CB750 wallow on high speed sweepers or bumps
SirFallalot
PostPosted: 22:14 - 27 Sep 2021    Post subject: CB750 wallow on high speed sweepers or bumps Reply with quote
On my 96 CB750...
On high speed turns (100+) the bike tends to develop what I believe is called wallow,wherim the rear end seems to lean up and down, although sometimes looking at the front end it looks it it's the culprit weaving left and right slightly.
First I thought it was the square tyres and old shocks, now replaced with BT32 and mid range YSS with default preload and rebound in the center. Forks are from a CBR F3 dropped 1cm as they were longer than stock, the bike turns quite sharply and it was a big improvement compared to stock.
At the same time I refit the useless screen due to a cross country trip.
The wallow is still there, either when leaning at high speeds, or at lower speeds (80-90) if a slight bump is hit (those shallow things going across motorways for e.g.).
It's not an uncontrollable tank slapper, but it's not confidence inspiring and a bit butt clenching. I am going to try removing the screen before my next run but do you recon it's just a limitation of the bike/twin shock, bad setup or the screen?
Lexmoto Valiant 125; 94 CB400; 96 CB750F2; 81 CB750 (restoring, lol not gonna happen); 2001 ZX9R(It's about to go :c); 2012 R1200R; 2015 R1200RS
Shaft
PostPosted: 23:39 - 27 Sep 2021    Post subject: Reply with quote
It's a 25 year old UJM, which was probably based on very similar underpinnings to your '81 CB, how good do you expect it to be?
It certainly won't be a patch on your Kwak, but it was never designed to be, it was meant to be a cheap allrounder and the passage of a quarter of a century won't have improved things.
If you want to go mad, replace every chassis bearing and bush you can think of, but you will still be left with a relatively flexible frame and swing arm.
Or just live with it and enjoy the excitement of high speed wobbles, just like we all did back then.
jaffa90
PostPosted: 00:55 - 28 Sep 2021    Post subject: Reply with quote
I suggest,
https://funerals.reassured.co.uk/funeral-4?product_id=2&channel_id=3&advertiser_id=9497ff66-d65e-4275-8dc4-a5dce624b280&campaignid=2037998309&adgroupid=77348804815&creative=377949831986&keyword=funeral%20cover&matchtype=e&targetid=kwd-2710391916&gclid=Cj0KCQjw18WKBhCUARIsAFiW7Jx2zMA0oRbAXQosLjF1hM2HrnJjbukynVKnMHbxiiU1w59iaAG4HkkaAs4bEALw_wcB
MCN
PostPosted: 04:15 - 28 Sep 2021    Post subject: Reply with quote
Spension/Head Bearings/Shite tyres/Wallowed road.
SirFallalot
PostPosted: 09:21 - 28 Sep 2021    Post subject: Reply with quote
Ahah yeah that's the kind of answer I was looking for, I wanted to know if there's something that might need fixing, or if it's just a limitation of design, which is fine.It is quite exciting Laughing
to v or not to v
PostPosted: 19:32 - 28 Sep 2021    Post subject: Reply with quote
id try lifting the forks back up that 1cm, just to see how it affects the wobble.
Moto Guzzi V7.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:43 - 28 Sep 2021    Post subject: Reply with quote
I know that if you go under the bridge on the Keynsham bypass at 145 then the bike will pogo round the bend but that's because of the big dip in the road.
Triumph Sprint ST 1050
A100man
PostPosted: 19:47 - 28 Sep 2021    Post subject: Reply with quote
Recent MoT ? If not I'd check wheel bearings and S/A bushes..
mind you not sure how many 100mph corners I tackle these days..
redeem ouzzer
PostPosted: 20:36 - 28 Sep 2021    Post subject: Reply with quote
All steel framed bikes do this.
Be a REAL MAN!
stevo123
PostPosted: 12:39 - 29 Sep 2021    Post subject: Reply with quote
As mentioned already there will be some frame flex to blame. You could adjust rear rebound damping a bit higher and see if it helps you as well if you have luxury.
SirFallalot
PostPosted: 08:14 - 02 Oct 2021    Post subject: Reply with quote
Thanks for advice Very Happy
Mot a month ago, I had bearings checked too and no play.
I think removing the screen helped it, not sure if because it was applying pressure to the handlebars...or because without it I go much slower. B roads are much better but A and M, damn pain in the neck Laughing
sickpup
Old Timer
PostPosted: 10:55 - 04 Oct 2021    Post subject: Reply with quote
Was the springing and damping modified on the forks when fitted, I imagine the CB750 is a bit heavier?
If not this could be amplified by the rear end working correctly with the new tyres and YSS shock.
MCN
PostPosted: 18:05 - 04 Oct 2021    Post subject: Reply with quote
I had the use of a 1990s Suzuki 750 in South Africa.
Tons of grunt but hopeless in a corner.
Auld bikes were only made for straight roads I think.
Bru
PostPosted: 16:51 - 07 Oct 2021    Post subject: Reply with quote
My GPX600 makes its own bends, the twitchy little bastard.
SirFallalot
PostPosted: 23:34 - 10 Oct 2021    Post subject: Reply with quote
Yeah 30kg heavier, I thought the CBR forks would require new springs too, but after the conversion the forks became similar to my CB400 with aftermarket springs, my assumption was it had heavier springs in already.
Bhud
PostPosted: 01:50 - 11 Oct 2021    Post subject: Reply with quote
I think you will have to change that default setting on your new shocks. Do they have enough travel to be able to do their job, is the spring rate suitable and available to you, and what about rebound damping. Cornering at over 100mph is asking a lot. Dave Moss has a lot of material on this stuff. Personally, I would just play with it, set preload so there's 30-ish cm static sag, then see if there's an improvement 2 clicks in or 2 clicks out on the rebound adjuster(s). From there, fine tune
SirFallalot
PostPosted: 08:59 - 11 Oct 2021    Post subject: Reply with quote
Thanks, the bike felt so much better than stock in the twisties that I didn't bother with settings beyond def or sag Rolling Eyes , I'll try measuring it and playing with the settings a bit next time I take it out Very Happy
chriscrane
PostPosted: 13:46 - 23 Oct 2021    Post subject: Reply with quote
I suggest https://www.quotemeless.co.uk/funeral-plans
c crane
jaffa90
PostPosted: 17:31 - 23 Oct 2021    Post subject: Reply with quote
chriscrane wrote:
Copy cat Rolling Eyes Read the script / replies.
Copycat73
PostPosted: 20:57 - 23 Oct 2021    Post subject: Reply with quote
been there done that ..... took the honda to some one who knows what he is doin.. cost £50 .. but stopped it wallowing round corners and sweepers with undulations...
caveat emptor
xX-Alex-Xx
PostPosted: 21:27 - 23 Oct 2021    Post subject: Reply with quote
jaffa90 wrote:
It takes a lot of reading to get to the third post Laughing
DILLIGAF
The last post was made 4 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 110.71 Kb
