DRZ400 needing filled up before tank empty.
Scatcat1994
PostPosted: 17:02 - 17 Nov 2021    Post subject: DRZ400 needing filled up before tank empty. Reply with quote
Hi guys.
So I recently ran out of fuel after 70 miles, flipped to reserve and went to a fuel station.
I put in 7.25 litres until it was brimmed up 1.6 gallons. I had done 78 miles by the time I filled up so 78/1.6 = 49 mpg which doesnt seem overly concerning fuel economy considering I mess about.
My concern is that the supposed capacity of the tank is 2.6 gallons with most people reporting needing to flip to reserve around the 100 mile mark.
Essentially I'm getting ok fuel economy but my bike isn't using all the fuel in the tank.
Any ideas on what to look for or how to identify issues?
I'm guessing I should have a look at the petcock for blockages or something?
Thanks guys!
-Scott
PostPosted: 17:23 - 17 Nov 2021    Post subject: Reply with quote
I can't think of a reason that would happen unless maybe the reserve was blocked but that's apparently working fine.
Your fuel tap has a brass tube attached to it which sticks up into the fuel tank, usually about 2" long. On main, it draws fuel through that tube. When the fuel level goes below the height of the tube, your bike cuts out and you switch onto reserve. When on reserve, fuel runs out through a hole hear the base of the tap so you can run the tank empty.
It sounds to me like you're going onto reserve too early. The thing that determines when that happens is the length of the pipe on the fuel tap. Perhaps someone has modified it or fitted a tap off a different bike? Looking on ebay, there seem to be taps with two different lengths of tube for your bike.
What I'd do is run it to nearly on reserve then have a look in with a torch to see if that tube is near the surface of the fuel. If it is, you can check what's left in reserve by draining the tank into a fuel can. You'll need to switch the tap to the "PRI" position to make fuel run out with the engine off. If you think it's too much, you could always remove the tap and cut a bit off the top of the tube so the reserve level is where you want it.
ThunderGuts
PostPosted: 18:00 - 17 Nov 2021    Post subject: Reply with quote
Suggestion is the bike ran out and had to be flicked onto reserve? Assuming the reserve take-off is fixed, the only other thing is was the tank actually brim-full? If on a side-stand some bikes (not familiar with this exact model) sometimes generate a large air-space on the "uphill" side of the tank. If it's level, quite a bit can fit in there (although a gallon sounds a big difference). Does it have a centre stand? If so, fill up with it on that next time and see what happens.
TG.
Scatcat1994
PostPosted: 19:14 - 17 Nov 2021    Post subject: Reply with quote
Thanks for the replies guys, I'll have a look at the petcock and see if it's a standard DRZ one. And yes, the bike only has a sidestand. Some more investigation required.
I might fit a transparent hose under the carb to help visualize what's going on, something not right. Cheers!
Nobby the Bastard
Harley Gaydar
PostPosted: 19:18 - 17 Nov 2021    Post subject: Reply with quote
Mist transparent hoses aren't safe with petrol as they either breakdown or go brittle.
Triumph Sprint ST 1050
PostPosted: 01:14 - 18 Nov 2021    Post subject: Reply with quote
Not really true, there are plenty of transparent hoses suitable for petrol. Just make sure it is actually fuel line and not designed for something else.
A100man
PostPosted: 11:12 - 18 Nov 2021    Post subject: Reply with quote
DRZ400 tank capacity 10 L (2.2 imp gal; 2.6 US gal)
Islander
PostPosted: 12:01 - 18 Nov 2021    Post subject: Reply with quote
Those damned yanquis with their 16 floz pints. Laughing
Fizzer Thou
PostPosted: 12:18 - 18 Nov 2021    Post subject: Reply with quote
If the DRZ tank is anything like that which is on my XR400R then it overhangs the spine frame.Once the fuel gets below a certain level then you are left with none on the tap side but an amount on the other side.
On the bigger tank that I used to have fitted for long distance greenlaning up in Wales,I drilled and tapped a hole and fitted pipework so that the side opposite the tap would empty first.This gave me the greatest range.
With the OEM tank when the bike goes onto reserve I can get off and lean the bike over to the tap side so that I can carry on with the ride until I can refuel.
https://i.postimg.cc/fLYbyY49/20201118-145503.jpg
Always have a 'Plan B'
MCN
PostPosted: 14:04 - 18 Nov 2021    Post subject: Reply with quote
Work out how many miles from full to empty.
(Take it out and have a pint bottle full of petrol for when it dies to get you to a filling station.)
Zero the Trip Meter or record/memorise the odometer.
Brim the bastirt.
Run till the bastirt dies.
Subtract the odometer at brimmed from dead to find out tank range for that fill.
In future remember what the mileage was when you fill and monitor as you go.
Leave the cock on reserve and don't fackaboot with the 'main'.
Easier to get a machine with a tank level gauge.
The last post was made 4 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.08 - MySQL Queries: 13 - Page Size: 66.25 Kb
