Yamaha YBR Clutch Doesn't Bite
Haarp
PostPosted: 19:41 - 12 Oct 2021    Post subject: Yamaha YBR Clutch Doesn't Bite Reply with quote
I had to install a new clutch clamp, which meant taking the cable out of the lever to place it through the new clamp and back into the lever again. It was a little tricky and I did have to pull on the cable a bit to get enough slack.
Now what happens is with the engine on, the bike can go into gear without stalling with the clutch out. The back wheel spins quite fast as well. With the engine off and the clutch held in on 1st gear, I can just about move the back wheel but it's very stiff I don't know if this is an indicator of something. But the clutch does allow me to spin the wheel and when I let go the wheel locks again.
I've tightened and loosened the cable and found no discernable difference (although I can feel the tight/loosening of the cable), I've tried pushing the lever attached to the gearbox incase it wasn't falling back into it's usual position and was semi-disengaged.
Is it possible I damaged the clutch cable when trying to fit it back into the lever? Are they really that delicate?
jaffa90
PostPosted: 23:46 - 12 Oct 2021    Post subject: Reply with quote
Have you lost the free play at the hand lever and the actuator arm?
Haarp
PostPosted: 00:01 - 13 Oct 2021    Post subject: Reply with quote
No I don't believe so, I can feel the freeplay adjusting when I tighten or loosen so in that respect the cable doesn't feel ruined. However someone did bring up a good point, although I've tried to push the gearbox lever while the clutch was in maybe I haven't pushed hard enough to completely disengage the engine which would indicate a ruined cable if I can manage to do that. I going to try that tomorrow.
jaffa90
PostPosted: 00:39 - 13 Oct 2021    Post subject: Reply with quote
""""Now what happens is with the engine on, the bike can go into gear without stalling with the clutch out"""
This tells me that the clutch is disengaged all the time now, providing the rear wheel is on the ground.
Haarp
PostPosted: 14:04 - 13 Oct 2021    Post subject: Reply with quote
I've also noticed that with the clutch in and feeling tuned, if I use the throttle in 1st gear the back wheel spins faster like the gears are still working. This is using the centre stand.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:08 - 13 Oct 2021    Post subject: Reply with quote
There will always be a slight drag in the clutch (and I mean miniscule) with the clutch disengaged.
If you can hold the wheel in your had with the bike in gear, running and with the clutch disengaged there is no problem, it's normal.
Triumph Sprint ST 1050
doggone
PostPosted: 14:13 - 13 Oct 2021    Post subject: Reply with quote
You might expect to get a bit of drag like that normally if it's off the ground, especially with cold engine/oil.
Most likely the cable is damaged and simplest fix would be get another, or maybe what you fitted isn't really compatible. Even 1mm discrepancy in how much the cable is pulled will mess things up.
yen_powell
PostPosted: 16:44 - 13 Oct 2021    Post subject: Re: Yamaha YBR Clutch Doesn't Bite Reply with quote
Do you have a picture of the cable where it connects to the handlebar lever, one of the other end where it connects to the clutch arm or goes into the crank case and one of the central main adjuster? Just in case it's something obvious or simple and the cable is fine.
XT1200Z and a DR350 in bits
Haarp
PostPosted: 21:00 - 13 Oct 2021    Post subject: Reply with quote
I've read that the back wheel will spin on the centre stand. The main thing that concerns me is when I hold in the clutch and rev the throttle the back wheel spins even faster shouldn't it be the opposite or not be affected at all?
doggone
PostPosted: 21:35 - 13 Oct 2021    Post subject: Reply with quote
It would not be unusual to be able to build up momentum like that from a tiny bit of drag because the plates don't clear each other completely they are in oil which can be a bit sticky especially when cold.
This is why you often get that nasty clunk and shudder going from neutral to first.
If while it's spinning you can easily stop it with the rear brake (or even your hand - carefully) that's normal.
jaffa90
PostPosted: 00:32 - 14 Oct 2021    Post subject: Reply with quote
When are you going to take all the good advice and get on with it ?
Easy-X
PostPosted: 19:47 - 14 Oct 2021    Post subject: Reply with quote
Take the lever off and then you know the clutch should be disengaged entirely, perform your tests. Put the lever back on, test again... come back with the results of your experiments. For bonus points do a third test with the old lever.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:42 - 14 Oct 2021    Post subject: Reply with quote
Eh?
You pull the lever to disengage the clutch. No lever equals no disengagement.
The last post was made 4 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 76.67 Kb
