Bearing shelf life
t121anf
PostPosted: 19:41 - 15 Jan 2022    Post subject: Bearing shelf life Reply with quote
I need to replace the bearing in my steering damper, it’s available to order in Fowlers but not stocked.
eBay has a couple of listings but they are “new old stock” mainly looks like tatty packaging.
Would it be worth paying the extra for one from Fowlers over buying a new old stock one?
I’d still need to get the dust seals from Fowlers as mine have disappearing, and they aren’t listed by the bearing sellers on eBay.
sickpup
Old Timer
PostPosted: 19:45 - 15 Jan 2022    Post subject: Reply with quote
As long as correctly stored a bearing in packet would last pretty much forever.
t121anf
PostPosted: 23:10 - 15 Jan 2022    Post subject: Reply with quote
Suppose that’s the risk with eBay, one bag is open, the other is still stapled shut but doesn’t look like it was ever sealed.
jeffyjeff
PostPosted: 02:02 - 16 Jan 2022    Post subject: Reply with quote
Contact the seller. Ask about their return policy. If you don't like the bearing, send it back. You only risk the cost of postage.
jeffyjeff
PostPosted: 02:11 - 16 Jan 2022    Post subject: Reply with quote
By the way. If the steering damper has worked the old bearing past its service life, I'd think that the damper itself must be shot by now as well. You might consider replacing the whole assembly. just a thought.
xX-Alex-Xx
PostPosted: 09:15 - 16 Jan 2022    Post subject: Reply with quote
It doesn't matter what their own policy is, if they're operating as a business on eBay you have a right to return it regardless.
https://pages.ebay.co.uk/safetycentre/rights.html
DILLIGAF
PostPosted: 10:21 - 16 Jan 2022    Post subject: Reply with quote
We had bearings on the spare gear shelves on ships that had been there since the ship was built, in some cases up to 40 years old. I can't remember ever finding one that was unusable.
I might have qualms about using a sealed bearing (ZZ or 2RS) as you can't be sure of the grease condition if it's not from a sealed package and old but an open face one, no problem.
sickpup
Old Timer
PostPosted: 12:32 - 16 Jan 2022    Post subject: Reply with quote
Any decent steering damper is designed to be rebuilt.
t121anf
PostPosted: 16:45 - 16 Jan 2022    Post subject: Reply with quote
Damper seems fine, probably could do with an oil change but as I’m hardly Rossi I’m not that concerned.
The reason I want the bearing doing is when you go over a bump the vertical movement had increased and it comes down with a bang, it never used to do this.
Got the damper off the bike and the bearing is defo shot, it’s rough and you tell it has too much vertical play, not to mention the missing seals.
Going to order the one from eBay, the saving will pay for the stupidly over priced seals (approx. £12 each)
steve the grease
PostPosted: 17:22 - 16 Jan 2022    Post subject: Reply with quote
If it's just a regular bearing with seals , can't you get one from somewhere like ' simplybearings' ? Does the bearing have any numbers on it, or are the sizes easily measurable? Dealers often charge silly prices. Starter drop gear cover o ring - dealer 6 or 7 quid. Simply bearings 2 for £1.50
PostPosted: 17:29 - 16 Jan 2022    Post subject: Reply with quote
How much are they?
WD Forte
PostPosted: 17:43 - 16 Jan 2022    Post subject: Reply with quote
Steering dampers usually use rod end or Heim joint bearings
cant recall ever seeing one with seals on tho'
but that isnt to say they don't exist and some may have a boot on them.
Simply bearings is often my first point of call when looking for bearings
as bikes are made to fit bearings not the other way round.
A clunk when going over bumps makes me suspect other stuff
as a damper is to stop/dampen rapid oscillations not clunks
but as usual, we have no pics, no mention of make model etc................
bikers smell of wee
t121anf
PostPosted: 21:50 - 16 Jan 2022    Post subject: Reply with quote
How much are they?
£60, eBay one is £38 iirc.
t121anf
PostPosted: 21:51 - 16 Jan 2022    Post subject: Reply with quote
Bearing size is
18X17.5X11
t121anf
PostPosted: 21:52 - 16 Jan 2022    Post subject: Reply with quote
Seal
Seal
https://www.fowlersparts.co.uk/parts/view/64339-14101
One above and below.
PostPosted: 23:11 - 16 Jan 2022    Post subject: Reply with quote
Is this it on eBay? https://www.ebay.co.uk/itm/154101439707?
t121anf
PostPosted: 10:41 - 17 Jan 2022    Post subject: Reply with quote
Ste wrote:
that's the same bearing, but it was this one I was thinking of ordering
https://www.ebay.co.uk/itm/133446535506
jaffa90
PostPosted: 13:04 - 17 Jan 2022    Post subject: Reply with quote
Have you considered e-bay no`s.
384607722458
353762134901
t121anf
PostPosted: 16:21 - 17 Jan 2022    Post subject: Reply with quote
384607722458
353762134901
Don't want a top mount damper.
WD Forte
PostPosted: 16:40 - 17 Jan 2022    Post subject: Reply with quote
Just buy the fecker, stick it on and use the old dust seals if they're largely intact
then you get on and sort the clunk out
bikers smell of wee
PostPosted: 16:55 - 17 Jan 2022    Post subject: Reply with quote
That will be fine. Thumbs Up
jeffyjeff
PostPosted: 20:45 - 17 Jan 2022    Post subject: Reply with quote
What could be clunking in the front end? Loose caliper? Steering head bearings? I would check the steering head bearing preload. If the bearings need to be replaced, taper roller bearing replacements might be available. A definite upgrade, in my opinion.
xX-Alex-Xx
PostPosted: 21:09 - 17 Jan 2022    Post subject: Reply with quote
Can confirm Thumbs Up
DILLIGAF
t121anf
PostPosted: 22:53 - 17 Jan 2022    Post subject: Reply with quote
It’s the damper, there was enough play you could lift it and let go , and hear the same noise.
t121anf
PostPosted: 22:43 - 28 Feb 2022    Post subject: Reply with quote
For anyone interested I didn’t change the bearing in the end, cleaned it up gave it a load of grease and replaced the missing “pillow” seals.
Very little vertical play now, still some as there should be, but I can no longer lift the damper and drop it to hear the clunk I could before.
The last post was made 4 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 128.6 Kb
