Plug check
Farmingstock
PostPosted: 13:48 - 01 Jan 2022    Post subject: Plug check Reply with quote
Does this plug look ok?
Trying to sort out the fueling on a 50cc, it starts on the button sometimes and runs fine but then occasionally it won’t start at all on the button the barely runs at all when I bump it and once it does start I have to wind the throttle totally back and hold it there or it’ll die, then eventually it will Rev up.
It’s getting fuel as I’ve tried to undo the overflow on the carb and it leaks out of that.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:55 - 01 Jan 2022    Post subject: Reply with quote
Yep, looks fine.
Triumph Sprint ST 1050
Farmingstock
PostPosted: 14:00 - 01 Jan 2022    Post subject: Reply with quote
Any suggestions as to why it has the running issue?
Almost like it’s getting either too much are or too much fuel?
Nobby the Bastard
Harley Gaydar
PostPosted: 14:18 - 01 Jan 2022    Post subject: Reply with quote
What bike?
Fueling can't change that dramatically if it starts fine sometimes and not others. what sort of fuel tap does it have?
Does it start fine when cold or hot?
Do you mean overflow or drain screw? Fuel shouldn't be coming out of an overflow.
Farmingstock
PostPosted: 14:40 - 01 Jan 2022    Post subject: Reply with quote
It’s a Rieju with the AM6 50 engine.
Does it hot and cold, has a vacuum fed tap, a new one, comes out of the drain when I undo the tap.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:44 - 01 Jan 2022    Post subject: Reply with quote
The drain on the fuel tap? It shouldn't have a drain.
Farmingstock
PostPosted: 14:46 - 01 Jan 2022    Post subject: Reply with quote
The drain on the bottom of the carb, you unscrew it and fuel comes out! Most carbs have them!!
Nobby the Bastard
Harley Gaydar
PostPosted: 14:50 - 01 Jan 2022    Post subject: Reply with quote
Yes I know. Your comment was unclear on whether you were talking about that because you referred to a tap and an overflow. Rather than a drain and a screw.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:08 - 01 Jan 2022    Post subject: Reply with quote
Is the vacuum pipe in good condition and a good seal at each end?
Farmingstock
PostPosted: 15:23 - 01 Jan 2022    Post subject: Reply with quote
The vacuum petcock is new and yes they are tight, the reason I mentioned the tap was because I checked that when it wouldn’t start to see if there was fuel in there to try and cross that off.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:24 - 01 Jan 2022    Post subject: Reply with quote
Does the tap have a 'prime' position?
Farmingstock
PostPosted: 15:44 - 01 Jan 2022    Post subject: Reply with quote
No, nothing on the petcock and nothing on the carb.
Farmingstock
PostPosted: 18:16 - 05 Jan 2022    Post subject: Reply with quote
The bike has the issue all the time now, it struggles to start but does start with no throttle, as soon as I touch the throttle to give it any revs it will die, also the mixture screw and idle screw do nothing!
Looking like a carb issue.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:33 - 05 Jan 2022    Post subject: Re: Plug check Reply with quote
Thats not a fueling issue with a carb. They dont sometimes work fine and at others not at all unless there's a reason that fuel isn't going into the carb.
jaffa90
PostPosted: 18:35 - 05 Jan 2022    Post subject: Reply with quote
Hi again, "" but does start with no throttle""
That tells me the pilot jet is letting fuel through with part opening of the butterfly flap / carb slide / piston. Opening it more (more throttle) should pick up more fuel from the main jet.
I suggest that the carb should be serviced and an inline fuel filter fitted to see what is going on.
Farmingstock
PostPosted: 19:30 - 05 Jan 2022    Post subject: Reply with quote
Made a quick video to hopefully explain, this is warm, choke does nothing either way. Won’t start when on throttle!
Kawasaki Jimbo
PostPosted: 19:34 - 05 Jan 2022    Post subject: Reply with quote
That’s doing the opposite of what I thought you meant originally. It dies with throttle. Air leak?
Farmingstock
PostPosted: 19:41 - 05 Jan 2022    Post subject: Reply with quote
I’ve sprayed brake clean around the carb and no change in revs
jaffa90
PostPosted: 02:27 - 06 Jan 2022    Post subject: Reply with quote
Try OIL SPRAY (to be on the safe side) direct into the carb inlet and open the throttle when on tick over/ idle.
mentalboy
PostPosted: 03:33 - 06 Jan 2022    Post subject: Reply with quote
Has this started happening since the start of winter? Sounds to me like it could be condensation collecting in the float bowl.
Make mine a Corona.
Farmingstock
PostPosted: 18:24 - 06 Jan 2022    Post subject: Reply with quote
Still no joy today
Tried some fresh fuel in a separate tank - no joy
Tried a new plug -no joy
Tried spraying pre-mix around carb with throttle open - no joy
Checked all the jets - all clear
Tried without filter - no joy
Tried blocking air filter intake - no joy
I have taken the carb off again, to check gallery’s and all clear, the float has no adjustment as it’s made of plastic.
As can be seen in the video, it’s from tickover to anything above, could it be anything to do with the reeds or needle height? I haven’t touched either as yet but I’m struggling here
jaffa90
PostPosted: 18:33 - 06 Jan 2022    Post subject: Reply with quote
"""Tried spraying pre-mix around carb with throttle open - no joy"""
I hope you mean IN THE CARB?
Farmingstock
PostPosted: 18:39 - 06 Jan 2022    Post subject: Reply with quote
No around the carb was checking for air leaks to see if there was any change.
Farmingstock
PostPosted: 21:07 - 06 Jan 2022    Post subject: Reply with quote
Put the carb back together and no change! Tried spraying fuel in the carb, no change, seems to be getting plenty of fuel!
Farmingstock
PostPosted: 22:17 - 06 Jan 2022    Post subject: Reply with quote
Just took the silencer off and it now revs up! It lingers low down it the revs around 3000 revs, then drops down to 2000 revs after around 30 seconds but with the silencer removed it actually revs up, it feels very lazy low in the revs and not responsive at all, but high in the revs it pulls ok.
Could it be over fuelling?
The last post was made 4 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.77 - MySQL Queries: 16 - Page Size: 122.84 Kb
