Kawasaki Triple exhaust baffles - and baffle plates
Martin4150
PostPosted: 21:20 - 17 Jan 2022    Post subject: Kawasaki Triple exhaust baffles - and baffle plates Reply with quote
Hello
Kawasaki KH / H1 / H2 etc model
Can anyone settle an argument relating to the fitting of baffles tubes in relation to the silencer internal baffle plates.
So, 30 years plus silencers that have had the baffles tube in and out God knows how many times, so tubes are worn and covered in carbon, baffles plates likewise and central holes enlarged due to baffles being ragged in and out.
Friend of mine insists that the baffle tube must be an interference fit into the baffle plate nearest to the engine. Is this correct and how is that going to happen with all the wear and tear over the years ?
Looking forward to your comments.
redeem ouzzer
PostPosted: 21:42 - 17 Jan 2022    Post subject: Reply with quote
I see his point but we are not talking the height of 2t technology here, it’s not far of being three lawnmower engines bolted together. As long as all three pipes have the correct baffles and everything is clean then I can’t see there being a problem.
Be a REAL MAN!
Tankie
PostPosted: 22:20 - 17 Jan 2022    Post subject: Reply with quote
If you look at a cut open pipe of one of the H series pipes you will see that the silencer is in fact an expansion pipe , so yes in theory the removable baffle tube is indeed the tail pipe of the chamber, but for practical manufacturing and ease of removal it is not a good fit in the first baffle which forms the front of the silencer part of the system.
I do not use standard pipes on my machines but instead use after market silenced expansion pipes.
PostPosted: 00:02 - 18 Jan 2022    Post subject: Reply with quote
Bloody hell mate, I spat my rum out there. Don't say that on a Kwak forum, they'll burn you at the stake. Laughing
Triumph Trophy Launch Edition
PostPosted: 00:21 - 18 Jan 2022    Post subject: Reply with quote
Pick the middle stake. They never run properly.
redeem ouzzer
PostPosted: 14:25 - 18 Jan 2022    Post subject: Reply with quote
It's fact though. Aircooled, piston ported, no CNC control of timing or carbs, low state of tune. A bit of blow by over the exhaust baffle isn't going to be a deal breaker.
Be a REAL MAN!
The last post was made 4 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.2 - MySQL Queries: 13 - Page Size: 48.33 Kb
