| stinkwheel |
 Posted: 23:05 - 31 Mar 2022 Post subject: Why shouldn't I get a super cub? (Honda C125) |
Looking to get the Mrs something easy to ride which requires minimal maintainance and is economical to run for a 12 mile each way commute. Her 2l diesel car is starting to get pricey to run and we don't have room for another car.
Commute is on a mix of rural roads, town running and a 5 mile A-road section which rarely gets over 55 during commuting time. She sometimes cycles it but it's a bit of a slog after a days work and you need to avoid the A-road section because it's a bit of a fucking bun fight at the best of times.
I'm actually thinking super cub. 180mpg. Well made, lots of inherant protection from long term road damage requiring a minimum of regular maintainance (enclosed chain, shrouded forks, high-end honda build quality).
Mrs stinkwheel has a full licence, IAM membership and a CBR600F but would find taking the CBR to work every day a bit of a rigmarole (and it would be a lot of wear and tear on the bike).
Seems to me it provides the weather protection and ease of use of a twist and go but with bigger wheels, proper suspension and normal motorcycle controls. Fit handlebar muffs, put on bit one-piece suit over work clothes, off you go. Maybe even one of those step-through poncho things for colder/wetter weather.
Main downside is price, they aren't cheap. Can pick up a low mileage used one for around £3k, closer to £3,600 new. I suspect they will hold their value quite well.
Thing is, I kind of want one, (or a Grom) and may be letting this colour my recommendation. So why would this be the wrong bike and what should I be getting instead? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
 WD Forte World Chat Champion
| ThunderGuts |
 ThunderGuts World Chat Champion
 Posted: 07:41 - 01 Apr 2022 Post subject: |
They're great. If I was in a position where I needed to commute on a bike and very fast roads were not involved, I'd get one. As you said, enclosed chain means it stays clean and requires less lubing. Very efficient (not sure if you'll get 180mpg out of it in the real world if riding flat out), pretty comfy, some weather protection off those legshields, simple. Not cheap as you say, but they do probably hold value better than most 125s. LED headlight is probably better than the average big bike halogen.
Speed? I ride my C90 on fast roads occasionally and it'll climb up to 55mph; it's not the bike's preferred speed, but it'll do it. If there are alternative roads for when the weather is a bit ropey, I wouldn't worry too much about that. The C125 should be able to crack 65mph I imagine on a good day.
Things to think about (one of which I remember you telling me about when I was looking at C90s!); they are easy to steal as they're so light, not sure if the electrics will cope with heated grips (if she'll use it year round) and their range is pretty limited (I get around this by having a 3L jerry can in the topbox, doubling the range pretty much to 200 miles).
I'd go for it. They're fun, they're frugal and they're practical. If she finds in 6 months she doesn't like it, she'll probably still get most of the money back on it if she sells it. It should be a red one though . . . ____________________ TG. |
| blamski |
 blamski Two Stroke Sniffer
 Posted: 09:51 - 01 Apr 2022 Post subject: |
| Polarbear |
 Polarbear Super Spammer
| Nobby the Bastard |
| Prawny |
 Prawny Nitrous Nuisance
| stinkwheel |
 Posted: 12:48 - 01 Apr 2022 Post subject: |
Maybe just me but I've never really liked the concept of a motorcycle with the engine mounted on the swingarm rather than bolted to the frame, which is probably the main reason I'm looking away from the likes of the maxi-scoots. Not big on the concept of CVTs either. Again, probably more my prejudice.
I don't think speed is a big issue, she did her commute on her YB100 for a while which does 60 absolutely flat-out downhill with a wind behind it. It's nearly 40 years old now which kind of necessitated more regular maintainance and having occasional minor breakdowns which she's not best equipped to deal with. Not the bike to be racking up commuting miles on really. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Prawny |
| WD Forte |
| A100man |
 A100man World Chat Champion
 Posted: 14:15 - 01 Apr 2022 Post subject: |
Sounds good to me, but to save cash couldn't you buy any old cub and stick a new 110 Lifan (or similar) in it? ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion |
| ThunderGuts |
 Posted: 14:46 - 01 Apr 2022 Post subject: |
| A100man wrote: | Sounds good to me, but to save cash couldn't you buy any old cub and stick a new 110 Lifan (or similar) in it? |
Not sure I'd want to trust a Lifan with commuting (I know they're cheap to replace and simple, but not sure how good their longevity is), plus the original cubs are rot-boxes (I keep mine for dry days!) which wouldn't be an issue for dry summer days, but winter salt would kill it quickly. They've also got hopeless headlights. Don't get me wrong, I love mine and would probably commute on it if circumstances were better, but only when I wanted to, not all the time.
A C90 I'd imagine doing bigger miles would require far more tinkering to keep on the road than a new or newish C125 which will probably just run and run without touching it.
Go for it I say, I was torn between a C90 and a C125, only went for the former because I liked the old-world charm and easy home mechanics, neither of which are an issue for a toy rather than a tool. ____________________ TG. |
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 14:55 - 01 Apr 2022 Post subject: Re: Why shouldn't I get a super cub? (Honda C125) |
| stinkwheel wrote: | I'm actually thinking super cub. 180mpg... So why would this be the wrong bike and what should I be getting instead? |
Fuelly reckons 120-150mpg is more realistic. https://www.fuelly.com/motorcycle/honda/c125a_super_cub
That's still bloody fantastic obviously, but puts it's on par with quite a few other alternatives. So, with the caveat that I've got a real soft spot for the super cub myself, I'll do my best devil's advocate...
The super cub has no real storage and the tank size is pitiful. It's not Honda's replacement for the C90, it's Honda's attempt to cash in on the retro market and the cult status of the C90. Ignoring styling, and sticking only to Hondas, there are measurably better alternatives.
CT125
+ Much more practical (proper rack, fork gaiters, bash plate etc.)
+ Otherwise pretty much identical
- Import only and an extra £1500 new.
PCX125
+ Much more practical (space for two lids under the seat)
+ Proven track record as a commuter
+ Cheaper (especially used where there are loads about)
- Slightly lower mpg
Innova
+ Actual C90 replacement
+ EFI from 2007 I think.
+ Decent number about, lots of parts.
+ Similar mpg
+ Much cheaper (£1200-£1700)
- Not available new
Obviously, there are loads of alternative makes/models too. I think it needs to be admitted that in purely practical terms, it's not the best choice (although I'm not aware of anything that beats it on outright mpg). So it's whether you're willing to accept it's limitations because... well they're just cool aren't they. I'll have a dark grey one.  ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| ThunderGuts |
 Posted: 15:21 - 01 Apr 2022 Post subject: Re: Why shouldn't I get a super cub? (Honda C125) |
suspect a C125 could match these figures, especially given I go through several fuel-wasting activities (let it warm up for a good few minutes before setting off, let it drain the carb bowl before parking away as it tends to do big days out but with potentially a few weeks between rides, so I don't want the bowl contents evaporating and leaving gummy muck behind).
probably slightly less competent than a C125 (thinking lights and brakes, C125 has ABS on the front and LED headlights), but probably a lot less charming than either the C125. The utility solution for sure though.  ____________________ TG.
| WD Forte |
| Brava210 |
 Brava210 Crazy Courier
 Posted: 16:05 - 01 Apr 2022 Post subject: |
| WD Forte wrote: | I was going to suggest a scooty too but reckoned I might be accused of
gender bias cos of my recent transcooter gheyness.
Even this 20 year old YP250 of mine will easily keep up with traffic on Dual carriage ways without
it feeling like I'm caning it
Good weather protection, loadsa stowage, easy relaxed ride
New scoots are all EFI so should be pretty frugal
Honda Forza 300 Vespa do a 300 Suzuki do a 180 200 and 400 Burgervan
Yamaha do 250, 400 500 scoots
I hear Kymco ( Taiwan) aint bad
I do have some reservations about the Vespas though because they seem to be designed
for looking cool rather than practical riding.
Sod looking cool, you need a good screen and stowage capabilty IMO or its just an ornament |
Scooters are for Ladies you know ____________________ Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE" |
| stinkwheel |
 Posted: 18:36 - 01 Apr 2022 Post subject: |
I was looking at Innovas but they have turned into pure rocking horse poop, I've been keeping an eye out for them and there's nothing but totally fucked moon-mileage courier hacks in London.
I'm watching a decent looking Wave on ebay. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Zen Dog |
 Posted: 19:23 - 01 Apr 2022 Post subject: |
| stinkwheel wrote: | I was looking at Innovas but they have turned into pure rocking horse poop, I've been keeping an eye out for them and there's nothing but totally fucked moon-mileage courier hacks in London.
I'm watching a decent looking Wave on ebay. |
They're not as common as you'd hope certainly, but they are about. They seem to come in more or less two categories, either it's a courier/delivery hack with a history of endless abuse, or it's been strapped to the back of a big camper van for 10 years.
The only problem with the wave is the lack of enclosed chain, and even though it's so similar to the innova, I couldn't find an answer online as to whether you could just fit an innova one. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| WD Forte |
| slowasyoulike |
 slowasyoulike Scooby Slapper
| WD Forte |
| UncleFester |
 UncleFester World Chat Champion
| stinkwheel |
| Zen Dog |
 Posted: 01:09 - 04 Apr 2022 Post subject: |
| stinkwheel wrote: | I'm thinking hanging fire and keeping my eye out for a tidier and closer Innova is going to be the best bet. Then there's no hipster premium. |
Just something to tempt you in the meantime... https://www.gumtree.com/p/honda-motorbikes/honda-super-cub-125-/1429263675
It's got a Givi screen and a rack fitted already, and it looks genuinely immaculate, as you'd expect for only 500 miles on the clock. Perhaps the lady would care to pay some premium to be conveyed in style?
I'm not sure hipsters are really the target market. I can't see topknot wearers riding them in their checked shirts (unlike customised C90s). They're not cool. The Super Cub is classy instead. It's like a genteel old lady. I suspect used prices will remain quite high, because the actual market for them is old men with excess cash who want to bimble about on them while reminiscing about their dad going to work on his. They don't need to sell so they can probably wait for a decent price. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| stinkwheel |
The last post was made 4 years, 81 days ago. Instead of replying here, would creating a new thread be more useful? |
