trouble with the zx9r
stumpy75
PostPosted: 02:26 - 12 Dec 2021    Post subject: trouble with the zx9r Reply with quote
ok so i bought 1998 zx9r started and rode it fine about 50 miles parked it in the garage and a week later started it was runnin lumpy went ut and about 500yds she died as if out of fuel started it but wont pull off tho it seems to rev ok took the carbs off cleaned them changed spark plugs started it and it ran rode it a day went back next day will start run rev but when i go topull off it dies anyone have any ideas i need this for work and its frying my brain so far i have changed coils ignition pick us spark plugs cleaned carbs checked for brakes in the wires ect changed the fuelpumprelay fuel pump fuel pipes petrol tapis fine fuel pisses out when in on position.... i cant find anything
Mysteriass
PostPosted: 03:02 - 12 Dec 2021    Post subject: Reply with quote
You cleaned the carb and it worked. I'm thinking it's E10 ethanol fuel eating a lining sealant in the fuel tank and now tiny particles of gummy snot are constantly getting sucked into the carb jets.
jeffyjeff
PostPosted: 04:33 - 12 Dec 2021    Post subject: Reply with quote
Starts ok, revs, but won't pull a load. Sounds fuel related to me.
Double check fuel pressure. Could be a restriction, fuel pressure sensor or regulator. Does your ZX9R have a vacuum operated fuel valve? If so, a vacuum leak could restrict fuel from passing to your carbs. If not, try running the manual valve on 'reserve' see if problem goes away. Check your tank breather/purge valve/charcoal canister to make sure the tank is breathing OK. Maybe try opening the tank cap when the symptoms occur to see if it helps.
stumpy75
PostPosted: 10:07 - 12 Dec 2021    Post subject: Reply with quote
this is a second set of carbs [ i have a whole bike for spares] it did it on
the original carbs also the fuel pump is also off the spares bike
its not vacume operated bit of a strange set up on the zx9r c1/2 te fuel pump only works when the bike is running/cranking as opposed to being primed ect when the ignition is turned on as on other bikes
it also has a cam position sensor but ime not sure if these do anything as i thought they were for fuel injected bikes not carbs
the bike does have a rocker cover breather valve as in picture a narrow pipe also connects to this thin metal tubein pic but is not connected to the fuel tap or the fuel pump
Kawasaki Jimbo
PostPosted: 11:02 - 12 Dec 2021    Post subject: Reply with quote
I’d check for air/vacuum leaks at the airbox. I’d also suspect the fuel pump/relay but you’ve changed those. Then I’d look at electrics. Is the battery healthy? Is the charging system working?
Robby
Dirty Old Man
PostPosted: 14:54 - 12 Dec 2021    Post subject: Reply with quote
I had very similar symptoms on a CBR600 with a dead reg/rec, so it wasn't charging.
Running out of electricity feels very similar to running out of fuel.
Get it running, put a multimeter across the battery set to DC volts. You want to see 14.5V at around 4000rpm, and 13V at tickover.
trevor saxe-coburg-gotha
PostPosted: 03:12 - 13 Dec 2021    Post subject: Reply with quote
if none of the above works, try zx-9r.net if you haven't already - there is a lot of excellent advice there and the forums are still used quite regularly
https://www.zx-9r.net/viewforum.php?f=4
A100man
PostPosted: 11:58 - 13 Dec 2021    Post subject: Reply with quote
..or water in the tank through condensation or other means.
Tdibs
PostPosted: 13:26 - 14 Dec 2021    Post subject: Reply with quote
Sounds electrical. I'd be having another really good look for any hairline cracks in the coilstick boot and testing them with the multi meter.
Wull
PostPosted: 02:04 - 20 Dec 2021    Post subject: Reply with quote
That forum has went to shit tbh, you might still get some help but I wouldn’t bet on it.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
The last post was made 4 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 62.93 Kb
