Derbi Terra 2009 electrics died
robives
PostPosted: 12:57 - 17 Oct 2021    Post subject: Derbi Terra 2009 electrics died Reply with quote
I came to my 2009 Derbi Terra after a visit to town, it started fine then when I moved the handlebars it died. Completely dead, nothing on the dash. I straightened the bars, the lights came back on, started then had exactly the same issue. Dead bike. After one more try the bike no longer comes on at all. It sounds to me like an electric fault - bad earth maybe but my problem is I just don’t know where to start trying to track down the problem. Any advice gratefully received!
steve the grease
PostPosted: 14:41 - 17 Oct 2021    Post subject: Reply with quote
Like bending a bit of metal backwards and forwards until it breaks, pretty much the same can happen with electrical wires.
The steering head area is a common place for breaks in wires as in moving the bars, the wires bend back and to.
The fattest wires being stiffer bend less well and are most likely to break. It sounds to me like the main wire to the ignition and lights has let go.
You will need a meter ( or a bulb and a couple of wires) and a wiring diagram would be a big help. Find where isn't getting an electrical supply and then you will have identified where the fault lies.
As a start I'd try the biggest wire going to the ignition switch .... it may well be red.
Having said all that , yeah it could be an earth lead, but the same principle applies
All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of.....
robives
PostPosted: 17:16 - 17 Oct 2021    Post subject: Thanks! Reply with quote
I took your advice, followed the wires back from the ignition, found a wire that had broken off a connecting block. I’ve had to remove the original block and replace it with a screwed terminal block but the bike is now working! Thanks!
ThatDippyTwat
PostPosted: 18:03 - 17 Oct 2021    Post subject: Reply with quote
All of these era bikes based on that Aprilia/Piaggio motor are useless in the leccy dept. I pulled my hair out with a Mulhacen before rewiring the thing from the ground up, then flogging the bastard thing. Went well when it wasn't fucking around though.
robives
PostPosted: 18:07 - 17 Oct 2021    Post subject: Reply with quote
Just gotta last till I’ve passed my direct access! Mod 1 week on Monday…
Easy-X
PostPosted: 23:54 - 17 Oct 2021    Post subject: Reply with quote
I wish you the best of luck Smile
steve the grease
PostPosted: 01:05 - 19 Oct 2021    Post subject: Reply with quote
Glad you got the bike fixed, best of luck with the test.....
xX-Alex-Xx
PostPosted: 08:58 - 19 Oct 2021    Post subject: Re: Thanks! Reply with quote
Those blocks aren't amazing for motorcycles (heat and vibration will work the screws loose). It'd be a good idea to replace it with a proper connector block.
Good to know you found the cause though - good luck with the test.
DILLIGAF
The last post was made 4 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 5 - MySQL Queries: 13 - Page Size: 54.67 Kb
