Strange Home Radiator blockage
A100man
PostPosted: 11:54 - 10 Nov 2021    Post subject: Strange Home Radiator blockage Reply with quote
I've been cleaning my rads out one by one and the last one I took into the garden for the hose treatment was blocked solid with some weird white chalky substance. Not hard like limescale but softer like school chalk. I removed the rad tails and rodded it all out but I'm confused how it got there. Horrid 'black as your hat' treacle in the other rads but not this stuff. Biggest piece I extracted was teh size of a broad bean - half the lower 'rail' of a 1.5m radiator was solid with it. Confused
Andy Perrett This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
A100man
PostPosted: 13:03 - 10 Nov 2021    Post subject: Reply with quote
Cable Tie wrote:
Lowest point of the system?
I have one where the to and from pipes originate from the floor above.
It does similar.
No in fact upstairs. This will be the last rad to be added back in after converting the system form 1970s single pipe to 'modern' flow and return..
Freddyfruitba...
PostPosted: 13:24 - 10 Nov 2021    Post subject: Reply with quote
Could it be plumber's mait, applied over-enthusiastically by the original system installer?
A100man
PostPosted: 13:33 - 10 Nov 2021    Post subject: Reply with quote
too much of it.. and not hard enough - that stuff sets like rock!
RhynoCZ
PostPosted: 17:30 - 10 Nov 2021    Post subject: Reply with quote
Have you checked the water/heating medium, yet? Hard water causes limescale.
There are test kits for hard water, limescale inhibitors etc. If you used your tap water as your heating medium, then there should be other tell tale sings all over your house (kettle, boiler, the faucets...)
JackButler
PostPosted: 17:31 - 10 Nov 2021    Post subject: Reply with quote
At a guess it's rust inhibitor, either poorly added to the system or by bad luck it's collected there & coagulated.
Once found a layer of the stuff on top of an open feeder tank which could only be described as 'lard'.
I clean my guns with the tears of the snivelling, left wing scum.
A100man
PostPosted: 20:37 - 10 Nov 2021    Post subject: Reply with quote
Indeed, one of my theories also. I don't suppose it matters just wondered if anyone else has seen such a thing.
A100man
PostPosted: 12:44 - 17 Nov 2021    Post subject: Reply with quote
Showed some of the pieces my time-served heating man and he'd never seen it before either!
Oh well all back together with new valves and it's heating up nicely again.
MCN
PostPosted: 14:31 - 18 Nov 2021    Post subject: Reply with quote
Did you take a sample and test it.
Leave it for a day or so to see if it tries hard.
Wipe it on a piece of paper, let it dry, Hold it up to a light and check if the paper is 'sorta' transparent-ish (grease/fat/oil test.).
Test it for flammability. (Justfuckinaboot)
Fernox have a heating water sample service.
https://fernox.com/product/system-health-check/
Do your duty and get it done.
BCF massive needs to knows now.
A100man
PostPosted: 15:20 - 18 Nov 2021    Post subject: Reply with quote
Thank you for your keen interest. I do have some samples as it goes.. (it does dry hard). I'll take some tests and update this fascinating thread soon. Thumbs Up
Robby
Dirty Old Man
PostPosted: 17:22 - 18 Nov 2021    Post subject: Reply with quote
Sounds like leak stopper. Looks like PVA glue going into the system, it's meant to only harden on contact with air.
Like any leak stop stuff (home or vehicle) it's an ugly bodge.
MCN
PostPosted: 18:55 - 18 Nov 2021    Post subject: Reply with quote
It's held my attention for days now.
With the additional thought of the A100mans all sat huddled the gither in their winter woolens as dad does his best to get to the bottom of the fascinating, radiator gloop issue.
The last post was made 4 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 78.42 Kb
