Tail tidy - what do I need to know
BRUN
PostPosted: 09:27 - 17 Dec 2021    Post subject: Tail tidy - what do I need to know Reply with quote
I want to get a tail tidy for my bike, the rear mudguard is huge, but what are the legal or MOT things I need to know about before I buy one
Im reading online about number plate angle ? rear reflectors ? but some of this seems to be other countries than the UK
Nobby the Bastard
Harley Gaydar
PostPosted: 09:59 - 17 Dec 2021    Post subject: Reply with quote
Number plate is supposed to vertical otherwise could be considered to be obsured, indicators have to be a set distance apart and the must be a reflector dead in the centreline of the bike.
Triumph Sprint ST 1050
ThunderGuts
PostPosted: 10:10 - 17 Dec 2021    Post subject: Reply with quote
Are you sure about the verticality thing? The numberplates on my bikes (stock tail) have always been about 10-15deg off the vertical at least. I reckon you could get away with up to 25 degrees but much more than that and I agree it's starting to get a bit harder to read.
Not sure about MOT, but isn't the rearmost part of the bike supposed to be something static (i.e. not the wheel) which is why on bikes with shorter / more angled pillion seats/tails tend to have those ridiculous numberplate mudguard things?
TG.
t121anf
PostPosted: 10:14 - 17 Dec 2021    Post subject: Reply with quote
MOT rules state
be fitted vertically, or as close to vertical as is reasonably practicable
Also did a quick image search for "gsxr" and the stock bikes don't look vertical.
Nobby the Bastard
Harley Gaydar
PostPosted: 10:15 - 17 Dec 2021    Post subject: Reply with quote
The number plate doesn't have to be vertical, but the further angled the more likely the filth etc. will take umbrance.
The rear projection thing is for construction and use. This only applies to manufacturers of vehicles/ vehicles that haven't been submitted by manufacurers (kit cars for exammple) and 'significanttly modified vehicles.'
A tail tidy isn't really in the category of 'significantly modified.
xX-Alex-Xx
PostPosted: 10:17 - 17 Dec 2021    Post subject: Reply with quote
Just note that one of those stick-on round reflectors stuck to the bottom of the plate is fine for MOT. It's how my "MOT plate" is set up as the one I use 364 days of the year is a bit smaller than stock.
DILLIGAF
Nobby the Bastard
Harley Gaydar
PostPosted: 10:25 - 17 Dec 2021    Post subject: Reply with quote
yep, I used to stuck a new one onto my FZ at every MOT because it had fallen off every time.
Zen Dog
PostPosted: 10:38 - 17 Dec 2021    Post subject: Re: Tail tidy - what do I need to know Reply with quote
I'm sure what everyone has said above is true, and abiding by the exact rules is probably a bit of a fiddle. But the reality is that if you're buying a tail tidy for your specific bike from a reputable manufacturer, they'll have done the homework and you can just fit it without worrying too much.
PostPosted: 11:59 - 17 Dec 2021    Post subject: Reply with quote
Indicators need to be minimum 180mm apart.
If you're stopped for the numberplate angle, save this picture on your phone?
https://cdn.visordown.com/styles/amp_1200/s3/field/image/South%20Yorkshire%20Police.jpg
EDIT: Also don't screw it to your ECU.
A100man
PostPosted: 12:19 - 17 Dec 2021    Post subject: Reply with quote
Interesting shot - where is that?
Nobby the Bastard
Harley Gaydar
PostPosted: 12:28 - 17 Dec 2021    Post subject: Reply with quote
According to this, Brighton....
https://www.car.co.uk/media/guides/number-plates/uk-number-plate-area-codes
Kawasaki Jimbo
PostPosted: 12:41 - 17 Dec 2021    Post subject: Reply with quote
I don’t know what value a red reflector has on a narrow vehicle like a bike anyway. That big yellow plate surely overwhelms it, even assuming you parked parallel to the kerb instead of the more usual angle, so the reflector actually shines back at approaching vehicles.
ThunderGuts
PostPosted: 13:03 - 17 Dec 2021    Post subject: Reply with quote
I can only see red reflectors on two of those police bikes.
TG.
xX-Alex-Xx
PostPosted: 13:08 - 17 Dec 2021    Post subject: Reply with quote
And they're not central to the bike so technically an MOT fail.
DILLIGAF
A100man
PostPosted: 13:38 - 17 Dec 2021    Post subject: Reply with quote
Ah I thought it was somewhere more grim and inhospitable, up North... Wink
BRUN
PostPosted: 13:59 - 17 Dec 2021    Post subject: Reply with quote
so, try keep to the number plate reasonably vertical but as long as its not horizontal, will be ok
I must have a rear reflector, in the centre, does it need to be a certain min size or shape, does it need to be at the bottom of the plate ?
Indicators must be 180mm apart, im sure they will be, planning to stick with OE for now
Is their any rule about the number plate or something else, being past the rear tyre, I thought I had read something like that somewhere
Have I missed anything ?
Nobby the Bastard
Harley Gaydar
PostPosted: 14:03 - 17 Dec 2021    Post subject: Reply with quote
Freddyfruitba...
PostPosted: 14:42 - 17 Dec 2021    Post subject: Reply with quote
Sheffield - looks to be taken from Meersbrook Park
ThunderGuts
PostPosted: 15:04 - 17 Dec 2021    Post subject: Reply with quote
Funnily enough I did think it looked a bit like that neck of the woods (I thought Huddersfield actually, but it's all a bit rinse and repeat on that bit of the Pennines).
TG.
xX-Alex-Xx
PostPosted: 15:42 - 17 Dec 2021    Post subject: Reply with quote
Have a look at the rules for motorcycle MOT's here.
https://www.gov.uk/guidance/mot-inspection-manual-for-motorcycles
DILLIGAF
The last post was made 4 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 108.42 Kb
