Zontes tiger non starter
Sldcb1992
PostPosted: 13:00 - 14 Oct 2021    Post subject: Zontes tiger non starter Reply with quote
Hello guys, I have question and was wondering if anyone here can help because I have no more ideas on how to solve my problem. I bought a 125 tiger last month, after 6 rides I had a bit of an incident where I had to swerve and the bike went down, I'm pretty sure it never actually hit the ground as I managed to hold it up on my leg. The bike cut out and after many attempts I did get it started and rode it home. Since then it will not start on the electric start button. It will bump start and I bought a kick start for it and it can kick over, but I want to solve the problem before I take it out again. The battery is fine and I see no obvious damage elsewhere. I recently found a wire which is composed of 6 smaller wires and 5 of them look like they have snapped (I will attach a photo), it goes from the back of the speedo and meets another connector under the tank and was thinking that could be the issue?
I would appreciate any help
Thank you
Nobby the Bastard
Harley Gaydar
PostPosted: 13:18 - 14 Oct 2021    Post subject: Reply with quote
Just connect the wires back together.
Obviously make sure you match the colours and use proper connectors or at least leccy tape so they don't short against each other.
TBH they look cut. Is mummy annoyed that you bought a bike?
Triumph Sprint ST 1050
PostPosted: 13:25 - 14 Oct 2021    Post subject: Reply with quote
If you zoom in they look ripped Nobby, not cut.
As said, just connect back together. Use crimps, bullets or spades. Once tested tape up and forget.
Triumph Trophy Launch Edition
Nobby the Bastard
Harley Gaydar
PostPosted: 14:06 - 14 Oct 2021    Post subject: Reply with quote
Thats what a breadknife would do.
It looks to be under the headlight so diffficult to rip by dropping the bike.
Sldcb1992
PostPosted: 15:02 - 14 Oct 2021    Post subject: Reply with quote
I was thinking bullet connectors originally, didnt know whether it was worth just replacing it completely. I will give it a go. Cheers for your help
WD Forte
PostPosted: 15:32 - 14 Oct 2021    Post subject: Reply with quote
Those wires didn't get cut by 'swerving'
Looks more like theft attempt damage to me
how do we know it not nicked nor nuffin?
bikers smell of wee
Sldcb1992
PostPosted: 15:36 - 14 Oct 2021    Post subject: Reply with quote
The guy who i bought it from handed over the registration docs, guessing thats proof enough??
A100man
PostPosted: 15:53 - 14 Oct 2021    Post subject: Reply with quote
Play nicely now Nobby Smile
doggone
PostPosted: 16:52 - 14 Oct 2021    Post subject: Reply with quote
If the electric start still worked after it was on its side the wires might have been yanked and only let go later unless there was a clumsy theft attempt as suggested.
Most bikes will cut out if on their side to avoid oil starvation to the motor, it's a tilt sensor and turning the ignition off and on again resets it.
You might also need to crank a while to get any air out of fuel line.
PostPosted: 19:17 - 14 Oct 2021    Post subject: Reply with quote
I very much doubt a Chinese 125 would have a tilt sensor. I just can't see them bothering. I've only had them on high end bikes though I suppose that might have changed now.
steve the grease
PostPosted: 19:29 - 14 Oct 2021    Post subject: Reply with quote
I'm going to go with a third option - not snapped- not cut but severely pinched , maybe in the lock stop which has crushed the cables until they have let go.
Sldcb1992
PostPosted: 19:35 - 14 Oct 2021    Post subject: Reply with quote
Cheers guys I appreciate the help. Was only hoping to keep it for 3 months until I had enough experience to do my das. Been off road for a month so not going to plan Thumbs Down
The last post was made 4 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 69.79 Kb
