Bandit, sticky KeyHole
MonkReadusuk
PostPosted: 16:46 - 08 Apr 2005    Post subject: Bandit, sticky KeyHole Reply with quote
Hiya,
Recently my 600 Bandit has started to develop a problem with the keyhole. It has a variation of positions to lock/unlock it and at first had a slight knack to using it. However now it seems to be a lot worse and is a real pain to turn the key sometimes! Anyone else have this problem? or any suggestions to fix it?
Many Thanks
-Monk-
Git
PostPosted: 16:55 - 08 Apr 2005    Post subject: Reply with quote
Maybe give it a good soaking in wd or similar, might be a bit dry and nothcy in there..
Bendy
Mrs Sensible
PostPosted: 17:02 - 08 Apr 2005    Post subject: Reply with quote
I think you're meant to use silicon spray, but I just whanged some WD40 into mine. Smile
Gazdaman
I did a trackday!!!
PostPosted: 17:10 - 08 Apr 2005    Post subject: Reply with quote
Light oil for me, works a treat.
Gaz
Patto
PostPosted: 19:53 - 08 Apr 2005    Post subject: Reply with quote
Got exactly the same problem on my 95 Gixxer.
have been holding off replacing the complete lock as I have one key fits everything at the moment.
Does anyone know whether you can recode the seat lock and petrol cap lock to suit a new ignition barrel.
I guess you would have the same isue on a bandit should you decide to renew the ign lock.
I will check back to this post to see if anyone knows what can be done.
Patto
Pat172
PostPosted: 22:00 - 08 Apr 2005    Post subject: Reply with quote
as far as i kno 99.999% of bandits have this, i just got abit happy with a can of WD40 and its helped it alot
- Suzuki Bandit N600
Liono
PostPosted: 14:46 - 10 Apr 2005    Post subject: Reply with quote
I have the same thing on my SV, I sloshed a bit of WD40 into it and it seemed to help a bit. Pushing the key very slightly away from you when turning it seems to help too.
PostPosted: 15:53 - 10 Apr 2005    Post subject: Reply with quote
Well known Bandit problem. My 1200 has the same issue.
garry
PostPosted: 23:58 - 10 Apr 2005    Post subject: sticky key Reply with quote
as all have said ,, just keep it well lubricated , i have same prob on my 1200 , one off our crew even replaced the whole ignition ?
Sad
The last post was made 21 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.36 Sec - Server Load: 2.33 - MySQL Queries: 13 - Page Size: 58.84 Kb
