Solid Indicators
CurtisLee
PostPosted: 21:32 - 30 Dec 2021    Post subject: Solid Indicators Reply with quote
I have a 2009 Honda Hornet and recently the indicators have been funny, blinking normally when stationary but as soon as I rev the engine or accelerate is speeds up then goes solid and back to blinking when I’m off the throttle, this happens on all 4 corners, any ideas??
Skudd
PostPosted: 21:41 - 30 Dec 2021    Post subject: Reply with quote
Short or loose wire.
martin734
PostPosted: 22:25 - 30 Dec 2021    Post subject: Re: Solid Indicators Reply with quote
Do you have any other symptoms like headlamp brightness fluctuations? I would check the voltage at your regulator just to make sure the voltage output is stable.
Current bike: ST1100 "Big Red"
Nobby the Bastard
Harley Gaydar
PostPosted: 22:36 - 30 Dec 2021    Post subject: Reply with quote
Like the OP said it sounds like a regulator issue but it could be just the flasher unit is knackered. Get a solid state one.
Triumph Sprint ST 1050
CurtisLee
PostPosted: 23:01 - 30 Dec 2021    Post subject: Re: Solid Indicators Reply with quote
Not noticed any changes with the headlight, think it’s isolated to the indicators
jaffa90
PostPosted: 23:05 - 30 Dec 2021    Post subject: Reply with quote
Surprised Usually they can be solid at low revs and normal at higher revs.
I would check the battery connections to the bike and then check the battery voltage at higher revs as mentioned.
If all is well then check the connections / voltage to the relay and maybe replace also as mentioned.
Nobby the Bastard
Harley Gaydar
PostPosted: 00:12 - 31 Dec 2021    Post subject: Reply with quote
Actually they can be solid at higher revs and flash faster at lower revs. It's all about current as well.
Normally the battery will balance things out so it does sould like the charging/battery system is playing up.
A fucked regulator will fuck a battery but I would imagine if you can start it the battery isn't dead.
doggone
PostPosted: 10:41 - 31 Dec 2021    Post subject: Reply with quote
Bad earth somewhere is most likely, start with battery terminals - take off, brighten up and retighten.
If you have jump leads clip one to battery earth and the other end to a bright metal spot.
The last post was made 4 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 3.28 - MySQL Queries: 13 - Page Size: 55.13 Kb
