2010 CBF600 easy to work on
flyingcbf
PostPosted: 16:16 - 09 Nov 2021    Post subject: 2010 CBF600 easy to work on Reply with quote
Hi Guys,
I've not had this bike long but thinking of doing most maintenance myself. Is this bike easy to work?
For example, I need to check to valve clearance every now and then. Is this easy to do on this 2010 model?
2019 Suzuki V-Strom 250
2020 Cb125F @ 5k miles and going up!
PostPosted: 19:50 - 09 Nov 2021    Post subject: Reply with quote
I'd go with a firm no on the basis it is a compact Japanese sports bike and as such everything will be tricky to get at and fiddly due to being crammed into a small space. No sports bikes are easy to work on.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:02 - 09 Nov 2021    Post subject: Reply with quote
Clearances will likely mean taking off the tank, radiator and probably ht coils just to get the leads off. Plus various air channeling and water dispersing bits.
Then once you have the valve cover you can finally get at the gaps.
Then when you find they are out of spec you'll have to pull the cams, buckets and finally the shims aand then reverse the above once you have replacements.
I've done it outside my house but its definitely not the job for a novice.
Triumph Sprint ST 1050
PostPosted: 21:02 - 09 Nov 2021    Post subject: Reply with quote
Or more likely, you'll find they are all actually within tolerances but land up switching out a couple of shims anyway on the furthest out ones because it was such a PITA to get to this point and you don't want to have to do it again.
flyingcbf
PostPosted: 08:57 - 10 Nov 2021    Post subject: Reply with quote
Ok, thanks.
Guess I'll leave it since it's running OK for now. Probably sell it next year and get a bike that's easy to work on.
Robby
Dirty Old Man
PostPosted: 09:08 - 10 Nov 2021    Post subject: Reply with quote
If the job needs doing but you're not comfortable doing it yourself, take it to a shop. Cheaper than changing bikes.
The last post was made 4 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 48.4 Kb
