Paint correction on honda panel advice needed
GSXReater
PostPosted: 23:21 - 23 Mar 2022    Post subject: Paint correction on honda panel advice needed Reply with quote
I have an 07 CBR600 and my seat unit has multiple small scratches.
I'm thinking of wet sanding it then polishing.
Does anyone know if the OEM bodywork has lacquer on it? I assume the tank fairing has lacquer in order to protect it from petrol ruining it but what about the other panels.
Thanks in advance.
BRUN
PostPosted: 11:17 - 24 Mar 2022    Post subject: Reply with quote
give it a polish with something with some cut in it, if your cloth changes colour its not, but i would expect it to be tbh
MCN
PostPosted: 11:48 - 24 Mar 2022    Post subject: Re: Paint correction on honda panel advice needed Reply with quote
Thanks in advance.
'Lacquer' is just the gloss part of paint without pigment and background.
It's called clear coat.
Check out RS paints.
The big issue is colour matching.
But If there is enough separation between the repair and other panels it won't be noticeable.
Honda434
PostPosted: 12:44 - 24 Mar 2022    Post subject: Reply with quote
It will have clear on it. I’d be careful wet sanding as the paint is real thin on them. You can bust through the paint really fast. If you can post a photo of it.
Honda434
BRUN
PostPosted: 13:55 - 24 Mar 2022    Post subject: Reply with quote
have you wet sanded, and then polished, before ?
make sure your using something like 3000 and have the right gear to then correct it afterwards
The last post was made 4 years, 99 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 43 Kb
