Bike won't start! (Dodgy electrics)
meyrick
PostPosted: 21:05 - 07 Apr 2005    Post subject: Bike won't start! (Dodgy electrics) Reply with quote
Landed myself in it a bit with the CB125TDJ. I replaced the headlight with a halogen unit via a pair of relays and an inline fuse and fitted a switch for the heated vest on the handlebars. Both work perfectly but now the bloody bike won't start! Evil or Very Mad
Here are the facts:
I labelled all the connectors inside the headlight before I took the old one off so I know everything is back where it should be - I have checked 1000 times.
All the fuses are accounted for.
The battery is fully charged and putting out >12V.
The bike is in neutral and/or the clutch is pulled in.
The starter solenoid is fine, although it is not receiving any power at all when the starter button is pressed.
When I turn off the ignition and short the starter solenoid contacts the motor turns over, but when I turn on the ignition and do the same nothing happens.
Everything else on the bike is working including brake lights, indicators, headlight, horn etc.
It's driving me MAD. Have I missed something? Any help will be very much appreciated. Very Happy Crying or Very sad
BFG
PostPosted: 21:09 - 07 Apr 2005    Post subject: Reply with quote
Will it bump start?
The start button usually just short to earth and the hadlebars. This might help when testing
meyrick
PostPosted: 21:10 - 07 Apr 2005    Post subject: Reply with quote
Oooh, interesting. Not sure. Never bump started a bike to be honest. I could give it a go.
musclebiker
PostPosted: 21:51 - 07 Apr 2005    Post subject: Reply with quote
Yeah just get a buddy to push, hold the clutch in, slip it into 2nd and then let the clutch out sharply. That should at least get the bike going. (Enough to get it down to a dealer.)
Stupidity is unbeatable, but that doesn't mean we should give up fighting it.
Jayman
PostPosted: 22:46 - 07 Apr 2005    Post subject: Reply with quote
Or i know it sounds obvious but try checking your battery fluid level, shouldnt thing it would be a dry cell on a cb125 so check the fluid level. Its not much to buy and could be the problem. Also, batteries tend to lose charge, so the bulb could be draining it slightly. Bump starting the bike and giving it a good run should recharge the battery somewhat if this is the problem. Good look mate. Thumbs Up
'Yes, of course! We can't crush a mutiny here, only to return home and find everyone wearing overalls and breaking wind in the palaces of the mighty!'
BFG
PostPosted: 23:35 - 07 Apr 2005    Post subject: Re: Bike won't start! (Dodgy electrics) Reply with quote
Doesn't sound like battery to me. If it won't bump start I'd check your connections for the 1001st time Wink
meyrick
PostPosted: 23:39 - 07 Apr 2005    Post subject: Reply with quote
The battery checks out. It's always plugged into my oximiser when the bike is sitting. Would a knackered rectifier stop the starter motor from turning? Could I have killed it when I was messing about with the electrics to fit the light?
meyrick
PostPosted: 01:10 - 08 Apr 2005    Post subject: Reply with quote
Just went into the garage to check the rectifier and the starter switch with a multimeter. I had to bend the pins on the starter switch connection box to get the multimeter pins in there and hey presto, the bike now starts. A valuable lesson learned: just because everything is plugged into the right socket doesn't mean there isn't a loose connection! Doh!
Well, thanks guys, mystery solved and I don't have to give the evil bus driver another penny Thumbs Up Very Happy
The last post was made 21 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 55.67 Kb
