Cutting tufnol with hand tools?
PostPosted: 15:50 - 04 Nov 2021    Post subject: Cutting tufnol with hand tools? Reply with quote
Need to make a custom inlet manifold spacer out of 5mm tufnol sheet and I've never worked with the stuff before. Lots of info out there on machining it, not so much on hand tools. I have hole saws I can make the holes with but what best to cut the profile with?
Coping saw? Tile cutter saw? Stanley knife? I assume it will sand down nicely with some zinc oxide paper for final shaping?
Islander
PostPosted: 16:08 - 04 Nov 2021    Post subject: Reply with quote
It should cut easily with a coping saw/jigsaw/bandsaw and it'll drill and sand no bother. It might be a good idea to wear a mask - from memory the fumes are awful!
Nobby the Bastard
Harley Gaydar
PostPosted: 16:10 - 04 Nov 2021    Post subject: Reply with quote
What sort of strength is the material?
You can get tile cutting saws that are shaped similarly to a junior hacksaw but have a round cutter rather than a straight blade, making it easier to cut unusual shapes.
Triumph Sprint ST 1050
virus
Coping saw / band saw seemed to work fine when I last used Tufnol, wear a mask though its nasty stuff.
own: 81 xs1100g...
PostPosted: 16:30 - 04 Nov 2021    Post subject: Reply with quote
It's a layered construction plastic sheet which is both tough and brittle at the same time. I read it has a tendancy to delaminate if you cut it at the wrong speed so i wasn't sure how it would respond to being sawed.
It's very heat resistant and a poor conductor of heat which makes it a good material to use to space out carbs on air-cooled motors.
Coping saw it is then, it's just an oval shape I need.
Will wear a mask Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 16:31 - 04 Nov 2021    Post subject: Reply with quote
Tiles are tough but brittle, thats why I suggested one of them.
WD Forte
PostPosted: 17:32 - 04 Nov 2021    Post subject: Reply with quote
Yeah wot he said
It machines/cuts nicely, just wear a dust mask if indoors
as it's largely phenolic resin.
Coping saw for outer profile then sand
Stanley knife ? wouldn't be my tool of choice.
bikers smell of wee
PostPosted: 18:10 - 04 Nov 2021    Post subject: Reply with quote
Tufnol is very easy to saw but you're not cutting it with a knife. Hacksaw, coping saw, jig saw hell you could cut it with a mini grinder nd thin disc but only do that outside. File/sand to suit.
kramdra
PostPosted: 16:23 - 09 Nov 2021    Post subject: Reply with quote
Holesaw followed by die grinder,
or wood router. You could get one of the many laser'ists to cut out a plastic template and use a bearing bit to follow.
The last post was made 4 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 61.1 Kb
