Honda Hornet 2009 - Question :)
addj81
PostPosted: 12:21 - 07 Nov 2021    Post subject: Honda Hornet 2009 - Question :) Reply with quote
Hi all,
This is my first time posting here, but i have come across something that i would like to get advice on.
After taking my Hornet for a ride the other day I noticed a small amount of water coming out of the breather pipe by the exhaust (larger diameter one).
Is this normal as i have not noticed it before, hence the question!
Cheers,
Ad
Nobby the Bastard
Harley Gaydar
PostPosted: 12:24 - 07 Nov 2021    Post subject: Reply with quote
Where does the breather connect to the engine?
Triumph Sprint ST 1050
jaffa90
PostPosted: 21:57 - 07 Nov 2021    Post subject: Reply with quote
What does it smell / taste like as in fuel or coolant / antifreeze ?
Islander
PostPosted: 23:04 - 07 Nov 2021    Post subject: Reply with quote
Really? Rolling Eyes Laughing
TravisBickle
PostPosted: 00:39 - 08 Nov 2021    Post subject: Reply with quote
The taste test is always my first go-to method. I've had worse fluids in my mouth before now than anything you'd expect to come from a motorbike Thinking
2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
jaffa90
PostPosted: 01:02 - 08 Nov 2021    Post subject: Reply with quote
REALLY.
UncleFester
PostPosted: 06:37 - 08 Nov 2021    Post subject: Reply with quote
Really.
Sniff and taste is always my preferred check too.
Nothing that comes out of / off my bike tastes worse than Marmite and people eat that shite.
2017 Z1000SX
Islander
PostPosted: 09:18 - 08 Nov 2021    Post subject: Reply with quote
UncleBFester wrote:
Really.
Sniff it to see what it smells like? Yes maybe if that helps, but taste it? That's frankly stupid. I'd expect it from jaffa90 because he gives frankly stupid advice on here and TravisBickle is on his way past Barking to full on Upminster but really??
OP don't put the stuff that drips out of any part of your bike into your mouth. Work out where it comes from logically.
Easy-X
PostPosted: 11:54 - 08 Nov 2021    Post subject: Reply with quote
My wife's just pinned an article to the fridge "How to spot antifreeze poisoning in cats" Shocked
rpsmith79
PostPosted: 12:02 - 08 Nov 2021    Post subject: Reply with quote
Expansion tank is under the seat, see if it connects to here, they are a pretty basic bike, so you should be able to trace it without having to remove much off the bike, usually just give the pipe a wiggle at one end and see if it moves at t'other end
Have you recently topped up the coolant?
Hong Kong Phooey
PostPosted: 13:33 - 08 Nov 2021    Post subject: Reply with quote
There's a fuel cap drain, to drain off excess fuel or rain water that can leak past the cap. It will be attached to a spigot at the bottom of the tank.
addj81
PostPosted: 14:21 - 08 Nov 2021    Post subject: Reply with quote
Thanks for the replies!
After checking the fluid it was odourless.
I have followed the pipe and it in fact leads to the rear of the fuel tank. I have also taken two pictures to highlight the pipe in question and where it leads too.
I also checked coolant and it seems to be fine. I suppose this is normal?
Cheers,
Add
Easy-X
PostPosted: 14:38 - 08 Nov 2021    Post subject: Reply with quote
If it's anything like my bike it'll be a drain for around the fuel cap so rain doesn't collect there.
PostPosted: 14:39 - 08 Nov 2021    Post subject: Reply with quote
Lets simplify things. If it's not fuel, oil or coolant which are all coloured or smelly.... In the words of the song 'Don't worry, be happy'. Thumbs Up
Triumph Trophy Launch Edition
Hong Kong Phooey
PostPosted: 15:33 - 08 Nov 2021    Post subject: Reply with quote
Passive aggressively rated as agree Laughing
addj81
PostPosted: 17:08 - 08 Nov 2021    Post subject: Reply with quote
Appreciate all the info!
I just like to ensure everything is running as it should be Smile
UncleFester
PostPosted: 20:44 - 08 Nov 2021    Post subject: Reply with quote
There's a degree of common sense expected here.
Petrol = dead giveaway
Oil = the same
Coolant = taste but not smell.
AC condensate - no taste no smell.
And then there's plain old water.
Let's be clear - a drop on your tongue is not going to fuck up your renal system and most of us have had petrol or diesel in our mouths at some point I'm sure.
It's about common sense. Unlike eating marmite, which is just wrong.
2017 Z1000SX
Nobby the Bastard
Harley Gaydar
PostPosted: 20:48 - 08 Nov 2021    Post subject: Reply with quote
You missed off battery acid.
Islander
PostPosted: 21:16 - 08 Nov 2021    Post subject: Reply with quote
I really want to see jaffa90 taste that Laughing
xX-Alex-Xx
PostPosted: 21:21 - 08 Nov 2021    Post subject: Reply with quote
Blinker fluid.
Splatted fly juice from your windscreen.
Tears of that Porsche driver you just annihilated off a roundabout.
DILLIGAF
PostPosted: 22:06 - 08 Nov 2021    Post subject: Reply with quote
Indeed. Colourless and odourless. However it's immediately recognizable regrettable on a taste test.
Or maybe a dog pissed up it...
MCN
PostPosted: 22:09 - 08 Nov 2021    Post subject: Reply with quote
"What does it taste like?"
That's why grown-ups are advised to keep chemicals and medicines out of reach of children.
Children don't understand the risks.
Very Happy
jaffa90
PostPosted: 00:10 - 09 Nov 2021    Post subject: Reply with quote
No need to taste because it smells like rotten eggs as you lot should know? Smile
Islander
PostPosted: 00:30 - 09 Nov 2021    Post subject: Reply with quote
Wrong. It only smells like that when it's reacting with something like iron. Sulfuric acid is odourless - well apart from the fumes burning all of those delicate mucous linings as you inhale it of course - which isn't smell just a sudden painful burning...
MCN
PostPosted: 09:02 - 09 Nov 2021    Post subject: Reply with quote
Oil = the same
What harm could a couple of drips do?
https://youtu.be/NJ7M01jV058
The last post was made 4 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 4.12 - MySQL Queries: 13 - Page Size: 125.67 Kb
