Fast charging wall sockets.
recman
PostPosted: 17:25 - 10 Sep 2021    Post subject: Fast charging wall sockets. Reply with quote
Any of you nerds use them?
I'd quite like to rid myself of the Samsung fast charger but I'm not entirely sure what socket to go for to get the same results.
xX-Alex-Xx
PostPosted: 18:36 - 10 Sep 2021    Post subject: Reply with quote
I’ve not seen much/any difference between using a Samsung fast charger plug and a “normal” higher output charger in terms of speed. A regular socket with higher ampage USB sockets should be ok.
https://www.screwfix.com/p/lap-13a-2-gang-sp-switched-socket-3-1a-2-outlet-type-a-usb-charger-white/4087p
DILLIGAF
to v or not to v
PostPosted: 19:30 - 10 Sep 2021    Post subject: Reply with quote
you need a deep recessed back box for the sockets with built in usb chargers.
Moto Guzzi V7.
t121anf
PostPosted: 21:59 - 10 Sep 2021    Post subject: Reply with quote
No you don’t, even the one linked above states 25mm which is the standard back box.
sickpup
Old Timer
PostPosted: 12:37 - 11 Sep 2021    Post subject: Reply with quote
I've got a load of these installed and they work well.
Be aware that the 3.1amp output is shared between BOTH USB sockets so if you want a quick charge only plug one item in, they are also always live.
At the moment you can buy 2 for £15 so kep that in mind when you buy, they often have these deals.
xX-Alex-Xx
PostPosted: 15:23 - 11 Sep 2021    Post subject: Reply with quote
Agreed, almost all of them quote a combined current total.
And they do fit in a standard box. I have some.
DILLIGAF
to v or not to v
PostPosted: 21:27 - 11 Sep 2021    Post subject: Reply with quote
the back box i fitted one to was smaller than that. maybe because its an old house?
Moto Guzzi V7.
bugeye_bob
PostPosted: 23:28 - 11 Sep 2021    Post subject: Reply with quote
If you have a samsung as mentioned USB C charges quicker than the old USB A to USB C leads, so maybe a socket with usb C on would be a faster charge for your device.
RE Back boxes, for 30 + years they have always been a 25mm box, with a deeper 32mm being available, socket boxes were never as shallow as a switch box . .
As said a standard backbox will take these USB/mains combined sockets.
grr666
PostPosted: 00:39 - 12 Sep 2021    Post subject: Reply with quote
Oh no you don't. The one's linked fit in a 25mm backbox. I have 4 of them in my house.
recman
PostPosted: 09:14 - 12 Sep 2021    Post subject: Reply with quote
Can't beat real world answers. Much appreciated chaps.
Im-a-Ridah
PostPosted: 10:38 - 19 Sep 2021    Post subject: Reply with quote
A 3A wall charger will be much slower than a QuickCharge charger. QuickCharge gives actually fast charging but uses higher voltages to do so.
https://www.qualcomm.com/products/features/quick-charge
xX-Alex-Xx
PostPosted: 13:36 - 19 Sep 2021    Post subject: Reply with quote
Literally never seen a difference on all my Samsungs. YMMV.
DILLIGAF
recman
PostPosted: 15:02 - 19 Sep 2021    Post subject: Reply with quote
Does your Samsung indicate that it's actually fast charging?
xX-Alex-Xx
PostPosted: 16:53 - 19 Sep 2021    Post subject: Reply with quote
Yeah, even gives identical times to fully charged. Even tried it across 3 different phones when I've upgraded. Official Samsung fast charger vs regular (high output) USB charger showed identical times to full.
DILLIGAF
The last post was made 4 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 82.58 Kb
