Car mobile phone mount that is secure?
Bike Chat Forums Index -> Dear Auntie BCF... via View Category
Ribenapigeon
PostPosted: 11:47 - 04 Nov 2021    Post subject: Car mobile phone mount that is secure? Reply with quote
Can anyone recommend a phone holder for a car dash or windscreen that actually stays securely fixed in place and is much cheapness.
I bought one from The Range but the damn thing just falls off the window or the dash. It has some sticky stuff nonsense which just doesn't actually stick and the supposed suction cup clearly doesn't pull enough suction unless on an absolutely flat surface.
Cheers.
Fat Angry Scotsman
PostPosted: 11:53 - 04 Nov 2021    Post subject: Reply with quote
Quite simply, I don't think a good-quality, low-cost screen mount exists.
This is what I am getting for in the car after the £20 Belkin one that I got has started to constantly fall off the windscreen in my car:
https://www.quadlockcase.co.uk/collections/shop-mounts/products/quad-lock-car-mount
Islander
PostPosted: 12:07 - 04 Nov 2021    Post subject: Reply with quote
Or replace the sticky pad with a decent quality 3M EHB double sided pad and thoroughly clean/degrease the surfaces before you stick it down...
Ribenapigeon
PostPosted: 13:08 - 04 Nov 2021    Post subject: Reply with quote
Looks like a good phone to holder mount but do you know if the suction cup works as well?
Ribenapigeon
PostPosted: 13:10 - 04 Nov 2021    Post subject: Reply with quote
That's a good idea and reminded me i have some of that 3m velcro type stuff. Just have to find out where ive stashed it though Laughing
PostPosted: 14:04 - 04 Nov 2021    Post subject: Reply with quote
I have a magnetic air vent mount that is solid, it stays in place and it is easy to remove the phone from. You need a phone case with a metal plate in it, but it works very well.
pepperami
PostPosted: 14:35 - 04 Nov 2021    Post subject: Reply with quote
Super glue your phone directly to the windscreen Shocked Thumbs Up
Once again the sage that is Pepperami provides the wisdom to solve the problem Thumbs Up .
You’re welcome Smile
Ribenapigeon
PostPosted: 15:10 - 04 Nov 2021    Post subject: Reply with quote
Too much hassle taking the windscreen out to do the job.
Ribenapigeon
PostPosted: 15:12 - 04 Nov 2021    Post subject: Reply with quote
Ive looked at those ones but they screw up the magnetometer in the phone.
PostPosted: 16:41 - 04 Nov 2021    Post subject: Reply with quote
The who?
My phone functions exactly the same when it's on the mount as when it's not. Either way you could still get a mechanical mount that fits to the air vent if you were worried.
MCN
PostPosted: 19:35 - 04 Nov 2021    Post subject: Reply with quote
Ram should have wot u want.
If you don't value the worth of the device you're holding then the pound shop will suffice.
The better tools use a flat disc of prastic that you stick to the dash using its VHB tape/similar sized disc.
Then the tool's sucker has something suitable to sook onto.
Some surfaces may be flat but a little porous so air facks up the sucker's vaccum.
(VHB can be removed using a hair drier/heat gun to soften the adhesive.)
PostPosted: 20:00 - 04 Nov 2021    Post subject: Reply with quote
I have this on my dash. The 3M pad is stuck solid.
https://www.amazon.co.uk/gp/product/B07XDYPG1V
Ribenapigeon
PostPosted: 20:09 - 04 Nov 2021    Post subject: Reply with quote
The device itself is well designed amd has wireless charging so im thinking hack off the sucker bit then fabricate a pad out of foamex and 3m it to the dash, either with 3m sticky pad or the 3m hook+eye pads.
Kawasaki Jimbo
PostPosted: 20:40 - 04 Nov 2021    Post subject: Reply with quote
I’ve got a £5 Halfords One Touch Universal Car Mount Holder which seems good although I don’t leave it on the windscreen all the time. I’ve also had it stuck on the music player’s 7” screen which allows a short and tidy connection to the 12v socket.
The last post was made 4 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Dear Auntie BCF... via View Category All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 83.63 Kb
