| thx1138 |
 thx1138 World Chat Champion
| Ste |
 Ste Not Work Safe
 Posted: 13:16 - 08 Sep 2021 Post subject: |
Get a better pump that's less bulky.  |
| thx1138 |
 Posted: 13:18 - 08 Sep 2021 Post subject: |
I just spent my money on a swanky new track pump  |
| Ste |
 Ste Not Work Safe
| ThunderGuts |
 ThunderGuts World Chat Champion
| Easy-X |
 Easy-X Super Spammer
 Posted: 20:41 - 08 Sep 2021 Post subject: |
This is why I like mountain bikes: Schrader valves or GTFO. If someone would care to inform me of the the superiority of Presta valves I'm all ears  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
| Nobby the Bastard |
| Ste |
 Ste Not Work Safe
 Posted: 00:02 - 09 Sep 2021 Post subject: |
They are the boring reasons about stuff like presta valves are slightly easier to inflate, having a lockring on the valve is useful, they're better at high pressures than schrader valves and other such marginal differences but the real reason is that presta valves need a smaller hole drilled in the rim than schrader valves do.
I like Lezyne pumps for anything when a track pump can't be used. But as good as they are, tubeless is still preferable.  |
| mentalboy |
 mentalboy World Chat Champion
| Easy-X |
| Ste |
 Ste Not Work Safe
| Nobby the Bastard |
| weasley |
 weasley World Chat Champion
| stinkwheel |
 Posted: 18:09 - 09 Sep 2021 Post subject: |
Could you threadlock the core in? I can't remember EVER having a need to remove a presta valve core. in fact, I wasn't even aware they were removable. I think some of them aren't. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 19:34 - 09 Sep 2021 Post subject: |
Last year, I got one of those mini pumps from Zefal with the lever mechanism and it works great. It fits in my ''tool bottle'' and can do 7 BAR (101.5 PSI), which is more than enough for my road bike.
I also carry one of those presta to schrader valve adaptors in my wallet, so I can use schrader valve pumps when needed. I got it manybe 20 years ago and still have it. Before I got the mini pump, this adaptor saved me many times and I still use it everynow and then. With this you can use whatever air pump.
This thing.
https://i.ebayimg.com/images/g/MDoAAOSw-YBXGx1E/s-l400.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| thx1138 |
| Ste |
 Ste Not Work Safe
 Posted: 22:53 - 09 Sep 2021 Post subject: |
You could buy more inner tubes or you could go tubeless.  |
| thx1138 |
| Ste |
 Ste Not Work Safe
 Posted: 12:59 - 10 Sep 2021 Post subject: |
You've got to get a fairly big puncture for the sealant to not immediately seal the hole!! But if are unlucky enough to get a puncture that's too big for the sealant then you've got several options.
You can use a tubeless repair kit thing that's similar to what would be used for motorcycle tyres. https://muc-off.com/products/puncture-plug-repair-kit
You can spend a bit more on that repair kit and get one that fits inside the ends of your handlebars. https://muc-off.com/products/stealth-tubeless-puncture-plug
Or if you're wanting to repair it quickly then something along the lines of this is much faster to use. https://www.notubes.com/dart With one of those and CO2 cartridges to reinflate the tyre, you should be going again before you even know it.
If you end up having to put a tube in then it's slightly messy because of the sealant in the tyre but they're all biodegradable or similar so the mess isn't going to do anything bad.
Once you've run tubeless, you won't go back to running tubes.
The fact your rims are drilled for schrader valves is a bit of a problem though.  |
| RhynoCZ |
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 15:35 - 10 Sep 2021 Post subject: |
| Ste wrote: | Once you've run tubeless, you won't go back to running tubes |
I have, and I have.
Bike was tubeless when I got it. Had slow punctures. One went flat and it was a PITA to reinflate as I don't have a compressor. Horrible gunk inside the tyre too. Stuck tubes in since I had them anyway. No problems since.
Don't really understand the advantage of tubeless unless you're racing and you want to save a few grams. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| Ste |
 Ste Not Work Safe
 Posted: 15:53 - 10 Sep 2021 Post subject: |
| RhynoCZ wrote: | How often do you replace the sealant inside the tyres? |
Running the standard Stans sealant I top it up about every six months if using the amount of sealant the bottle says to use for your tyre size or about every twelve months if you're more generous with how much sealant you put in.
How often the sealant needs topping up depends on which sealant you're using; you can get ones which are good for the life of the tyre and you can get ones which need topping up every few months.
| Zen Dog wrote: | I have, and I have.
Don't really understand the advantage of tubeless unless you're racing and you want to save a few grams. |
Over time tubeless tyres do lose pressure. You don't need a compressor, you just need a half decent track pump.
You don't get slow punctures with tubeless because as the wheel is spinning the sealant seals the puncture. If the previous owner hadn't put the tape on properly then that could explain the 'slow puncture'.
The advantages of tubeless are that you're far less likely to ever get a puncture.
It's a bit of an old video but this shows how well the sealants work. https://www.youtube.com/watch?v=FTlZvOVG8zs |
| stinkwheel |
The last post was made 5 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
