Running on low oil for long, how screwed up am I?
 Topic moved: from The Cycling Forum to The Workshop by stinkwheel (20 Feb 2022 - 14:19)
Leo8900
PostPosted: 14:32 - 19 Feb 2022    Post subject: Running on low oil for long, how screwed up am I? Reply with quote
Hey lads,
Got my bike 3 months ago, so i’m a first timer with vehicles in general, had no idea what I was doing. It’s an 125 Nmax, bought it with 3.8k km, learned how to change the oil and did when around 4.5k km. I read the manual and it said oil should be changed every 6k km, so as i work with the bike I aimed to change again after 4k km. 3 months later and 4k km more I remembered I had to check the oil derp and it didn’t even reached the min mark on the dipstick.
I just changed the oil and you can see in the photo it had like 100ml only, the recommended is 900ml.
Never heard any unusual rattling or banging noises or any evident symptom, loss of power etc… only a couple of times when in idle at traffic lights the engine would get quieter and recovered. Noticed white smoke too when accelerating it, but nothing excessive.
should I be worried and alert about something?
I read I should keep an eye on the oil in case it becomes milky.
Thanks
PostPosted: 14:52 - 19 Feb 2022    Post subject: Reply with quote
Bike engines get tappity when the oil is run low usually. If you haven't noticed that then you're probably alright. Either way, there's nothing to do now except fill it up and see what happens. If it starts and runs quietly then you probably got away with it.
doggone
PostPosted: 15:08 - 19 Feb 2022    Post subject: Reply with quote
If the oil light didn't come on it was likely able to maintain pressure.
Generally if that light comes on in use it is already too late and some damage has been done.
The pump draws from low down in the reserve and even if it sucked a but of air through once in a while the internals would still stay oily until it got going again - hopefully.
GettinBetter
PostPosted: 17:54 - 19 Feb 2022    Post subject: Reply with quote
doggone wrote:
If the oil light didn't come on .....
Assuming it has a 'working' oil light.
Freddyfruitba...
PostPosted: 18:51 - 19 Feb 2022    Post subject: Reply with quote
Well, pushbikes generally don't in my experience Wink
WD Forte
PostPosted: 19:24 - 20 Feb 2022    Post subject: Reply with quote
I doubt it has an oil pressure light
not many scoots or small bikes seem to have them
bikers smell of wee
bikenut
PostPosted: 20:50 - 20 Feb 2022    Post subject: T Reply with quote
I assume this bike has a dip stick and you know how to use it ?
Post a picture of the bike....
Bet you have lubed the chain and checked the tyre pressures....oh, and put petrol in the tank ?
Don't forget to wear a helmet and what the bloody hell are you doing riding a bike in this weather !!!
nuts about bikes
A100man
PostPosted: 20:50 - 20 Feb 2022    Post subject: Reply with quote
What Pete said.. call back in two months and let us know if it's still running.
Make sure you keep the oil level correct in future.
If it lives you're one lucky guy - buy a lottery ticket.
Kawasaki Jimbo
PostPosted: 21:17 - 20 Feb 2022    Post subject: Reply with quote
Those bikes seem to have two oil drain plugs for some reason, one below and one on the side. Have you drained all the oil?
Looks bad but they only take 900mL, I think.
Now, where did it all go? Thinking
WD Forte
PostPosted: 02:34 - 21 Feb 2022    Post subject: Reply with quote
Re 2 oil drain plugs
I reckon
The side one is for quick/frequent changes and slightly less oil dropped.
The one underneath is larger and holds the spring loaded 'thimble' strainer which needs less frequent servicing and drops more oil.
bikers smell of wee
ThunderGuts
PostPosted: 10:38 - 21 Feb 2022    Post subject: Reply with quote
On a side note, how come the OP has bad karma but apparently this is his/her only post and it doesn't appear to have had any karma? Question
TG.
xX-Alex-Xx
PostPosted: 10:41 - 21 Feb 2022    Post subject: Reply with quote
Probably cos they posted in the cycling forum first. And cyclists deserve it.
DILLIGAF
Robby
Dirty Old Man
PostPosted: 15:53 - 21 Feb 2022    Post subject: Reply with quote
My assumption is that the picture doesn't show all of the engine oil. Maybe it has oil in the final drive and that was dropped, or it has multiple plugs - possibly a proper drain and a level plug, or it was upright when it should have been leant over.
The picture appears to show less than 100ml of oil. Even on a bike with an oil capacity of 900ml, that can't be enough to have an uninterrupted supply of oil to the pump.
PostPosted: 04:50 - 22 Feb 2022    Post subject: Reply with quote
It's either fcuked or it isn't and you will soon know if it's deaded. I would surmise if there are no horrible noises and it's running OK you have escaped.
Keep an eye on the oil level and watch the exhaust for 2 stroke like clouds of blue smoke and keep you fingers crossed.
Triumph Trophy Launch Edition
Copycat73
PostPosted: 22:00 - 22 Feb 2022    Post subject: Reply with quote
there is a ladybird book on this subject .. you may find relevant ..
caveat emptor
The last post was made 4 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.32 - MySQL Queries: 16 - Page Size: 84.62 Kb
