would anyone want a cheaper Rev light system? *updated* *1*
Ric
PostPosted: 16:12 - 07 Apr 2005    Post subject: would anyone want a cheaper Rev light system? *updated* *1* Reply with quote
im working on a circuit at the mo (finished) and building a test rig as soon as i can for my bike (zxr400)
but if they work and i can test them on other bikes (heres where you lot come in)
Would anyone be intrested in a BCF branded Rev Light thingy?
hopefully a small box that can be tucked away and the lights seperate, just need help finding something to mount the led's in to make it flexy
need to sort out the costs of stuff but i rekon they will be far far cheaper than 60 quid or what ever datatool do them
ne one taking an intrest? ill keep you all updated
lilredmachine
PostPosted: 16:19 - 07 Apr 2005    Post subject: Reply with quote
That'd be really helpful as the MZ has no rev counter at all and no gear indicator so it would help greatly with that. Stop me detonating the motor at least, as well as look cool.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 16:27 - 07 Apr 2005    Post subject: Reply with quote
Sounds quite cool, if they're cheap as chips I can imagine a lot of people wanting one.
binge
Emo Kiddy
PostPosted: 16:36 - 07 Apr 2005    Post subject: Reply with quote
Ill have one for my mini.. Cool
DO you mean somthing like this?
https://img.photobucket.com/albums/v358/binge/revthingey.jpg
If its that sort of thing. then yes, I would like one for my mini as I took my big rev counter clock out because the new dash didnt have room for it. Crying or Very sad
Jrod
Page 3 Girl
PostPosted: 16:48 - 07 Apr 2005    Post subject: Reply with quote
You've already had my order. Thumbs Up
binge
Emo Kiddy
PostPosted: 17:16 - 07 Apr 2005    Post subject: Reply with quote
I take it you make them in Neon Blue then Ric... Laughing
Method
PostPosted: 17:35 - 07 Apr 2005    Post subject: Reply with quote
Ill take 2! Thumbs Up
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
The Tot
PostPosted: 17:54 - 07 Apr 2005    Post subject: Reply with quote
I might be interested, but then again - i don't have a tach so it'll be pretty useful for me to see the revs as well as hearing it. Sometimes i feel my engine isn't loud enough when i have my plugs in.
Never argue with autism
Ric
PostPosted: 18:13 - 07 Apr 2005    Post subject: Reply with quote
titty man i dont think you will have the feed for the zapper to get a reading?
just a guess
BTW dont hold out as me and my mates have worked out a circuit that *could* work, it may not or may be hard to set up
BUT
i have a digi tacho and digi speedo circuit on paper too Razz
Sparks!
Sir Tart-a-lot
PostPosted: 18:15 - 07 Apr 2005    Post subject: Reply with quote
If it works and is really cheap then I'll have 1, maybe 2.
HurtMePlease This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Ric
PostPosted: 19:46 - 07 Apr 2005    Post subject: Reply with quote
basically on a zxr400 the loom has an o ring connector thingy that a screw goes thru into the back of the clocks
from what i can gather without testing (its wet outside)
the signal is one of these, so the link up can jus be screwed in, dont kno about other bikes
vlf
PostPosted: 20:11 - 07 Apr 2005    Post subject: Reply with quote
I'd happily buy one.
Ric
PostPosted: 02:48 - 08 Apr 2005    Post subject: Reply with quote
Right the spec is lookin as follows
10 Led's, 5 green, 3 amber, 2 red (fully choice tho just that standard)
dimmer switch (can be LDR or manual switch)
adjuster (using small screwdriver) to tune it to your bike
connection fitting for rev signal on set wire
power socket, power connector fitted on a over long wire (so can be cut to size) which will have to be fitted my owner to ignition
tryin to find a solution to make it so the LED's will bend and stick (possibly mounting them in a thin rubber block?)
so what you all reckon?
M1ke
Ped Boi
PostPosted: 03:00 - 08 Apr 2005    Post subject: Reply with quote
Which chip are you using to read the rev signal and then output the correct LED's?
Is it one you have programed your self or what?
numark1
Scared of girls
PostPosted: 03:13 - 08 Apr 2005    Post subject: Reply with quote
I'll take one.
Flip
PostPosted: 03:18 - 08 Apr 2005    Post subject: Reply with quote
I don't need one and I don't see the point of having one, but I might well buy one if they're good enough. Very Happy
binge
Emo Kiddy
PostPosted: 03:29 - 08 Apr 2005    Post subject: Reply with quote
My mini has 4 wired going to the rev counter Confused
The last post was made 21 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 95.34 Kb
