Thread and nut pitch
XT65
PostPosted: 18:28 - 07 Feb 2022    Post subject: Thread and nut pitch Reply with quote
Good afty all hope all's well
chain adjusters Question: [or anything with bolts]
If:
[21 94002-08000-0S NUT, HEX., 8MM •••••••••••••• 2 2 2 2 2 2 2]
[22 94030-08000 NUT, HEX., 8MM ••••••••••••••2 2 2]
And two different pitches are given:
M8 standard = 1.25
M8 fine = 1.00
and if I measure the pitch of the adjuster threads with a pitch gauge and it fits 1.25 better than 1.00 mm
Then does that mean I'd use the fine [bearing in mind one's the lock-nut] so it's a tighter fit , or:
use the standard 1.25 as measured on the adjuster threads?
Is that the convention , [I've never thought about it before]?
Do you find the pitch of something ie a thread and call it the 'standard'
and then use the 'fine' as the nut's internal thread -
or is it simply 'like for like'?
given that - how would I know just from the part description what pitch it is meant to be and nothing to suggest it in the parts info either?
Hope this makes sense -- Maybe .25 of a mm is neither here nor there in the grand scheme of things and as I said ,it's not something I've given any thought to ,tbh .....
If it goes on ,it goes on :)
Cheers all !
Fat Angry Scotsman
PostPosted: 18:35 - 07 Feb 2022    Post subject: Re: Thread and nut pitch Reply with quote
If:
M8 standard = 1.25
M8 fine = 1.00
If it goes on ,it goes on Smile
Cheers all !
If it fits the 1.25mm gauge better than it fits the 1.00mm gauge then you get the 1.25mm pitch version. Laughing
steve the grease
PostPosted: 19:00 - 07 Feb 2022    Post subject: Reply with quote
It's not a choice, or about loose and tight threads, it's an either /or choice.. One nut when screwed on the appropriate bolt will move along the thread 1mm if rotated one turn , the other 1.25mm, if you mix the threads the nut will jam on the thread, if you keep turning the nut then it will rip the threads on which ever is the softest material, usually the nut. Most threads are the standard coarse thread ,for 8mm , the 1.25, only special applications use the finer thread.
WD Forte
PostPosted: 19:03 - 07 Feb 2022    Post subject: Reply with quote
As said, use the same pitch as the bolt
Mixing them up will strip threads
M8 nuts and bolts usually have a 1.25mm pitch as standard
and 1mm or even 0.75 pitches are regarded as 'fine' thread/pitches
bikers smell of wee
PostPosted: 19:12 - 07 Feb 2022    Post subject: Re: Thread and nut pitch Reply with quote
Yep, you always match the pitch of the nut and the thread, no ifs, no buts.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:13 - 07 Feb 2022    Post subject: Reply with quote
It'll go from righty tighty to righty loosey very quickly with a mismatched thread pitch...
Triumph Sprint ST 1050
WD Forte
PostPosted: 19:23 - 07 Feb 2022    Post subject: Reply with quote
You should be able to run a new nut up with finger and thumb
or if it's a lock nut, until it hits the locking collar
if its stiff from the start do NOT use a spanner as you probably have
mismatched threads
bikers smell of wee
PostPosted: 19:34 - 07 Feb 2022    Post subject: Reply with quote
mismatched threads
Or a Royal Enfield. Laughing
XT65
PostPosted: 21:03 - 07 Feb 2022    Post subject: Reply with quote
Thanks a lot Steve that makes sense
XT65
PostPosted: 21:05 - 07 Feb 2022    Post subject: Re: Thread and nut pitch Reply with quote
Yes nice 1 thank you MarJay
XT65
PostPosted: 21:10 - 07 Feb 2022    Post subject: Reply with quote
stinkwheel wrote:
mismatched threads
a1 cheers Stink
XT65
PostPosted: 21:11 - 07 Feb 2022    Post subject: Reply with quote
Cheers Nobby
SpiritMr89
PostPosted: 00:39 - 12 Feb 2022    Post subject: Reply with quote
Thought everyone had a random tub of bolts.
Just find a m8 and try it.
If not go somewhere that has thread bar, and put the bolt against it. If the threads match all the way it is standard.
Knowwing Land Rovers better than bikes these days. Thay have some stuff which is completely custom to them. Could not find the correct thread and pitch anywhere for a 300tdi oil return. 30quid from Land Rover.
Hello
PostPosted: 01:33 - 12 Feb 2022    Post subject: Reply with quote
I've never yet in my life seen a M8 x 1mm pitch bolt (that I recognised as one).
The odds that it's not 1.25mm pitch are very remote especially for a chain adjuster, there's just no reason for it to be a fine pitch.
PostPosted: 13:56 - 13 Feb 2022    Post subject: Reply with quote
I really would reccomend getting one of these if you are doing your own spannering. Cheap and eliminates any doubts on pitch size. OK, it's not a necessity but I'm a tool nerd and it's nice to have. Laughing
https://images-eu.ssl-images-amazon.com/images/I/41RVb1HZRwL._SY445_SX342_QL70_ML2_.jpg
https://www.amazon.co.uk/Deals%E3%80%91OriGlam-Stainless-Measuring-55-Degree-60-Degree/dp/B071H8GP18/ref=sr_1_6?keywords=metric+pitch+measure&qid=1644756896&sr=8-6
Triumph Trophy Launch Edition
PostPosted: 18:10 - 14 Feb 2022    Post subject: Reply with quote
Metric fine are pretty rare, and annoying when I find them! Bolts holding the detatchable frame rail on the Bandit is metric fine (M10 from memory)
Katy
PostPosted: 18:58 - 14 Feb 2022    Post subject: Reply with quote
Katy
Yeah, M10 fine Suzuki use plenty of those. M8 fine I have never seen. Maybe used for banjo bolts I dunno.
PostPosted: 22:41 - 14 Feb 2022    Post subject: Reply with quote
Think banjo bolts are m10. Seems m8 fine is common on paddock stand bobbins.
Katy
struan80
PostPosted: 23:09 - 14 Feb 2022    Post subject: Reply with quote
UNF and UNC.
Fisty
PostPosted: 19:29 - 17 Feb 2022    Post subject: Reply with quote
Katy
Bloody hell! Welcome back Mrs Katy! Pleased to see you are still here!
Fatter and faster than Fret
The last post was made 4 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.47 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 113.57 Kb
