Sudden engine noise
dennymc123
PostPosted: 15:28 - 27 Aug 2021    Post subject: Sudden engine noise Reply with quote
01 GSXR 750
Engine started making a rapid ticking noise on the way home from work, then before I got home I had power loss, a bit of lurching and a more metallic smashing sound, once the noise started I had to ride for approx 2 minutes longer before I was able to stop and push it.
See the attached link to YouTube.
Any help would be appreciated.
Thanks
https://youtube.com/shorts/oQh_g70O1UY?feature=share
S mcginn
Nobby the Bastard
Harley Gaydar
PostPosted: 15:53 - 27 Aug 2021    Post subject: Reply with quote
That sounds like the big end has gone.
Shell bearing.
Triumph Sprint ST 1050
Skudd
PostPosted: 15:54 - 27 Aug 2021    Post subject: Reply with quote
Sounds terminal.
WD Forte
PostPosted: 16:13 - 27 Aug 2021    Post subject: Reply with quote
Ouch!
Was sir caning the arse off it prior to the nasty sound?
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 16:22 - 27 Aug 2021    Post subject: Reply with quote
WD Forte wrote:
Ouch!
Sir was ragging the tits off the exup valdes cause some cunt was blocking the gap between two queues when it started to make the same sort of noise, yes...
virus
PostPosted: 16:46 - 27 Aug 2021    Post subject: Reply with quote
R.I.P big end bearing Laughing
own: 81 xs1100g...
dennymc123
PostPosted: 19:38 - 27 Aug 2021    Post subject: Reply with quote
Pretty much what I was expecting to hear, oh well.
Thanks for the replies
Yes I was tearing along before it happened Sad
S mcginn
MCN
PostPosted: 04:42 - 28 Aug 2021    Post subject: Reply with quote
Terminal Diesel Knock.
'Usually' big ends fail due to lack of lubrication.
Not enough, old lube or thinned out due to heat or dilution.
Heat from loss of cooling.
Thinning from heat or fuel dilution.
Ragging shouldn't kill an engine in the short term but if the engine is treated like shite then results speak for them self.
to v or not to v
PostPosted: 07:29 - 28 Aug 2021    Post subject: Reply with quote
rotten luck mate. i often hear how indestructible Gixxer engines are Crying or Very sad
Moto Guzzi V7.
Nobby the Bastard
Harley Gaydar
PostPosted: 08:51 - 28 Aug 2021    Post subject: Reply with quote
Stolen from skudd.
https://www.bikechatforums.com/files/240865804_10158798404319790_1488319400635170858_n.jpg
sickpup
Old Timer
PostPosted: 08:24 - 29 Aug 2021    Post subject: Reply with quote
Does it have a manual CCT on it?
Fizzer Thou
PostPosted: 21:22 - 30 Aug 2021    Post subject: Reply with quote
That sounds more like a little end Neutral
Heard it often enough on two-strokes Confused
Always have a 'Plan B'
The last post was made 5 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 71.01 Kb
