Next bike advice?
Fred3606
PostPosted: 16:38 - 01 Jan 2022    Post subject: Next bike advice? Reply with quote
Hi all,
Just upgraded from a2 to full license and wanting a change from my SV650Sk3.
My budget is around 2000-2500 so mostly looking at privately sold bikes.
I like the idea of a naked bike for doing any maintenance and simplicity but looks always end up drawing me to a faired bike. My main requirement is something relatively reliable and likely to be well kept (due to the likely early 00s age), atleast 600cc and atleast 3 cylinders since I have had twins for the last 5 years.
I am currently looking at VFR800s (gen5 and 6) and Sprint ST1050 since there seems to be a good wodge of them second hand and I like the relatively unique sound of both.
Any advice and/or bikes to consider?
Thanks
ThatDippyTwat
PostPosted: 17:52 - 01 Jan 2022    Post subject: Re: Next bike advice? Reply with quote
Gen 5 - gear driven cams, throttle response can be snatchy but you get used to it fairly quickly.
Gen 6 - the first VTEC's are usually well past needing VTEC (Expensive) valve checks done, gear driven cams are gone, throttle response much improved.
I would have a 5th gen, I wouldn't touch a 6th. I'd buy a 4th gen over either.
Common to all up to 5th gen. Check collector boxes, they rot. Connectors (R/R, Stator, Earths, and on the 5th gen, the big block tucked in fairing) need cleaning or can lead to R/R, Battery, Stator failure if left unchecked. Plastics range from expensive to unobtainable. Bulletproof if looked after and oil changed regularly.
Soild, reliable, not going to give you any nasty surprises coming from an SV unless you're hamfisted on the throttle. Can hustle surprisingly well for a chunky thing. Chuck on a decent can and it'll sound glorious.
jeffyjeff
PostPosted: 19:15 - 01 Jan 2022    Post subject: Reply with quote
+1 on everything That Dippy Twat said. Electrical issues are quite likely on the 5th gen, unless you are fortunate enough to find one that has been well sorted. Often times owners will install an aftermarket band aid called a VFRness. In my opinion the VFRness is a worthless piece of crap that owners slap on the bike (prior to sale) so that they can say they fixed the problem. In my experience, clean connections, redundant grounds, and hard wiring (eliminating the connector) between the stator and RR (three phase circuit) does wonders for the reliability of the VFR electrics. Installing a decent voltage monitor is a smart move on these bikes. In my experience, you can expect about 75,000 miles out of an OE stator. The mosfet RR on my bike lasted longer than that.
Evil Hans
PostPosted: 20:58 - 01 Jan 2022    Post subject: Reply with quote
ST1050 is a great bike (OK I'm biased) but be prepared for the possibility of electrical niggles, and make sure the rear hub/chain adjuster has been regularly serviced and greased otherwise they have a tendency to seize. Earlier ones have a habit of self destructing their starter sprag gears.
Mine has been reliable, except for the charging system once giving up after a day of riding in torrential rain. It was fine once it dried out, though.
Fred3606
PostPosted: 16:51 - 03 Jan 2022    Post subject: Reply with quote
thanks for the responses and advice!
I'll keep an eye out for all you're pointers when I'm having a look around
The last post was made 4 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 45.25 Kb
