| beeblemaster |
 beeblemaster Two Stroke Sniffer
 Posted: 14:49 - 08 Apr 2005 Post subject: Can't see oil level through glass on Divvy |
Hi all,
What's the best way to check the oil if I can't see through the glass on a Yamaha Diversion?
I checked the oil last week and I noticed that the oil level was on the minimum mark (I could see it then), as I didn't have any oil I didn't top up until now.
However, now I can't see the level , so I've put some oil in, I reckon I must have put in between 500ml - 1 litre, and I still can't see the level.
So, if I can't see through the glass, how can I check the level? I don't know whether I've put too much in or perhaps not enough to get to the level?
The bike is in my garage on the centre stand where it's just about flat.
Many thanks in advance. |
| gsxrpeak |
 gsxrpeak Trackday Trickster
 Posted: 15:43 - 08 Apr 2005 Post subject: |
in this situation the best thing for you to do is. start from scratch.
go under your bike, drain all the oil out. grab your manual find out how much to put in, go get oil!
get a sweet new filter!
take old filter out, put new one in.
put that sweet none new oil in and watch your bike grant you a big smile!  |
| beeblemaster |
| Finglonga |
 Finglonga World Chat Champion
| Git |
 Git Brolly Dolly
| beeblemaster |
 Posted: 16:51 - 08 Apr 2005 Post subject: |
Why didn't I think of that sooner?
I've just checked. I put the bike on the side stand and I could see through the glass about 3/4 of the way down. Put it back on the centre stand and I see nothing.
Many many thanks!!
The glass seems filthy on the inside though, it looks a bit white which is a bit worrying.
It was clean last week and the only thing I've done since then is waxed my chain and was out on it for about a 5 mile run this afternoon. There's no chance of chain wax entering there is there?
Thanks again |
| Finglonga |
 Posted: 16:54 - 08 Apr 2005 Post subject: |
The white it water in the oil, probably condensation. Don't worry about it, take it for a good run to get the engine nice ind hot and it will go back to normal.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| beeblemaster |
| Finglonga |
| Patto |
 Patto Derestricted Danger
| Finglonga |
 Posted: 01:13 - 09 Apr 2005 Post subject: |
There are higher spec bike oils.
Some car oils seem to have problems in bike clutches, others don't. I have used BP Visco 3000 (Semi synthetic) and 5000 (fully synthetic) in bikes without problems until the engine on the Bandit was tuned, but then even with new plates and bike oil the clutch slipped.
The other problem is that the highest spec car oils have virtually eliminated some of the best additives as they also happened to damage catalytic converters in the long term.
Honda cars often use conventional 10W40 oil in their gearboxes.
The last post was made 21 years, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
