How to move a heavy motorbike around in a small space?
jimster
PostPosted: 17:44 - 17 Jan 2022    Post subject: How to move a heavy motorbike around in a small space? Reply with quote
This is probably a question with a really obvious answer (so apologies) but my Diversion 900 weighs a metric s*** ton (or at least, 250kg+) and I need to occasionally get it in and out of a tight backyard and my feeble arms struggle. Every time this has been a major pain. Is there any easy accessible and cheap piece of equipment I can use to make this less awkward? Maybe a paddock stand or some kind of dolly? Halfords sells a little stand on wheels but (i) how do I get the front wheel up and onto this thing and (ii) how do I stop the bike tipping over sideways?
I doubt I'm the first person with this issue so wanted to tap into the collective knowledge. Thanks!!! Very Happy
Current: Yamaha Diversion XJ900
Previous: Yamaha Diversion 600cc, Piaggio Zip 50cc, Honda CG125-W, Siamoto Caddy 50cc moped
Fat Angry Scotsman
PostPosted: 18:01 - 17 Jan 2022    Post subject: Re: How to move a heavy motorbike around in a small space? Reply with quote
How tight is this backyard because I can wheel and manoeuvre my ER-6F which is over 210kg around hedges and a normal width gate and I am an obese unfit cunt. Need to know some more details. A dolly or two dollies will be harder to handle than just wheeling the bike unless you have someone else around to control the other end, etc.
c_dug
PostPosted: 18:16 - 17 Jan 2022    Post subject: Reply with quote
For really tight manoeuvres I prefer to sit on the bike and use the engine if possible, for example to get in and out of the garage I have to squeeze between mine and my neighbours cars and then turn tightly across my own car bumper into the garage. If we're parked a bit tight it is far easier to ride through the gap than push.
Once inside the garage I have a centre stand turn table which makes it really easy to 180 the bike on the spot (in theory it can be done on the sidestand but I'm not a fan).
Kawasaki Jimbo
PostPosted: 19:26 - 17 Jan 2022    Post subject: Reply with quote
It’s not clear what the real issue is. Going round tight corners? Paint diagram FTW. What’s the Halfords dolly thing? If you mean the roller-stand for oiling the chain that won’t do. In fact I don’t think there is an equipment solution.
I’ve never got the knack of wheeling a bike backwards with one hand on the bars, the other on the seat. Instead I lean it on my hip. Forwards too, sometimes.
PostPosted: 19:44 - 17 Jan 2022    Post subject: Reply with quote
If you're struggling to physically push it, put a camlock strap round the rear grabrail and your waist so you're pulling it along with your mass and only steering with your arms.
This also works if you find yourself having to push your bike any distance on the road (eg when out of fuel). Remember to use the brake to stop or it can all run away with you.
UncleFester
PostPosted: 20:06 - 17 Jan 2022    Post subject: Reply with quote
https://www.workplacestuff.co.uk/product/sealey-motorcycle-dolly-side-stand-type/?of_tid=MFRWG5B5GM3DCJTGMVSWISLEHUYSM4DSN5SESZB5GEYTINRW&adGroupId=79962807551&device=c&gclid=EAIaIQobChMIwOOrrL259QIVMYODBx1GLwHtEAQYBCABEgKlrvD_BwE
That's what i used to store the old VFR on - made it dead easy to get it parallel with the back wall of the garage.
But you do need a good flat surface.
2017 Z1000SX
Kawasaki Jimbo
PostPosted: 20:27 - 17 Jan 2022    Post subject: Reply with quote
I have visions of the bike tipping away and the rope launching jimster into orbit. There was a brief childhood craze using a knotted string and a 3-foot wooden dart to launch the thing roughly twice as far as you could throw it unaided. Spear thrower.
Easy-X
PostPosted: 22:33 - 17 Jan 2022    Post subject: Reply with quote
https://pictures.topspeed.com/IMG/jpg/200905/kawasaki-zx-6r-with-.jpg
Keithy
PostPosted: 22:42 - 17 Jan 2022    Post subject: Reply with quote
Or pop it in gear and hold in the clutch when moving it. It’s easier to move when you are on the left side as you don’t have to reach over the bars to get to the brake lever.
I have one of these for in the garage
https://www.amazon.co.uk/PDSR024-Biketek-Floating-Paddock-Stand/dp/B008F5RWG2
But as mentioned earlier, needs a smooth surface.
Tdibs
PostPosted: 03:42 - 18 Jan 2022    Post subject: Reply with quote
Sit on it and paddle with feet or use the engine?
t121anf
PostPosted: 11:00 - 18 Jan 2022    Post subject: Reply with quote
Abbastands Moto Glide
https://abbastands.co.uk/product-detail.asp?item=moto-glide-package&pid=63
A100man
PostPosted: 11:36 - 18 Jan 2022    Post subject: Reply with quote
t121anf wrote:
Clever.. but one hell of a palaver..
Nobby the Bastard
Harley Gaydar
PostPosted: 11:38 - 18 Jan 2022    Post subject: Reply with quote
Donuts.
Triumph Sprint ST 1050
Fat Angry Scotsman
PostPosted: 11:58 - 18 Jan 2022    Post subject: Reply with quote
What I was thinking. When I eventually have a house with a garage I will absolutely get an Abba Stands skylift, but I don't see OP wheeling one of these around his garden unless it's concreted and smooth.
t121anf
PostPosted: 13:10 - 18 Jan 2022    Post subject: Reply with quote
A100man wrote:
Takes <5 mins to get the stands and full moto glide kit on my GSXR, wouldn't be without it.
ThunderGuts
PostPosted: 13:24 - 18 Jan 2022    Post subject: Reply with quote
Centre stand turntable if you're really tight for space. Ride in, ride out. That said, I've considered similar for my 250kg VFR (which I currently wrestle by hand on the not-level garage floor) but the centre of mass is nowhere near the centre stand so I don't actually think a turntable would work for mine unless I fill the topbox with bricks first.
TG.
Keithy
PostPosted: 13:56 - 18 Jan 2022    Post subject: Reply with quote
On the plus side you would have a night storage heater on the back Very Happy
A100man
PostPosted: 14:43 - 18 Jan 2022    Post subject: Reply with quote
If you have decent set-up and smooth floor it'd work. Although I'm sure I'd spend most of my time tripping over it in my (ironically) cramped spaces..
..5 mins is just enough t be annoying. unless it's once a year at the end of the season
t121anf
PostPosted: 15:48 - 18 Jan 2022    Post subject: Reply with quote
yeah the lack of a smooth garage is a problem, I attacked mine with a chisel and it's better now.
I'm not a commuter so it's not a big problem for me, I pull the bike from the side to where the car would normally be, take it off the stands leaving bits all over the place, when I return I reverse the back back into the garage and re-fit.
I've considered a new bike which isn't Abba compatible and wondered what I'd do.
Fat Angry Scotsman
PostPosted: 15:50 - 18 Jan 2022    Post subject: Reply with quote
What bike? They can machine custom fittings for almost any bike in existence from what I have heard.
t121anf
PostPosted: 17:01 - 18 Jan 2022    Post subject: Reply with quote
Not asked them but I was thinking Triumph Thruxton R, it's not listed on their site.
c_dug
PostPosted: 18:26 - 18 Jan 2022    Post subject: Reply with quote
I use mine daily and I have to put a lot of weight through the pillion handles/seat to get it to tip back, but it turns nice and easily once I do.
stevo123
PostPosted: 22:44 - 18 Jan 2022    Post subject: Reply with quote
Looking at it from another angle can you make your access to and from the garage easier? Re-arrange things perhaps, I don't know. Just a thought
Freddyfruitba...
PostPosted: 19:58 - 21 Jan 2022    Post subject: Reply with quote
Some people are happy to spin the bike round on it's side-stand, eg:
https://youtu.be/K2HoKzrHcQY
Quite high likelihood of disaster though, even if you reckon the sidestand isn't going to snap or bend under the weight...
MCN
PostPosted: 19:42 - 22 Jan 2022    Post subject: Reply with quote
Sum peepol are as dum as fuk too. Very Happy
Spining on the side stand bends the side stand or the bracket/lug.
Its more party trick than solution.
The last post was made 4 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.28 - MySQL Queries: 13 - Page Size: 131.25 Kb
