ER6F 2007 Headlights died (fixed: replaced bad relay)
NutsyUk
PostPosted: 22:31 - 23 Nov 2021    Post subject: ER6F 2007 Headlights died (fixed: replaced bad relay) Reply with quote
So that was eventful....
Last night on the way back from town (I'm in the pitch black countryside)
Just as i was joining a dual carriage way my headlights went out. Short flicker then dead.
The thing is. When i checked my highbeam, that was dead too.
Managed to get home as i was about 8 miles from home, dad came out and with hazards on we he guided me back on minor roads...
Anyway going to properly go over the bike tomorrow and wanted to check in to see if anyone has any suggestions to really look into.
First things first, fuse hasnt blown. I am using LED bulbs, theyve been working for a few years. Ive not checked to see if they burned out.
But i find it strange if they have, why would they take out the high beam at the same time?
(one bulb for normal one bulb for high beam)
Wiggled what connections I could find reaching up under the fairing in the pitch black. In case it was a loose connection.
Anyway so yeah, before i spend the day tomorrow fixing it. Any ideas?
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
Nobby the Bastard
Harley Gaydar
PostPosted: 22:47 - 23 Nov 2021    Post subject: Reply with quote
If its lost both its an earth or the wires to the hi low switch.
Triumph Sprint ST 1050
NutsyUk
PostPosted: 22:54 - 23 Nov 2021    Post subject: Reply with quote
yeah might be a funky earth as they are connected.... Was going to check that tomorrow.
Also no switch for the main beam as its always on.
High beam is well... normal switch Very Happy
But yeah earth is my first check.
NutsyUk
PostPosted: 14:02 - 24 Nov 2021    Post subject: Reply with quote
Well this is bad...
Wireing looks fine, doesnt look like any mouse nibbled anything or burned out loom where i can see....
But both earth lines are fine, just no 12V to the light sockets :/
Which means its still something in the loom or ECU :/
Shite!
yen_powell
PostPosted: 14:13 - 24 Nov 2021    Post subject: Reply with quote
How did you check the fuse?
XT1200Z and a DR350 in bits
NutsyUk
PostPosted: 14:22 - 24 Nov 2021    Post subject: Reply with quote
to begin with I looked at it, then ran continuity on it just to be sure.
Mysteriass
PostPosted: 17:04 - 24 Nov 2021    Post subject: Reply with quote
Put 12v onto the LED lamp and make sure it's not burned out. Examine the lamp circuitry carefully if you can get at it. The LED's might be fine but one of the tracks might be burned and could be repaired. Or...one of the LED's burned out which put more voltage into the other LED's and catalytically burned the lot out. Just depends how clever the circuit was.
Then, is there some kind of resistor / stabiliser circuit box that takes care of the LED headlight? LED's are very sensitive to overvoltage so there's sometimes something to keep the voltage down inline. If so, that circuit could be bust. It could literally be a resistor taped into the loom somewhere.
Is the handlebar switch a direct on / off between the battery and headlight? Or does the switch go to a relay?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:27 - 24 Nov 2021    Post subject: Reply with quote
Mysteriass wrote:
catalytically
A bit like in an exhaust?
NutsyUk
PostPosted: 17:51 - 24 Nov 2021    Post subject: Reply with quote
new update.... Its the relay... Funnily enough bigclive had a teardown of the same unit... That has the exact same fault!
The coil is burned out.
managed to take mine apart and desolder the contacts. Now im just struggling to find a replacement part.
Mysteriass
PostPosted: 17:54 - 24 Nov 2021    Post subject: Reply with quote
Mysteriass wrote:
catalytically
Poor choice of word on my part.
If one LED shorted therefore increasing voltage to the other LED's thus burning them then we could say that the first LED to die was the catalyst for burning the other LED's out.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:56 - 24 Nov 2021    Post subject: Reply with quote
Id be surprised if its anything other than a normal 4 pin relay.you can buy them in halfords for about a fiver
https://www.halfords.com/tools/fuses-electricals-and-fixings/electricals/halfords-hef554-relay-12v-30amp-4-pin-184013.html
Mysteriass
PostPosted: 17:58 - 24 Nov 2021    Post subject: Reply with quote
Sometimes it's better to buy an entire loom with everything included. Obviously cost a bit more but you'll have a bunch of spares. You can also strip the spare loom down / use meter on it easily to figure out how it works before you work on your own.
Worth a look perhaps.
NutsyUk
PostPosted: 18:09 - 24 Nov 2021    Post subject: Reply with quote
sadly not, I mean im sure I could hack that in some how but it wont be weather proof.
The part I need is a
NEC EQ1-11111S
Or a clone other brand part.
NutsyUk
PostPosted: 18:20 - 24 Nov 2021    Post subject: Reply with quote
I mean the specific component... It should only cost a couple of quid rather than the cost of a whole box or loom...
The trouble with getting a breakers yard box is, that this seems to be fairly common. They burn out. And theres a good chance the box id get might be burned out too. or On its way to being burned out.
Still my best option is to find the replacement relay part and solder that into the pcb.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:27 - 24 Nov 2021    Post subject: Reply with quote
Why the fuck is there a pcb controlling power to the fucking front light?
NutsyUk
PostPosted: 18:52 - 24 Nov 2021    Post subject: Reply with quote
it latches on the main headlight / running light when the engine starts...
Theres about 5 other relays in the box.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:55 - 24 Nov 2021    Post subject: Reply with quote
Just bypass it entirely and have both the front and running lights on permanantly. If you must, have a relay set up that cuts the power to the lights when the starter is running.
You'll need a 5 connector relay for that.
NutsyUk
PostPosted: 18:57 - 24 Nov 2021    Post subject: Reply with quote
Well think ive just found a replacement alternative part https://uk.rs-online.com/web/p/non-latching-relays/0492894/
Trouble is I dont know if the ECU is sending the signel as 12V or 6.5v.... Its a bit confusing.
NutsyUk
PostPosted: 15:37 - 25 Nov 2021    Post subject: Reply with quote
Good news, the relay from RS worked....
Its a pain in the arse to get into the relay box. You have to desolder the plug connector pins. And i used a solder sucker that mostly worked. But a proper desoldering gun with a vacuum pump would be far easier.
it also seems to be a fairly common problem with this relay box. (googled around even bigclive had a video with the exact same dead relay)
So if anyone else has their headlights die like this...
You can get the part from RS for a reasonable price. Link in my previous post.
The 12VCD version works just fine. I was worried it wouldnt as the old part might be a 6.5V (according to a badly translated datasheet)
which is an odd voltage.
sickpup
Old Timer
PostPosted: 10:23 - 28 Nov 2021    Post subject: Reply with quote
The relay box normally burns out because the reg-rec is on it's way out and overcharging.
The last post was made 4 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 110.47 Kb
