1990 xt600 cannot start
njenduro
PostPosted: 01:08 - 17 Mar 2022    Post subject: 1990 xt600 cannot start Reply with quote
Well this is my story last year before winter had it outside covered for 3 weeks cold out. Had it on a battery tender. I went to start it up and started ran for about maybe 2 minutes on choke then it stalled like it ran out of gas tried to start it and cranked but would not start up. What I did was put it into the trailer with the tender on it. Now the fun starts , I tried to start it up and cranks but will not start. I put a new spark plug in still no go. Now started to check coil all good,stator ohm good,pick up coil ohm good. Now I tried starting fluid still no good check spark it sparks but it’s there but not really bright but I got shocked. I checked the wires going to the coil the 12v bulb tester I have lites when the starter cranks. I checked valves on tdc also checked the piston to make sure that is tdc and adjusted valves now I did noticed that the feeler was real tight so maybe the valves were open so readjusted intake and exhaust and still will not start. I take the carbs off to see if they were dirty looked good even in the bowl looked good. Now I hooked up a fuel line with a cup to bypass the fuel tank. Help is needed thanks
WD Forte
PostPosted: 01:54 - 17 Mar 2022    Post subject: Reply with quote
I'd be checking the carb diaphragm hasn't hardened and/or
split over the years.
If it has, it may not be lifting and be stuck down
and it wont want to go if it has.
bikers smell of wee
njenduro
PostPosted: 02:15 - 17 Mar 2022    Post subject: Reply with quote
Now you are talking about the diaphragm on top of the carb correct. Now I have 2 on here now even if I use starting fluid to start it still doesn’t start. My concerns are now getting parts they are getting difficult because of shipping of supplies. I like the oem cause everything perfect. Now if that diagram is split symptoms would be what. Thanks for the quick response
WD Forte
PostPosted: 03:56 - 17 Mar 2022    Post subject: Reply with quote
Just looked it up and see it has a dual inlet carb
and only 1 has a diaphragm so may well have misunderstood it
as I initially assumed 1 carb
Some pics show a vac operated fuel pump for '90 xt600
if the plug is dry after repeated cranking, maybe its that not working?
could be just a cracked/split vac pipe if you're lucky
bikers smell of wee
doggone
PostPosted: 08:58 - 17 Mar 2022    Post subject: Reply with quote
The way it ran for a couple of minutes then stopped sounds like water or dirt in fuel but air leak in fuel lines is a good guess.
Unlikely the valves are involved when it initially ran, they can stick open or closed especially if a bit of damp got in somehow
Dan Norse
PostPosted: 10:00 - 17 Mar 2022    Post subject: Re: 1990 xt600 cannot start Reply with quote
Hmm, my initial thoughts were to check inside the carb etc. as modern 'supermarket' gas soon gums up if left a while, because of the ethanol in it.
Did you take out the jets etc.?
Seem like it's got to be fuel related one way or another!
If you want to meet interesting people, do interesting things...
njenduro
PostPosted: 10:33 - 17 Mar 2022    Post subject: Reply with quote
Thanks everybody for the quick response’s. I did have the carbs off and I did clean the screen, jets on the one primary carb and I did not clean the jets on the secondary carb I did not remember there is another jet in that one. I did not check the diaphragm which I should of. I will check that as well in taking the carbs back off. Anything else I should be looking into. Thanks again
MCN
PostPosted: 10:37 - 17 Mar 2022    Post subject: Re: 1990 xt600 cannot start Reply with quote
Y U shit on top of Supermarket Gas?
We use Petrol in Europe.
R U a Murikan?
Anecdotal Evidence to prove supermarket fuel is detrimental to fuel systems is only anecdotal evidence. The 'real world' Data doesn't support those claims.
I only use supermarket fuel for my car. I use premium in my bikes coz (all) supermarkets dont sell premium.
xX-Alex-Xx
PostPosted: 11:20 - 17 Mar 2022    Post subject: Re: 1990 xt600 cannot start Reply with quote
All petrol will gum up after a while regardless of ethanol content..... fuel stabiliser helps with this if you're leaving it parked up for a long time.
DILLIGAF
njenduro
PostPosted: 11:39 - 17 Mar 2022    Post subject: Reply with quote
This bike is a runner. I ride this bike just about all year and in the rain basically it stops is for 3 months for winter. But before I put away it sat outside covered with a tender. It started then stalled. My concern is it wouldn’t start back up. I did put stablizer on it anyway. Now if it was cold out and moisture was in the carb maybe something split in the carb? Any other idea for when I take them out again. I will take a look at the second jet and diaphragm. Thanks again
A100man
PostPosted: 11:58 - 17 Mar 2022    Post subject: Reply with quote
You say you ran it dry.. my bet would be some crap from the tank has blocked a circuit in the carb most likely the choke circuit...
Thoroughly clean the carb and then try again from your auxiliary tank.
njenduro
PostPosted: 12:51 - 17 Mar 2022    Post subject: Reply with quote
Never ran dry, the bike sounded like it ran out gas when it stalled but will check all again. Thanks all
WD Forte
PostPosted: 17:25 - 17 Mar 2022    Post subject: Reply with quote
If it does have a vac operated pump check that
they're not powerful and the slightest of leaks can stop them
Easy to test though, just whip off the outlet pipe and crank the motor
bikers smell of wee
PostPosted: 17:43 - 17 Mar 2022    Post subject: Reply with quote
My first thought was it having water at the bottom of the tank due to the ethanol content sludging out but using fresh fuel in your remote tank should have sorted that.
American pump fuel is appallingly poor quality and degrades rapidly when left to stand for any length of time. As one youtube channel demonstrated, the "regular" grade wont even run in a lawnmower after sitting for 12 months.
For the majority UK readers. In the USA, "regular" is 87 octane and "premium" is 91-94 octane. Most of it is either E10 or E15 ethanol content.
When you say you cleaned the carb, did that include removing the jets, washing them with solvent, blowing them through with compressed air and visually checking against a bright light that they have a clear, perfectly round hole in them.
For starting purposes, you only need to bother with the slide carb.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:46 - 17 Mar 2022    Post subject: Reply with quote
Fuck me, thats worse than most third world countries.
It does explain the quality (or lack of) of their road infrastructure though.
Triumph Sprint ST 1050
xX-Alex-Xx
PostPosted: 18:51 - 17 Mar 2022    Post subject: Reply with quote
You need to add 5 on to make it equivalent of UK ratings.
DILLIGAF
Nobby the Bastard
Harley Gaydar
PostPosted: 18:56 - 17 Mar 2022    Post subject: Reply with quote
xX-Alex-Xx wrote:
You need to add 4 on to make it equivalent of UK ratings.
Octane rating is octane rating. it's like trying to say to convert Uk celsius to US celsius you need to add 4.
'The octane rating was originally determined by mixing fuels from only normal heptane and iso octane (2,2,4-trimethylpentane, a highly branched octane), and assigning anti-knock ratings of zero for normal heptane and 100 for pure iso octane.'
njenduro
PostPosted: 19:13 - 17 Mar 2022    Post subject: Reply with quote
I did do the primary carb which does have the diaphragm. I did take out the float jet and tube all good and clean no clog the secondary did not clean Because I forgot there was a jet there but we’ll take apart again and check the diaphragm I am going to do a compression test over the weekend to make sure that’s good. This is really baffling me thanks again everybody for your help
Kawasaki Jimbo
PostPosted: 19:22 - 17 Mar 2022    Post subject: Reply with quote
Sounds like it ran out of fuel so I’d work on that basis and start by assessing the fuel pump as indicated by WD Forte.
Alternatively, did you knock the choke off in time or is it flooded?
PostPosted: 20:04 - 17 Mar 2022    Post subject: Reply with quote
In fairness, those big singles can be a bit of a dick to start when they've been stood for a while. Maybe try sticking a few drops of petrol down the sparkplug hole?
One thing maybe worth a check. Could the cable operated decompressor be stuck?
xX-Alex-Xx
PostPosted: 20:13 - 17 Mar 2022    Post subject: Reply with quote
And there's different ways of measuring the octane rating which will give you different results when testing the same fuel.
The european octane rating is ron, where as the us octane rating is an average of (ron+mon)/2
You know how 32F is the same as 0? It's like that but wet.
DILLIGAF
njenduro
PostPosted: 20:21 - 17 Mar 2022    Post subject: Reply with quote
Electric start only and vacuum for carb
PostPosted: 20:33 - 17 Mar 2022    Post subject: Reply with quote
Wrong, there is RON and PON. Research Octane number and Pump Octane Number. They haven't used pure iso octane since the 60s or something, and fuels can have octane ratings of over 100.
xX-Alex-Xx
PostPosted: 20:45 - 17 Mar 2022    Post subject: Reply with quote
RON, MON, and AKI.
Difference between RON, MON, and AKI......
Because of the 8 to 12 octane number difference between RON and MON noted above, the AKI shown in Canada and the United States is 4 to 6 octane numbers lower than elsewhere in the world for the same fuel. This difference between RON and MON is known as the fuel's sensitivity, and is not typically published for those countries that use the Anti-Knock Index labelling system
.[/i]
DILLIGAF
Nobby the Bastard
Harley Gaydar
PostPosted: 21:15 - 17 Mar 2022    Post subject: Reply with quote
Either way, the US version of standard unleaded is 1-2 ron less than the UK version.
This is where being a member of a common market where the same standards are applied is useful....
The last post was made 4 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.51 - MySQL Queries: 13 - Page Size: 127.43 Kb
