| Kawasaki Jimbo |
 Posted: 00:40 - 22 Mar 2022 Post subject: |
They have a standing charge because they are greedy bastards who don't want to lose out on profits if you decide to be frugal with your energy use.
The meter is whirring when the main switch is off but is the reading going up? If it is then something is wired in and running between the meter and the main fuse which would be a worry in itself. The meter itself will draw a negligeable amount of power.
You can buy energy monitors fairly inexpensively which have a sensor that clips round the meter output wire or the fuse box input wire. They have a display telling you how much power you are using at a particular time and your weekly total. Be interesting to see what's being drawn with the main fuse off. Also be interesting to see if the KW/h matches the meter. It won't be as exact as a meter ought to be but it should be somewhere close.
EDIT: I still have my old electromechanical meter and I will resist it being changed for as long as possible. They are reliable, accurate and don't draw any power when none is going through them. They also can't be set to overread without physically altering the meter itself. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| doggone |
 doggone World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 11:30 - 22 Mar 2022 Post subject: |
If the big black 'board fuse' is out you'll see no movement if you do then crikey...
.. Assuming therefore you are saying that with the consumer unit/fuseboard main switch off you are still seeing movement in which case you probably have an auxiliary (hopefully) fused circuit somewhere.
Post a picture of the set-up including the meter and the fuse board so we can see. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Islander |
 Islander World Chat Champion
| Nobby the Bastard |
| A100man |
 Posted: 15:30 - 22 Mar 2022 Post subject: Re: Electricity meter keeps running when main switch is off. |
| Kawasaki Jimbo wrote: | This all-electric terraced house seems to consume almost 140% of the predicted energy consumption based on number of bedrooms, etc. It used to have Economy 7 but the meter was converted so the ‘Night’ dial never moves. I’m wondering if the conversion was botched. . |
All electric probably means storage heaters - yuck. Got them at work and they cost a fortune to run., this might well explain why your bills are high (compared with Gas CH)
So your night Economy 7 was converted.. but to what? A single meter with two dials a) Day and b) Night? or, heaven forbid, the storage heaters are running on premium rate leccy. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Ste |
 Ste Not Work Safe
 Posted: 16:01 - 22 Mar 2022 Post subject: |
Your neighbour has taped into your electricity and is using it to grow weed and mine bitcoins.  |
| Kawasaki Jimbo |
| Nobby the Bastard |
| Kawasaki Jimbo |
 Posted: 20:57 - 22 Mar 2022 Post subject: |
Here’s the switchboard inside the house, and if I flick the mains to off the meter dial slows to a crawl (watch it for 10 seconds and you can see it move) but doesn’t stop, and I think it should. |
If everything is off, those meters shouldn't move, they work by induction so the disc only moves when current is flowing.
If it's barely perceptible movement, like less than 1 turn a minute, I suspect it'll be the timer which will be a tiny draw, probably costing you pennies a month. Almost certainly not worth bothering about.. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Kawasaki Jimbo |
| Kawasaki Jimbo |
| Nobby the Bastard |
| Ste |
 Ste Not Work Safe
| MCN |
 MCN Super Spammer
| Kawasaki Jimbo |
| drzsta |
 drzsta World Chat Champion
| Kawasaki Jimbo |
| MCN |
 MCN Super Spammer
| Islander |
| MCN |
 MCN Super Spammer
The last post was made 4 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
