RAM matching
PostPosted: 14:42 - 28 Nov 2021    Post subject: RAM matching Reply with quote
My laptop, according to speccy has 2 ram slots with only 1 used as shown below. Now is it worth me getting another 8GB RAM for the other slot and will it matter if the Hz are different. ie will this work OK or suggestions on something better?
https://www.amazon.co.uk/Rasalas-PC3L-12800S-1600mhz-PC3-12800S-204-Pin/dp/B08B5RCY5C/
RAM
Memory slots
Total memory slots 2
Used memory slots 1
Free memory slots 1
Memory
Type DDR3
Size 8192 MBytes
Channels # Single
DRAM Frequency 798.4 MHz
CAS# Latency (CL) 11 clocks
RAS# to CAS# Delay (tRCD) 11 clocks
RAS# Precharge (tRP) 12 clocks
Cycle Time (tRAS) 28 clocks
Bank Cycle Time (tRC) 39 clocks
Physical Memory
Memory Usage 86 %
Total Physical 6.94 GB
Available Physical 940 MB
Total Virtual 11 GB
Available Virtual 1.39 GB
SPD
Number Of SPD Modules 1
Slot #1
WD Forte
PostPosted: 17:01 - 28 Nov 2021    Post subject: Reply with quote
I reckon it will work as I think your current dram (798.4Mhz)
is 1600 too as its actually clocked at half the nominal/advertised speed of 1600Mhz
I was curious as to why your lappy was using 86% of your current ram when you ran speccy
heavy user?
bikers smell of wee
PostPosted: 17:07 - 28 Nov 2021    Post subject: Reply with quote
heavy user?
Not really. Internet. Civ4 in the background. Kindle app open and speccy. That's it (as far as I know Laughing )
GettinBetter
PostPosted: 17:11 - 28 Nov 2021    Post subject: Reply with quote
https://www.crucial.com/blog/memory/mix-and-match-dram
I wouldn't mix. I'm sure if you look you'll find another one.
xX-Alex-Xx
PostPosted: 21:04 - 28 Nov 2021    Post subject: Reply with quote
I’ve run mismatched memory before in a laptop without issues, but you’re always best off with a matched pair of sticks.
DILLIGAF
PostPosted: 23:36 - 29 Nov 2021    Post subject: Reply with quote
Oh well, mismatched or not, done and working although I'd fogotten it was such a pain to get into the laptop. It seems quicker but that could just be wishful thinking on my part.
New speccy
Memory slots
Used memory slots 2
Free memory slots 0
Memory
Type DDR3
Size 16384 MBytes
Channels # Single
DRAM Frequency 665.3 MHz
CAS# Latency (CL) 9 clocks
RAS# to CAS# Delay (tRCD) 9 clocks
RAS# Precharge (tRP) 10 clocks
Cycle Time (tRAS) 24 clocks
Bank Cycle Time (tRC) 33 clocks
Physical Memory
Memory Usage 39 %
Total Physical 15 GB
Available Physical 9.08 GB
Total Virtual 18 GB
Available Virtual 12 GB
SPD
Number Of SPD Modules 2
Slot #1
Slot #2
GettinBetter
PostPosted: 16:03 - 30 Nov 2021    Post subject: Reply with quote
Polarbear wrote:
Memory
Type DDR3
Channels # Single
Why is it still running in Single channel mode?
PostPosted: 16:05 - 30 Nov 2021    Post subject: Reply with quote
GettinBetter wrote:
Polarbear wrote:
Memory
Type DDR3
Channels # Single
No idea. Shouldn't it be?
xX-Alex-Xx
PostPosted: 17:21 - 30 Nov 2021    Post subject: Reply with quote
Probably not cos you've mismatched sticks.
DILLIGAF
GettinBetter
PostPosted: 20:06 - 30 Nov 2021    Post subject: Reply with quote
Polarbear wrote:
GettinBetter wrote:
...Why is it still running in Single channel mode?
It's entirely up to you.
If you had bought compatible memory it would probably have seen that and switched to DUAL and capitalised of the concept of DDR and hence faster memory. It may need a BIOS setting to do it, or maybe you haven't matched the memory in which case it will remain in SINGLE mode.
PostPosted: 20:22 - 30 Nov 2021    Post subject: Reply with quote
It's got the same size ram, the same type of ram, the same ghz. It fits in the slot. So whats the problem? Does it need two holes to be buggered properly?
GettinBetter
PostPosted: 20:27 - 30 Nov 2021    Post subject: Reply with quote
What's the motherboard model?
PostPosted: 20:40 - 30 Nov 2021    Post subject: Reply with quote
Sorry, on my boat so using a cheap and nasty notebook. Will post tomorrow. Thumbs Up
UncleFester
PostPosted: 20:42 - 30 Nov 2021    Post subject: Reply with quote
Notebook is not going to let uou select dual channel ram. If it boots its working
End thread.
2017 Z1000SX
xX-Alex-Xx
PostPosted: 00:00 - 01 Dec 2021    Post subject: Reply with quote
Dual channel and DDR are different things.
Laptop has been upgraded, doesn’t need any extra benefit, so who cares. It’s job done.
DILLIGAF
GettinBetter
PostPosted: 19:39 - 02 Dec 2021    Post subject: Reply with quote
Agreed. Different, but IMO related.
xX-Alex-Xx wrote:
....so who cares...
Well, obviously NOT you, but maybe Polarbear might?
PostPosted: 10:04 - 03 Dec 2021    Post subject: Reply with quote
Motherboard courtesy of speccy
Motherboard
Manufacturer Hewlett-Packard
Model 80B2 (P0)
Version 82.29
Chipset Vendor AMD
Chipset Model K16 IMC
Chipset Revision 00
Southbridge Vendor AMD
Southbridge Model Kabini FCH
Southbridge Revision 8.2
BIOS
Brand American Megatrends Inc.
Version F.19
Date 27/05/2016
PCI Data
Slot PCI
Slot Type PCI
Slot Usage In Use
Data lanes x1
Slot Designation PCI Express Slot 1
Characteristics 3.3V, Shared, PME
Slot Number 0
Does AMD stand for American Megatrends? I never knew that. Laughing
xX-Alex-Xx
PostPosted: 10:43 - 03 Dec 2021    Post subject: Reply with quote
Not related at all. DDR just sends signals on both sides of the clock signals. It's nothing to do with the width of the pipe.
You'll only see real-world gains in *some* high end gaming, and I don't think that's the goal here.
DILLIGAF
GettinBetter
PostPosted: 21:02 - 03 Dec 2021    Post subject: Reply with quote
I nearly agreed with you, seemed quite logical, but apparently it's Advanced Micro Devices. Who new (or cared enough to find out)?
Is it a Pavillion Notebook? Have you got a model number for the Laptop.
PostPosted: 16:30 - 04 Dec 2021    Post subject: Reply with quote
HP Pavilion Notebook - 15-ab088na (ENERGY STAR)
Product number: N2K61EA#ABU
Edited to add it's purple. Embarassed
GettinBetter
PostPosted: 20:33 - 04 Dec 2021    Post subject: Reply with quote
Product number: N2K61EA#ABU....
Seems your Motherboard doesn't support 'Dual Channel', here's some interesting links should you be interested, you've prolly already got them. I only asked because my last machine was Dual Channel and it was donkeys years old, I assumed all newer machines would be by now.
Specs
https://icecat.biz/p/hp/n2k61ea/pavilion-notebooks-0725184024771-15-ab088na-28548432.html
PDF version
https://icecat.biz/rest/product-pdf?productId=28548432&lang=en
Support
https://support.hp.com/gb-en/drivers/selfservice/hp-pavilion-15-ab000-notebook-pc-series/7771366/model/8543112
The last post was made 4 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 112.99 Kb
