reply with quote
Dry or wet clitoris?
I find the dry one's can snatch a tad when hot.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:45 - 22 Sep 2021    Post subject: Reply with quote
I do know that if you are too cack handed then you'll be pitched off.
PostPosted: 19:55 - 22 Sep 2021    Post subject: Reply with quote
Thanks...you've saved me from certain chagrin.
The last post was made 4 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 108.41 Kb
