Retro Reverse Drive
Would you like one, and what would your criterior be.
Yes, only if it met my criterior
15%
 15%  [ 3 ]
Probably Not
52%
 52%  [ 10 ]
Not a bloody chance
31%
 31%  [ 6 ]
Total Votes : 19
GettinBetter
PostPosted: 08:37 - 11 Sep 2021    Post subject: Retro Reverse Drive Reply with quote
I daresay many more bikes may have them in the future, especially electric bikes, I'm pretty sure they can add a circuit in the control panel to handle reverse.
But what about now, would you like one?
I'm pretty sure the diehards will say never, but then they did when electric starts came out.
I find pushing back out of a confined space uphill a struggle, and what often doesn't look much when you go in, is different when you try to push out, especially if the ground is uneven or worse gravel, and you have a few bumps to get over.
Anyway just thought I'd ask.
I'd only have one if:
    1. It was fairly sensibly priced.
    2. It was a simple bolt on option.
    3. Detected you were in neutral.
    4. Didn't engage on the tyres in any way.
    5. Had a friction clutch built in.
    6. Had a variable speed knob.
Zen Dog
PostPosted: 09:32 - 11 Sep 2021    Post subject: Re: Retro Reverse Drive Reply with quote
This is the only situation when I think a reverse gear would be beneficial really, and it can usually be mitigated with some forward planning (i.e. reverse downhill into the space, so you're facing uphill/forward when leaving). So I just don't think there's a massive need for them.
Makes more sense on really big bikes. Goldwings have had a reverse gear for donkeys years. And I remember my dad telling me you could get the reverse gear fitted to the F6C Valkyrie (which has the Goldwing engine). Beyond that, I think it's going to be pretty much impossible to design a universal fit bolt on reverse for any bike.
Easy-X
PostPosted: 22:35 - 11 Sep 2021    Post subject: Reply with quote
Trying to think of the bike (might not be a bike, some small vehicle though) that had an electric motor for a reverse Thinking
PostPosted: 23:25 - 11 Sep 2021    Post subject: Reply with quote
That's the Goldwing. Uses the starter motor to power the bike backwards. Engine has to be running, in neutral, engage reverse, press starter button and back you go.
A godsend on a bike that size.
trevor saxe-coburg-gotha
PostPosted: 05:34 - 12 Sep 2021    Post subject: Reply with quote
Wouldn't want to add weight but w/ the other six provisos yeah okay - would help on gravel car parks of which there are a few around here.
GettinBetter
PostPosted: 09:50 - 12 Sep 2021    Post subject: Reply with quote
I was thinking something along these lines...
Fitted forward of the rear sprocket, initial engagement by a lever up front which swings it from stowed position to down under the chain, then a button on the handlbars (ideally the starter button) turns on the motor & actuator.
The actuator moves the spring centreline to the opposite side of the clamp bracket causing the assembly to rotate and engage the drive gear. As the drive gear rotates it causes the assembly to rotate further forcing the gear to engage more.
Estimated drive gear speed to be in the order of 0.5 to 1.0 RPM.
PostPosted: 12:41 - 12 Sep 2021    Post subject: Reply with quote
No point, I've survived fine without for 23 years. If I physically get the point where I can't manhandle a bike out of a space then I probably should stop riding.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:16 - 12 Sep 2021    Post subject: Reply with quote
Pointless idea.
Triumph Sprint ST 1050
PostPosted: 14:00 - 12 Sep 2021    Post subject: Reply with quote
If you're struggling to push it backward uphill out of a parking space just plan ahead and roll the bike backward into the parking space. Then you can ride out of it, plus there's no fear of it rolling forwards off the stand.
GettinBetter
PostPosted: 14:09 - 12 Sep 2021    Post subject: Reply with quote
Pete. wrote:
.... plus there's no fear of it rolling forwards off the stand.
That's what I needed.. Thumbs Up Thumbs Up
As a lifelong manufacturing engineer, everything can be made easier with a tool/device, but one has to be careful of finding problems that don't really exist.
Concept scrapped.
redeem ouzzer
PostPosted: 18:47 - 13 Sep 2021    Post subject: Reply with quote
Yay cause we all want our bikes heavier and more complex Rolling Eyes
Be a REAL MAN!
slowasyoulike
PostPosted: 18:07 - 20 Sep 2021    Post subject: Reply with quote
No, because it will just encourage feeble, daft old c**** to buy bikes that are too big and too heavy for them. Like the feeble, daft old c*** who dropped his gigantic BMW in taking it off the centre stand - straight onto my bike, causing significant damage to it. As I said to him at the time, a mobility scooter would have been far more appropriate to his physicality and level of ability.
PostPosted: 18:35 - 20 Sep 2021    Post subject: Reply with quote
OOOOOOOhhhhhhhh!!!!!!!!!!!!!!!!!! Get you darling.
to v or not to v
PostPosted: 19:23 - 20 Sep 2021    Post subject: Reply with quote
silence feeble old person Razz
Moto Guzzi V7.
slowasyoulike
PostPosted: 19:55 - 20 Sep 2021    Post subject: Reply with quote
Sorry if I've touched a nerve there M8.
xX-Alex-Xx
PostPosted: 07:58 - 21 Sep 2021    Post subject: Reply with quote
It'd make sense on an electric bike, but only if it was limited to 1mph or so. Would I ever use it? Highly unlikely, I don't think I've ever struggled to push a bike backwards (uphill) more than a few times in my life. I'd rather the "reverse" button be used for a flamethrower or something similar instead.
All of this. I never park forwards in a spot anyway (car or motorcycle).
Pretty amazing how many people find it "too hard" to reverse into a spot (esp in a car) but will take more time trying to drive into a tight spot forwards, and then struggle to reverse out with visibility of almost zero.
DILLIGAF
The last post was made 5 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.27 - MySQL Queries: 15 - Page Size: 93.48 Kb
