| photoman |
 photoman Two Stroke Sniffer
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| photoman |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 14:40 - 21 Aug 2021 Post subject: |
I'm currently doing a lot of corroded and rusty nut/stud work with mixed results.
I did buy an Erbauer nut remover from Screwfix to remove a corroded
exhaust nut and to be fair it gripped well and remove the nut.
Unfortunately the nut was so rusted on it sheared the stud off
a PITA, but that happens sometimes.
Welding a nut on the remaining stud was a bust too as it sheared of flush with the head on the next attempt
Bollerx!
In the end I had to drill it out and helicoil it.
As above, I'd start with Plus Gas/ACF50 etc you might be lucky
other wise you might have to go down the route I did
Here's the nut whipper outer thingy
https://www.screwfix.com/p/erbauer-bolt-nut-remover-set-6-pcs/6083d
Incidentally, I never fit new exhaust studs mega tight
just lashings and lashings of copperslip and nip them up
I'd rather screw a new stud in than go through all the arseache above
Incidentally 2:
Stainless and ally will be more subject to volcanic corruption*
than carbon steel and and ally but I find copperslip helps alleviate this
* some scientific mumbo jumbo ____________________ bikers smell of wee |
| photoman |
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
| droog |
 droog Spanner Monkey
 Posted: 16:57 - 22 Aug 2021 Post subject: |
I had to deal with a snapped and seized exhaust stud when I was removing the header pipes off my old Hiornet.
I'll recount my experience as it might be of some use to you in getting your exhaust stud out.
I tried using a stud extractor tool but it didn't grip the stud sufficiently to get it turning, after numerous attempts the extractor tool just slipped around the stud when applying serious leverage. I have had success with these extractor tools on other seized bolts but not in this case.
Luckily there was enough of the snapped stud left poking out of the engine block for me to cut a notch in the end with a metal hacksaw. I then used a combination of Plusgas, an impact driver and hammer (with a screwdiriver bit fitted to the impact driver for the slot I cut into the top of the stud) and a propane/butane torch to heat up the stud.
After squirting the stud with some Plusgas and heating it up with the torch, I hit it a few times with the impact driver and finally got it turning. It came out of the block with no damage to the threads (so luckily no need to helicoil the block etc).
I'm just a DIY home mechanic on a learning curve, so naturally I was really pleased with myself and took some pics to commemorate the event (see below).
Stud in the block (this pic was taken after I got it turning - hence the shiny screw threads on the stud)
https://i.ibb.co/bH2VRtF/1.jpg
Engine block, propane torch and impact driver
https://i.ibb.co/ccBKmfy/3.jpg
The extracted stud showing the slot I cut in the top for the impact driver
https://i.ibb.co/Qpx0nYV/2.jpg |
| Tdibs |
 Tdibs Traffic Copper
| WD Forte |
| photoman |
| droog |
| droog |
| photoman |
| Easy-X |
 Easy-X Super Spammer
 Posted: 00:38 - 23 Aug 2021 Post subject: |
I'd be curious as to the physics chemistry occurring in the classic stuck bolt (or stud in this case.) In this specific scenario it's steel stud versus alloy head...
Is it the rust creeping down the thread of the stud or alloy corrosion having the biggest impact? Why use steel nuts on steel studs? Surely a recipe for disaster given on most bikes these fixings are exposed to water/dirt/salt spray  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| droog |
| droog |
| Easy-X |
 Posted: 10:34 - 23 Aug 2021 Post subject: |
That's one vote for alloy corrosion If copper slip on the threads (or will any old grease do?) is so helpful how come it's not done on every bike from the factory?! It's not a torque imperative area as compared to say head bolts  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| droog |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| photoman |
| Tdibs |
| photoman |
| WD Forte |
 Posted: 16:02 - 23 Aug 2021 Post subject: |
| Droog wrote: | I had to deal with a snapped and seized exhaust stud when I was removing the header pipes off my old Hiornet.
Well done you mate
I've never had any luck with impact drivers probably cos I'm a bit impatient and ham fisted at times.
If it was me doing that I'd probably have shattered that stud and had an ugly jagged remnant to deal with then burst into tears and flounced off  ____________________ bikers smell of wee |
| droog |
| WD Forte |
The last post was made 5 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
