is brake disc size limited by grip?
White Noise
Mr Dudwee
PostPosted: 01:02 - 07 Apr 2005    Post subject: is brake disc size limited by grip? Reply with quote
I have just been thinking about this and wonder if anyone has any answers.
It is pretty straight forward that the bigger diameter disc that you have on your brakes the more stopping power you have, due to having more material on the disc to grip per rotation of the wheel, my question is there a limit to the diameter of discs other that the diameter of the wheel? does having larger disc's increase the chances of locking up due to the fact that they will easily overcome the grip of the tyre.
WN
cagiva gezzer
PostPosted: 01:05 - 07 Apr 2005    Post subject: Reply with quote
Looking at it the wrong way. Bigger discs have more stopping power due to having more leaverage on the wheel.
Mr.Everready
PostPosted: 01:06 - 07 Apr 2005    Post subject: Reply with quote
The Buells have rim mounted disks.
Dont know if theyre any better than normal.
White Noise
Mr Dudwee
PostPosted: 01:08 - 07 Apr 2005    Post subject: Reply with quote
Yeah thats what i mean but there is also more disc to grip onto per rotation of the wheel. my question was real is there a point where too much stopping power is bad as it can easily lock the wheel?
WN
haGGard
PostPosted: 01:12 - 07 Apr 2005    Post subject: Reply with quote
Im making a complete guess here, but i think the size of the front disk varies depending on the Power/Weight of the bike. For example, if you fit a massive disk brake to a scooter, it would stop if quick, but there is a much higher chance of locking up/doing accidental stoppies? Confused I guess if you fit a disk that it too small, braking distances will be increased, especially if the bike is heavy, and there will be a greater chance of warping the disk as it will be under greater stress...
I think you have to find a decent comprimise between too big, and too small.
^^Probably all wrong but as i said, i just guessing/assuming Razz
chaff mans random tingz on loot Razz
"Why dont you go and weld your face to a moving train, you sack of pus" - tobyr
"ROFL MY TOFFLE I AM TEH 1337 SPELLING MISTAKE FINDER!" - BikerBen
PostPosted: 01:19 - 07 Apr 2005    Post subject: Reply with quote
Main reason for larger disks is a larger surface area to disapate heat more quickly.
paulyzf600
PostPosted: 01:29 - 07 Apr 2005    Post subject: Reply with quote
There would'nt be more material contact unless the calipers and pads are bigger like said above it's down to more leverage.
When I modded cars a few years ago I put bigger disc's on the front end and the stopping power at lower speeds was more or less the same but higher speeds the stopping power was 100% better but yes it was easier to lock the front of the car up as the brakes don't need to work harder to stop the wheel.
Also as Keith said bigger disk's help for better heat transfer.
Yamaha YZF600 Thundercat
Kram
PostPosted: 02:01 - 07 Apr 2005    Post subject: Reply with quote
i rode an XJR400 for about a week, with racing discs / calipers / pads on the front end....
it was hell to stop. move the lever [---] < that far, the back wheel was off the ground (at speed)
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
Frost
PostPosted: 02:22 - 07 Apr 2005    Post subject: Reply with quote
It's all about the setup of the bike. The designers set the calipers, and levers up so that you have control aswell as stopping power.
for example bikes with bigger discs and bigger pads normally have more pitons in the calipers to ditribute the fluid pushed down to them more. this means that a big lever movement results in a smaller movement at the pads than normal, giving you better control. Bikes that have better braking systems also tend to have grippyer tyres to help stop sheels from locking.
If engineers wanted to make brakes which would lock the wheel with zero effort, then they could. What they want to make is controlable systems that allow you to stop as fast as possible without locking the wheel.
Retro-Man
PostPosted: 10:09 - 07 Apr 2005    Post subject: Reply with quote
Keiths right, think back to your old physics teacher.
Energy can not be consumed it can only be transferred, the forward momentum of your bike has an energy value to it.
the calorific value of the fuel is transferred into forward momentum energy by your engine, when braking the forward momemtum energy or velocity is transferred in to heat energy, the quicker the disc can dissipate heat by means of braking surface area the quicker the brake can turn that motion energy in to heat energy and hence you stop.
although disc size is only one factor so there is a limit to what having bigger discs can do for your braking.
https://domharnessphotography.webs.com
PostPosted: 11:39 - 07 Apr 2005    Post subject: Reply with quote
Another point being that a larger disk will pass through the pads more quickly (the wheel is still rotating at the same speed, but being further out the disk has a larger circumferance to go through in the same time) so will generate more friction.
The last post was made 21 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 72.1 Kb
