Yamaha yzf 125 error code
piazza
PostPosted: 17:40 - 20 Jan 2022    Post subject: Yamaha yzf 125 error code Reply with quote
I've got 2011 yzf with a flashing engine management light on and can't find a port to read it. Anyone got one or know where it is?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:42 - 20 Jan 2022    Post subject: Re: Yamaha yzf 125 error code Reply with quote
You need to count the number of flashes (and potentially if they are long or short) then look up that.
Triumph Sprint ST 1050
piazza
PostPosted: 17:57 - 20 Jan 2022    Post subject: Reply with quote
It's just a flash not a code the problem is finding the port reader that doesn't seem to exist. It says to 'disconnect the diagnostic wire and plug it into no 2'
Nobby the Bastard
Harley Gaydar
PostPosted: 17:58 - 20 Jan 2022    Post subject: Reply with quote
FFS
https://www.r125forum.com/threads/error-code-list.8660/
piazza
PostPosted: 18:11 - 20 Jan 2022    Post subject: Reply with quote
Yes that's codes, it's not a code just a flash and if I can find out how to plug in and read it that'd be helpful Thumbs Up
Evil Hans
PostPosted: 18:15 - 20 Jan 2022    Post subject: Reply with quote
Just a single flash? Or a continuous flashing? Or does it flash a certain number of times then stop?
For example, as explained in the link above, 2 long flashes followed by 5 short ones would be code 25
Nobby the Bastard
Harley Gaydar
FFS part deux....
'After the engine has been stopped, the lowest fault code number is indicated by the engine trouble warning light'
https://www.yam-r125.net/ecu_self_diagnostic_function-348.html
piazza
PostPosted: 18:19 - 20 Jan 2022    Post subject: Reply with quote
It's just a standard flash like an indicator. The location of the port is what were looking for.
Everything you've sent has been seen and read already Nobby.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:41 - 20 Jan 2022    Post subject: Reply with quote
But clearly not understood....
If you need a separate reader the light would come on a d stay on.
It's flashing. Its sending you a message in a code that you don't understamd....
WD Forte
PostPosted: 23:58 - 20 Jan 2022    Post subject: Reply with quote
Continuous flashing = bent sub frame, chain slack
bikers smell of wee
The last post was made 4 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 8.32 - MySQL Queries: 13 - Page Size: 64.11 Kb
