Electronics-laden modern bikes.
Kawasaki Jimbo
PostPosted: 00:11 - 08 Mar 2022    Post subject: Electronics-laden modern bikes. Reply with quote
What sort of mileages are the electronics-laden modern bikes reaching before the gremlins appear? I expect they’re better built (proper waterproof connectors, for example) but having opened up a few old-skool handlebar switches I dread to think how complex the multi-function modern versions are. Do fancy modern bikes survive high miles and a salty UK winter or three? What’s yours done?
PostPosted: 00:26 - 08 Mar 2022    Post subject: Reply with quote
I'm on 108k miles.
Kawasaki Jimbo
PostPosted: 00:32 - 08 Mar 2022    Post subject: Reply with quote
What bike?
Shaft
PostPosted: 00:46 - 08 Mar 2022    Post subject: Reply with quote
Dunno about bikes so much, I've got an Interceptor, but that's the most modern thing I've owned and it's not overburdened with electronics.
I do work in the car industry though, where electronics are far more insulated from the weather and I can tell you for certain, the newer and more complex they get, the less reliable they are.
Many of the electronic systems are related to performance (for that read emissions) and they tend to interact with each other to such an extent, if even the slightest glitch takes place, it can have catastrophic mechanical and/or financial consequences.
I don't think bikes are quite at that stage yet (although everything bike parts related seems to be mega expensive) but it probably won't be too far down the line.
Unless you are very conversant with modern systems and how to diagnose them, I wouldn't be buying anything that isn't under factory warranty, or you are happy to undergo open wallet surgery to get fixed.
PostPosted: 00:48 - 08 Mar 2022    Post subject: Reply with quote
Kawasaki Jimbo wrote:
What bike?
rpsmith79
PostPosted: 09:15 - 08 Mar 2022    Post subject: Reply with quote
Pete. wrote:
https://www.bikechatforums.com/download.php?id=105394
So not modern, and not electronics-laden then Rolling Eyes
c_dug
PostPosted: 09:38 - 08 Mar 2022    Post subject: Reply with quote
My R1200GS was on around 50k I think when I sold it. Not a single electronic gremlin, although it really needed a good strong battery.
My Aprilia Shiver 750 is on 24,000 miles and the gremlins are creeping in. It's the only bike to have ever left me at the side of the road, and due to everything being controlled by the computer it is also the first bike I've ever had to put into a shop to even begin diagnosis.
That said, I've since bought the laptop cables and once you've had a bit of a play with the software it really isn't that bad. In some aspects it's easier than an pre-electronic-everything era bike because the laptop will usually (sometimes) tell you exactly which part is at fault.
Fat Angry Scotsman
PostPosted: 10:49 - 08 Mar 2022    Post subject: Reply with quote
Pete. wrote:
Completely off topic but I just noticed your sig about how you came off at 139 mph... what were you wearing? Jesus christ that's insane mate was it on a track so there were no trees, posts and other random obstacles that will fuck you up like on roads?
PostPosted: 11:07 - 08 Mar 2022    Post subject: Reply with quote
Fat Angry Scotsman wrote:
Came off my turbo bike on the runway. A blocked return port in the front brake master cylinder meant that pressure built up with heat as I was going down the strip until eventually the front brake locked up solid and I was still shoving it down the runway with 350hp. Took 20 minutes to cool down enough so that the front wheel would turn again.
Keithy
PostPosted: 11:12 - 08 Mar 2022    Post subject: Reply with quote
Saw 5 mins of a Wheeler Dealers episode with an Evo last night. The active yaw control was mounted under the rear wheel arch, so rotted quickly and costs £1,600 to replace. I was thinking about a similar thing on newer tech bikes, how much is an IMU and what would it cost to replace? Are there other bits like that which manufacturers are rubbing their hands together at the prospect of owners needing them in 5 years time?
PostPosted: 11:40 - 08 Mar 2022    Post subject: Reply with quote
It depends if it's a KTM or not. Triumps, BMWs and most Japanese stuff seems to be fine. KTM not so much, and Ducati depends on how you look after it.
Electronics have got better overall, with less actual wiring, all low voltage. Ducati have been using CANBus to transmit signals from one end of the bike to the other for a few years now, so you've only got a couple of wires to worry about rather than 20 or so. It's all swings and roundabouts.
Personally I was concerned when Fuel Injection was introduced, but it's been 20 odd years and I've never had a problem with fuel injection. However, I've had problems with ten year old Carbed bikes in that time... go figure.
PostPosted: 16:08 - 09 Mar 2022    Post subject: Reply with quote
When I was at maritime college I rewired my mates C15 using 3 core nicked from a builders site next to the college. I couldn't see that working on my Trophy. Laughing
blurredman
PostPosted: 19:18 - 09 Mar 2022    Post subject: Reply with quote
Keithy wrote:
IMU
Wuzzat?
UncleFester
PostPosted: 19:26 - 09 Mar 2022    Post subject: Reply with quote
Inertial Measurement Unit.
IIRC it's what does the maths for angle / lean / acceleration / grip and decides what the traction control does.
Personally i've no intention of riding a bike in the kind of weather / road conditions that kills them. Modern or not.
2017 Z1000SX
PostPosted: 09:40 - 10 Mar 2022    Post subject: Reply with quote
<pedant> The ECU's do the maths, the IMU does the measurement, it's in the name </pedant>
UncleFester
PostPosted: 10:07 - 10 Mar 2022    Post subject: Reply with quote
If you really want to split hairs, an IMU is also an ECU in and of itself Very Happy
2017 Z1000SX
PostPosted: 11:37 - 10 Mar 2022    Post subject: Reply with quote
Just an aside. Is it a fact that without fuel injection and electronics, no bike (or car) would even be able to come close to passing emission controls?
If that is the case, I'm amazed that there are no laws stopping remapping. You can't legally remove a CAT or a DPF can you, the vehicle won't pass it's MOT (or have I got that wrong) yet you can totally play around with the fueling?
xX-Alex-Xx
PostPosted: 12:02 - 10 Mar 2022    Post subject: Reply with quote
A cat or DPF is easy to check if it's been tampered with. Almost impossible to check a remap for the average garage without the right tooling and having base maps for everything to compare it to. It's a bit daft to ban anyway as having a custom map could actually reduce emissions over the one-size-fits-none base map that'll come as stock... It's not really any different to having a mechanic fail a test because you've changed jets on a carb. They'd never be able to check as they're not allowed to remove parts to inspect stuff like that.
Although having said that, these new proposed laws stopping modifications to motorcycles are going to prevent people having Power Commanders etc.
DILLIGAF
PostPosted: 12:35 - 10 Mar 2022    Post subject: Reply with quote
Yep, that's coming....
UncleFester
PostPosted: 12:41 - 10 Mar 2022    Post subject: Reply with quote
It only has to pass on that day. The market will adapt to make things better at plug and play.
Until roadside plod get more numbers then its unenforceable. Unless insurers start to require it.
So if you crash you might be double screwed.
2017 Z1000SX
grr666
PostPosted: 13:39 - 10 Mar 2022    Post subject: Reply with quote
There's removing DPFs and there's removing DPFs. The one on my Transit was removed from the van in it's entirety
and then gutted but down the exhaust pipe with no external tampering, refitted and then it's function completely mapped out,
only leaving the warning light to illuminate and then extinguish upon start up.
Only advisories on last years MOT were corroded rear brake lines. Laughing
Sold my similarly modded Sprinter to a dealer and they never spotted it on that either despite their mechanic giving the
van a thorough once over before agreeing to purchase it from me. Both vans were LOADS better to drive after the work and
I saw my average daily use MPG go up on my transit from about 35 to almost 50.
Easy-X
PostPosted: 19:54 - 10 Mar 2022    Post subject: Reply with quote
Bike EFI effectively does a "carb-emulation" in open-loop mode. Closed loop is the only nod to saving asthmatic kittens.
Direct injection (cars) on the other hand have a lot more feedback systems and you wouldn't even get close with carbs.
MCN
PostPosted: 14:32 - 13 Mar 2022    Post subject: Reply with quote
BMW k1300 18k and S1000RR. 11k
Elektronikally sound.
Unless one counts R and L handle bar switch clusterfucks replaced three times on each bike in the 1st and 2nd years from new.
Mechanical issue in the switches.
Been gremlin free for about a decade now.
Bike lektrics issuez were normally harness or connektor related in the olden days.
My triumph caused me to not buy British ever again. When the ignition coils failed on two new bikes. Arseholes.
The last post was made 4 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 126.07 Kb
